Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 01-17-2014, 05:40 PM   #16
DesertTortoise
Freedom Fighter
DesertTortoise's Avatar
Oddometer: 153
In the class they called it "all four down"
straighten the bike first then clutch in, downshifting to first, front and rear brake progressively
DesertTortoise is offline   Reply With Quote
Old 01-17-2014, 07:36 PM   #17
390beretta OP
Oddometer: 1,218
Originally Posted by Pantah View Post
When I need to stop fast, I almost always end up with the clutch pulled and the bike it too high a gear. But at least she is running. Thankfully, I don't have many panic stops and most of those are on dirt. I have to agree that usually the priority is to simply get stopped or slowed enough.
Pantah, glad you're here; almost sent you a pm asking you to chime in. I don't have a lot of panic stops either. I like to think it's because of my awareness and riding style. But, who knows?
I came into this world kicking, crying and covered in someone else's blood. I have no problem leaving the same way.
390beretta is offline   Reply With Quote
Old 01-17-2014, 08:07 PM   #18
Wraith Rider
Oddometer: 1,604
The rear brake is powerful enough not to need engine braking. Also the braking power is more easily controlled when the engine doesn't interfere, especially if it's nearly stalling.
I was told in riding school to pull the clutch but not shift down because it's better to focus only on the braking. I think that might be good advice for beginners, but never liked it for myself.
Wraith Rider is offline   Reply With Quote
Old 01-17-2014, 10:02 PM   #19
tkent02
Oddometer: 2,908
Braking hard from 80 mph in traffic is different from braking hard from 20mph in a parking lot, just as what the MSF class teaches is different from what keeps you alive on the road.
Think about it people.
Do you want to be in fifth or sixth gear at a standstill with fast and oblivious traffic coming up your ass?? Do you want to think about throttle control and finger - toe coordination while you are trying your hardest to stop?
There is a lot to this question.
tkent02 is offline   Reply With Quote
Old 01-18-2014, 03:33 AM   #20
JohnnyWaffles
Oddometer: 239
I took the class in June and like others said, you do lose points for not pulling in the clutch and also down shifting during emergency stops.
2013 KTM 990 Adventure Baja Edition
Originally Posted by Beefeater Steve
The KTM is the kind of bike you take behind the middle school and get pregnant. It's the kind of bike that, from the moment you light the fire, you know is downright nasty and makes you want to meet in the Burger King bathroom and lick its butthole.
JohnnyWaffles is offline   Reply With Quote
Old 01-18-2014, 03:45 AM   #21
Dexter2811
Dexter2811's Avatar
Oddometer: 299
Pull the clutch! You want to stop in the shortest distance, if you don't pull the clutch, the engine will keep the transmission rotating, any rotation will be translated into movement, you want to stop, not to move.
That's what they told me in a secure driving class I took (we don't have nothing similar to MSF down here)
Sent from my LG-E610 using Tapatalk
2010 NX4 Falcon, 440cc Wiseco Big Bore, Stage II Hotcams, XR400R clutch, XR600 40mm Mikuni carb, MX handlebar (Wirtz), Custom exhaust.
Dexter2811 is offline   Reply With Quote
Old 01-18-2014, 03:52 AM   #22
scootrboi
scootrboi's Avatar
Oddometer: 1,690
Downshifting and engine braking must be a drum brake thing.
42 years on a Heinkel Tourist
scootrboi is offline   Reply With Quote
Old 01-18-2014, 03:57 AM   #23
Dexter2811
Dexter2811's Avatar
Oddometer: 299
It's still forward movement... think about it.
Old 01-18-2014, 05:46 AM   #24
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,630
Current MSF doctrine is to down shift to 1st while emergency braking. The reason is to be able to rapidly move if the vehicle behind you can't brake as quickly. Every time I try to emergency brake without pulling in the clutch - the engine dies.
How do you prevent the engine from dieing if the clutch is not pulled in during an emergency stop?
