Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 01-17-2014, 08:50 PM   #1
fast4d OP
Oddometer: 2,333
find TDC without cams installed
this is on a 1190 which has chain driven cams. unlike the cam/chain drive of the 990
I am trying to reinstall the cams. ALL four were removed to troubleshoot some issues with the shortblock.
how can I tell if the piston is on the compression stroke near TDC since it only fires every other stroke?
or does it not matter on the first cylinder as long as piston is at top?
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d screwed with this post 01-17-2014 at 08:58 PM
fast4d is offline   Reply With Quote
Old 01-17-2014, 09:12 PM   #2
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,983
Ding, Ding, Ding, we have a winner!!!
The ignition fires on every stroke, so the cams determine if it is on compression or overlap. Do the front one first. Then turn the crank forward (about 3/4 turn) until the rear is on TDC.
"Son, you can't do both"
Old 01-17-2014, 11:41 PM   #3
Katoom72
Katoom72's Avatar
Oddometer: 861
according to manual: Set the rear to TDC and check for the position notch (locking bolt notch) on the crankshaft. If the notch is visible the rear cylinder is at the right mark to put the cams in.
The markings of the crankshaft and idler gear should line-up as well.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is online now   Reply With Quote
Times are GMT -7.   It's 05:54 PM.
