Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 01-21-2014, 09:49 PM   #16
Todd-Squad
See Ya, Bye.
Todd-Squad's Avatar
Oddometer: 775
Why would you expect the factory to reimburse the dealer under warranty to install an accessory? I think the reason it states not warranty, is so a dealer doesn't submit a claim for tapping the hole.
A ride you say? When and Where?
My Favorite Pics
Todd-Squad is offline   Reply With Quote
Old 01-21-2014, 10:18 PM   #17
Wonway
KTM Fanboi #2
Oddometer: 428
Absolutely. The only reason the hole is there is to mount the optional skid plate. I've seen multiple posts about it being an engine mount that is missing a bolt. That is not true.
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
2014 KTM 1190 Adventure R
Wonway is offline   Reply With Quote
Old 02-10-2014, 08:30 AM   #18
vasculopath OP
You're not your bike
vasculopath's Avatar
Oddometer: 368
Update
If you're like me, you probably don't have a Tap wrench as long as described by KTM. I have a small set of Taps, but thankfully rarely use them. Don't buy this extension from amazon: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Piece of Junk:
This one works, barely reaches, picked it up at local hardware store.
vasculopath screwed with this post 02-10-2014 at 11:04 AM
vasculopath is offline   Reply With Quote
Old 02-10-2014, 08:35 AM   #19
motocityktm
Oddometer: 143
Some of them are already tapped and some will need it...ask your dealer, it is a 30 sec fix, we have been just doing the fix before the bikes leave.
Originally Posted by Wonway View Post
Wierd, but my bike is tapped. I have the KTM skid plate here waiting to get installed. Looks like a nice well built piece.
And cut Chuck some slack. He really does like the 1190 and is a good friend of mine. He is directly responsible for me pulling the trigger on my 1190. I promise that he holds no bad feelings about the new bike.
I get tired of seeing multiple posts on the same subject too. I can see his point.
OP, thanks for putting up the official info. That will answer a lot of questions.
motocityktm is offline   Reply With Quote
Old 03-27-2014, 10:48 AM   #20
dewaynehasty
Oddometer: 114
How to mount the KTM skid plate
I couldn't find a video out there on mounting the KTM 1190 Adventure OEM skid plate so I made one. As usual my videos suck but I hope they will help someone.
https://www.youtube.com/watch?v=Xgc7yTX-EeE
FYI I mounted it without tapping the hole. I'll wait and let the shop do that on my next visit. The three points still make for a strong installation for now.
dewaynehasty is offline   Reply With Quote
Old 03-27-2014, 12:25 PM   #21
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,463
That doesn't sound like a good idea. If you're bashing the bottom hard enough to warrant the skid plate, the three legged mount is gonna mess it up.
If it's a Starbucks Mod...then on ya go.
For Sale: 2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 03-27-2014, 12:31 PM   #22
Vitruvian Mike
Vitruvian Mike's Avatar
Oddometer: 151
The dealer didn't even know it when they were prepping mine, until I pointed it out. The tapped and bolted it free of charge, on the spot.
I pointed it out to another dealer in Arkansas, and they were pretty surprised. He thanked me, and let me know he'd pass it on to the rest of their wrenches.
Fairly easy to do, but BS if the dealer won't cover it.
VM
2005 1150 GSA
2010 F800 GS
2011 F650 GS
Vitruvian Mike is offline   Reply With Quote
Old 03-27-2014, 01:26 PM   #23
Barekat
Looking to get dirty
Oddometer: 633
Isn't the bash plate intended to protect the engine casing? ... and the factory bash plate mounts to the casing... That sound counter intuitive to me.
2015 KTM 1290 SA
Barekat is offline   Reply With Quote
Old 03-27-2014, 03:05 PM   #24
jimmex
Guero con moto
jimmex's Avatar
Oddometer: 2,827
Sounds like a terrible idea to me.
Guero from Texas
COHVCO
AMA
PAPA
SJTR
jimmex is offline   Reply With Quote
Old 03-27-2014, 03:05 PM   #25
Vitruvian Mike
Oddometer: 151
Hey Barekat, lots of bikes have gone to frame systens that incorporate the engine as part of the structural design. Nearly all of these bikes use either some form of direct or indirect mount points to the engine case. Seemed counterintuitive to me a while back too.
VM
Sent from my SCH-I545 using Tapatalk
2005 1150 GSA
2010 F800 GS
2011 F650 GS
Old 03-27-2014, 05:17 PM   #26
dewaynehasty
Oddometer: 114
thread lock
Hey does anyone recommend using thread lock on the skid plate bolts?
Old 03-30-2014, 05:44 PM   #27
dewaynehasty
Oddometer: 114
thread lock
Yes do use thread lock. I lost one of the screws already :(
dewaynehasty screwed with this post 03-31-2014 at 03:52 PM
Old 03-30-2014, 06:03 PM   #28
Wonway
KTM Fanboi #2
Oddometer: 428
It gets mounted to the frame and the engine.
Old 06-03-2014, 11:05 AM   #29
red activist
Oddometer: 4
I'm having trouble getting the nut out on the left side of the engine casing. Any tips? Did you heat it up to weaken the locktite or just used alot of force on it? I don't want to break the bolt but I also don't want to go back to the shop before it needs it's first servicing since it's not really close to my home...
red activist is offline   Reply With Quote
Old 06-03-2014, 08:29 PM   #30
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,436
I just installed my KTM skid plate this evening. Tapping the hole was the easiest part. My front engine bolts came out fine, but I used a 3/8 drive Torx socket on a regular ratchet. The 2 issues I had, which made this whole deal take an extra hour:
1. I started with the bike on the center stand, but the CS interfered with the left rear bracket. It wouldn't let the bracket swing forward far enough to line up the holes in the rear of the a skid plate (even though it's obviously shaped to clear the CS when it's up). Finally I put the bike on the side stand, the bracket lined right up, and now there is no inference with the center stand. I finished in the dark so I can't tell if there is any interference now, but the CS seems to be working right.
2. When I pulled out the front engine bolts, I had trouble getting both skid plate / engine mount bolts in. It looked like the engine was dropping down just enough to make it hard to get one or the other bolts started. I used a bottle jack (carefully) to exert a little up pressure on the motor, but eventually put the original bolts back in to line it up again. I think I farted around with these two bolts for over an hour. Maybe my crash bars are a little "crooked" IDK?
I did use Locktite, and I think I can mill the left side to allow removal of my oil screens with out taking the whole plate off at oil change time.
PineyMountainRacing is offline   Reply With Quote
Times are GMT -7.   It's 08:36 AM.
