Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 01-14-2014, 06:05 PM   #1
vasculopath OP
You're not your bike
vasculopath's Avatar
Oddometer: 368
2014 1190 US Powerparts Skid plate mounting solution
From the Horses mouth:
TLDR Just tap it, not covered under warranty?
vasculopath is offline   Reply With Quote
Old 01-14-2014, 06:10 PM   #2
kag
Wander Lust
kag's Avatar
Oddometer: 1,736
Well I guess that answers that
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 01-14-2014, 06:37 PM   #3
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,415
Does the 1190
Bother you? Nice that someone posted it with a image and info that can be helpful for many owners. Yes not 950 owners sorry
ebrew is offline   Reply With Quote
Old 01-14-2014, 06:43 PM   #4
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,415
Funny shit there
Saw lots of posts in the multi area and did not even own the bike. Who knows
Old 01-14-2014, 06:52 PM   #5
Wonway
KTM Fanboi #2
Oddometer: 428
Don't do it. He'll ban you like he did me
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
2014 KTM 1190 Adventure R
Wonway is offline   Reply With Quote
Old 01-15-2014, 03:41 PM   #6
tmyhog
Oddometer: 58
Is it a must to drill the hole first before the thread tap?
My case has the hole but no threads.
tmyhog is offline   Reply With Quote
Old 01-15-2014, 03:55 PM   #7
Wonway
KTM Fanboi #2
Oddometer: 428
Yes. Otherwise you could crack the case.
Old 01-15-2014, 03:57 PM   #8
youngblood
Oddometer: 357
Yes and mind the warning about maximum depth! Unless you like to oil the floor of the garage!
Taps are meant to be used in a specific diameter hole. Too small and you'll ruin your tap.
2014 KTM Adv 1190R
2007 KTM Adv 990S Dakar 7k miles FOR SALE
2005 KTM 525 SX Supermoto/Rally
2002 KTM LC4 Supermoto (old GumbyDave-mobile)
youngblood is offline   Reply With Quote
Old 01-15-2014, 06:31 PM   #9
kag
Wander Lust
kag's Avatar
Oddometer: 1,736
Originally Posted by vasculopath View Post
Maybe you should read it again. This is the official answer from KTMUSA. There was speculation that the fix may be a through-bolt, or, as a dealer had posted, a new fitment kit altogether.
This is new, not a 'some guy in the shop told me', or 'how i fixed mine'
I would think that someone who presents himself as someone who wants good clean forums wouldn't go flaming around in someone's posts.
Thanks for that! You're a great contributor!
Man, thanks for posting the official fix up. I am not sure I would get a KTM plate but the detail instructions will come in handy when I drill and tap mine.
The 1190 threads seem to attract a lot of these with nothing useful to add:
Old 01-15-2014, 06:57 PM   #10
Wonway
KTM Fanboi #2
Oddometer: 428
Wierd, but my bike is tapped. I have the KTM skid plate here waiting to get installed. Looks like a nice well built piece.
And cut Chuck some slack. He really does like the 1190 and is a good friend of mine. He is directly responsible for me pulling the trigger on my 1190. I promise that he holds no bad feelings about the new bike.
I get tired of seeing multiple posts on the same subject too. I can see his point.
OP, thanks for putting up the official info. That will answer a lot of questions.
Old 01-16-2014, 09:44 AM   #11
fhammond
Oddometer: 245
TLDR Just tap it, not covered under warranty? {Snip}
Thanks for posting this. I noticed the untapped hole when I was fitting the Touratech plate (which doesn't use this mount but instead, uses the peg mounts). Glad it's normal...well, mostly.
fhammond is offline   Reply With Quote
Old 01-16-2014, 10:52 AM   #12
Jimkatoom
Not a nOOb
Jimkatoom's Avatar
Oddometer: 23
Skid plate mounting
Vasculopath-
Thank you for posting this official KTM bulletin. I had read other info on this in other threads, but they didn't have photos posted, nor did they mention (I don't believe) that one had to drill out the hole before tapping, to prevent possible case breakage.
There is a huge amount of assumption of mechanical skills, that goes on in discussions of work on motorcycles, and we all come from different knowledge and experience backgrounds...
I thank you very much for posting this, as I have the KTM plate on order, and due to arrive any day now. As a guy with limited experience wrenching on bikes, I really appreciate this info that is "straight from the horses mouth"
Jim K
Don't hear what I'm not saying,...
Nobody cares how much you know, till they know how much you care...
Jimkatoom is offline   Reply With Quote
Old 01-16-2014, 12:07 PM   #13
vasculopath OP
Oddometer: 368
Glad to Help. Real thanks goes to Santa Fe Motorsports for emailing me the info. 8.5mm drill bits are a bit hard to come by it seems. 8.35mm = 21/64 sae, and 8.7mm = 11/32. I just picked up a 21/64 for $5, and will probably tap it this weekend. I already had the tap. FYI, YMMV, but I have had my plate mounted using the front and left side mounts for a few weeks and it is plenty solid if ,like me, your only concern this time of year is keeping road sand off the bottom of the bike and you're not getting into anything real. I do like Winter riding, but I can't wait for spring...
Old 01-19-2014, 09:50 AM   #14
tmyhog
Oddometer: 58
Did you install the skid plate?
Any tips on how the tap went would be appreciated.My case has the hole drilled but not tapped.A 11/32 bit is too large for the hole.A 21/64 is a tad too small.My guess is it's 8.5mm drilled.I don't have a 8.5mm bit either and probably never need it again.
Old 01-19-2014, 02:09 PM   #15
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,415
Not that it matters
I did not drill. Just used a new tap and lots of oil. Go slow back and fourth to get the chips out. Mine is perfect
Times are GMT -7.   It's 10:59 PM.