Stan_R80/7 is offline   Reply With Quote
Old 01-18-2014, 06:04 AM   #25
390beretta OP
Oddometer: 1,218
Well, good question. I guess I see a difference between an "emergency stop" and for lack of a better term a "quick stop". For the sake of an explanation, in my mind, a true emergency stop almost assumes you're gonna hit something unless you get very lucky. A "quick stop" assumes that, provided you have the skill, you've got a good chance of not hitting something. Of course either kind of stop can be caused by the same incident....someone turning left in front of you, pulling out from a side street etc. The difference is measured in split seconds, the rider's awareness, anticipation etc. In a true emergency stop, I doubt that I'd have the presence of mind to shift down, worry about killing the engine, etc. Hope that makes sense.
Old 01-18-2014, 06:12 AM   #26
orangebear
orangebear's Avatar
Oddometer: 1,279
my i did my bike test in the uk in 2007 i was told to go hard on the brakes more front than rear and only pull the clutch in when then the bike is about to cut out then change in to 1st when you are stopped. you fail the test if you pull the clutch in when the brakes are hard on as you will be costing and not having engine braking.
suzuki gsxr 600 srad sound fun bike
bmw r100gs i sold as it be came to unreliable.
road legal stomp pitbike sold
Klr 650 the worst ever made
Honda xl125rc powered by a cg125 block fun wee bike
orangebear is offline   Reply With Quote
Old 01-18-2014, 06:22 AM   #27
ibafran
villagidiot
Oddometer: 1,289
This. The key word in the OP is 'emergency'. The rider has all of his/her focus on making the stop and avoiding the source of predicted initial impact. Disconnecting the engine allows the proper braking feel to keep the tires doing their best. A connected stalled engine does not allow proper modulation of the rear brake. Nothing quite like getting off the brake of a sliding rear wheel only to have the engine fire with half throttle in a tall gear.
The dowside of this teaching method for noobs is that they tend to have a more severe panic reaction tensing up and not being able to modulate the brakes and steering much less think of options while in the moment.
Even exerienced riders can get so 'caught out' in an emergency stop that they execute it poorly due to lack of practice. I can't remember when I had to make a full-on 100% emergency stop? My riding habits are of a sort to keep me from ever having to execute that again. Now that I have typed that, watch me come around a curve and hit a moose due to being so stunned by the sight that I will have completely forgotten how to ride and years of making great habits totally fail me. Sigh.
BTW, many emergency stops for experienced riders do not end in a complete standstill. Some riders are looking for 'outs' and 'safety holes' while braking hard. Commiting, or having to commite, to nothing but a full-on braking is a pretty good sign that one is still a noob in the situational awareness area of riding. And that does not excuse the experienced rider from further regular braking practice.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 01-18-2014, 06:33 AM   #28
judobiker
judobiker's Avatar
Oddometer: 488
Growing up on dirt, it has become instinct to pull the clutch. 2 stroke engines stall easier and the lurching, stalling bike can send you into a tree. It also stinks having to kick it back to life after a hard stop.
A 1 liter 4 stroke may be a little harder to stall, but its also harder to stop and the engaged engine can push you forward with more force. I treat it the same as I would a car with a manual transmission.
"How narrow and difficult the road that leads to life, and few find it" (Matt 7:14)
'05 Bandit 1200, '01 DRZ400, '95DR125, '01 KDX200
judobiker is offline   Reply With Quote
Old 01-18-2014, 01:12 PM   #29
dddd
Oddometer: 541
Originally Posted by 390beretta View Post
However, in none of the classes was it mentioned that one should also be shifting down during the braking process.??
in a few hundreds stop lights or intersections, clutch-in & downshifting will be natural to you. dont worry, your hands and foot will do it before you realize... there is no hurry to teach it, every rider figures it out after stalling a few times, even during the course!
so, during emergency, your natural reaction will be to clutch-in and downshift.
Just write it down in your phone in a reminder 1-2 years from now, you'll see what you learned then...
dddd is offline   Reply With Quote
Old 01-18-2014, 01:27 PM   #30
390beretta OP
Oddometer: 1,218
Uh, thanks; but did you read the part where I said I've been riding for many years?
Times are GMT -7.   It's 10:48 PM.
