Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 01-20-2014, 09:03 AM   #16
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,155
May be in compresión but how abput extensión ?
09´ KTM 530 EXC
07´ XR650R
alfaris is offline   Reply With Quote
Old 01-20-2014, 12:38 PM   #17
mousitsas
mousitsas's Avatar
Oddometer: 2,917
Originally Posted by bemiiten View Post
If a increased spring rate matches the load better, wouldn't the standard damping be greatly improved by virtue of it having to do less work to control suspension movement?
With a stiffer spring it will have to do more work, not less, which it cannot. Think in terms of frequency rather than force.
Old 01-20-2014, 01:09 PM   #18
Black Hills
Oddometer: 1,293
A heavier spring returns to extension with more force than a lighter one so more rebound damping is required.
Ride a bike set up by someone that knows what they are doing and you will never ride a stock suspension again.
Black Hills is offline   Reply With Quote
Old 01-21-2014, 06:04 PM   #19
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,970
Say the stock spring rate is ideal for a 175lb rider. If the rider weighs 225, the compression damping would be less effective resisting suspension compression because the load is too great for the spring. The opposite would be true for rebound. The weak spring has less energy to rebound. When the spring rate matches the load, The dampning no longer has to compensate for the wrong spring, and will be more effective controlling wheel movement.
I'm not saying riders cant benefit from damping tuned to meet their riding style, and the factory setup is a compromise at best. But the damping should become more effective with the right springs.
bemiiten is offline   Reply With Quote
Old 01-21-2014, 06:25 PM   #20
Black Hills
Oddometer: 1,293
Hasn't been my experience, but if it works for you stick with it.
Old 01-21-2014, 06:44 PM   #21
chief_lee_visceral
chief_lee_visceral's Avatar
Oddometer: 406
Konflict, if we are local to Redmond can we make an full setup appointment?
-= Never put your finger where you wouldn't put your face =-.
chief_lee_visceral is offline   Reply With Quote
Old 01-22-2014, 10:52 PM   #22
mousitsas
mousitsas's Avatar
Oddometer: 2,917
You are viewing suspension as if the spring is doing the work and the dampening is there to fix errors, but in reality the two have to work together to provide a certain ratio of spring vs hydraulic force throughout the envelop of wheel movement. Things are getting a bit complex since spring force depends on the state of compression while hydraulic force depends on the speed of compression.
For example, if you put stiffer springs on a given suspension valving, you will need to stiffen up the compression dampening too, because now the forks will compress at a lower speed, reducing the hydraulic force during compression, thus throwing away the force balance between spring and dampening.
Not an expert, but this is what I think.
Old 02-02-2014, 12:47 PM   #23
bemiiten
bemiiten's Avatar
Oddometer: 4,970
You have a good point but fail to take into account that the spring rate is changed to match the riders weight. That should put the suspension 'speed' right on target.
Old 02-03-2014, 12:57 AM   #24
mousitsas
mousitsas's Avatar
Oddometer: 2,917
You have a good point but you view suspension as a spring tied to the ground on one end with a weight on the other plus some dampening. Well this is not the case, since both ends of the spring are free to move (bike and wheel) depending on the circumstances. And while by putting a stiffer spring you address one end of the story, you don;t address the other (wheel) where nothing has really changed in its mass, however, you connect it with the rest of the bike by a stiffer spring.
mousitsas screwed with this post 02-03-2014 at 01:07 AM
Old 02-03-2014, 05:00 AM   #25
bemiiten
bemiiten's Avatar
Oddometer: 4,970
The wheel and it's componets are commonly known as unsprung weight.
bemiiten screwed with this post 02-03-2014 at 10:55 AM
Old 03-11-2014, 02:24 PM   #26
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,155
Hi konflict,
Did you advance on improving the travel on 1190 adv r forks and shock ?
Thank you
09´ KTM 530 EXC
07´ XR650R
Old 03-11-2014, 09:33 PM   #27
Konflict Motorsports OP
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 861
Originally Posted by alfaris View Post
Hi konflict,
Thank you
Yes, as a matter of fact we are about 2-3 weeks out from offering the service publicly. We have a few test bikes around the country running them at this time (different heights) and will make the decision with what the final option will be. I will post it in the vendor forum once it is live.
Thank you for your interest!
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 03-12-2014, 12:47 AM   #28
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,146
One thing I have been thinking about.. do both forks have both damping circuits for compression and rebound with just adjustment for one or is there really just one circuit per leg?
Verstuurd vanaf mijn LG-D802 met Tapatalk
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 03-12-2014, 02:12 AM   #29
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,155
Thank you very much for the information and for your efforts on this issue.
Sure I am absolutely interested on this improvement, I am missing mi 03 950adv s 265mm travel, the 1190 R 220mm travel looks short for me.
Best regards
09´ KTM 530 EXC
07´ XR650R
alfaris screwed with this post 03-12-2014 at 04:52 PM
Old 04-14-2014, 02:02 PM   #30
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,155
Hi konflict ,
looks like the 2-3 weeks time for the release of the suspension kits has expired.
Any news now ? I am crazy about this possibility of increasing 1190 R travel....
Thank you
09´ KTM 530 EXC
07´ XR650R
Times are GMT -7.   It's 01:58 PM.
