Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-03-2014, 08:33 PM   #31
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,358
Originally Posted by red activist View Post
I'm having trouble getting the nut out on the left side of the engine casing. Any tips? Did you heat it up to weaken the locktite or just used alot of force on it? I don't want to break the bolt but I also don't want to go back to the shop before it needs it's first servicing since it's not really close to my home...
You mean the front engine mount bolt? I used a regular ratchet and Torx socket, I doubt I could have gotten it with the ktm kit tools.
PineyMountainRacing is offline   Reply With Quote
Old 06-03-2014, 09:33 PM   #32
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,508
FYI: With the Power Parts skid plate make sure you use anti-seize on the small skid plate bolts. Aluminum skid plate w/ steel bolts will cause galvanic corrosion and freeze lock the bolts in place.
Old 06-04-2014, 10:38 AM   #33
red activist
Oddometer: 4
Yeah a different ratchet did the job without any trouble! Thanks!
red activist is offline   Reply With Quote
Old 06-04-2014, 10:46 AM   #34
NoSpam
Oddometer: 168
This is some big-brain stuff, YellowPig! Nicely done and thank you!
NoSpam is offline   Reply With Quote
Old 06-08-2014, 08:03 AM   #35
like2lean
Oddometer: 33
I couldn't find a 8.5 mm bit either, but the 21/64 is 8.35 mm and jiggles a bit so I ran the tap right in no problem at all. I'm purdy sure the hole must have been drilled already as the tap felt perfect.
like2lean is offline   Reply With Quote
Times are GMT -7.   It's 02:15 AM.
