Old 01-26-2014, 04:44 AM   #166
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Originally Posted by DAKEZ View Post
Said the smart guy that takes the truck.
Fixed it for ya Buttercup.
Old 01-26-2014, 04:51 AM   #167
tkent02
Oddometer: 2,779
Originally Posted by JohnCW View Post
Different for some small bore engine revving its head of going down the freeway.
Am I going with the flow here, or in the opposite direction????
No matter how high or how long you rev it, the heads don't actually come off.
They just run and run. Make a lot of power. Have nice gear spacing. Get good fuel economy. Last a long time.
tkent02 is offline   Reply With Quote
Old 01-26-2014, 07:21 AM   #168
JohnCW
Oddometer: 1,367
You're correct that "No matter how high or how long you rev it, the heads don't actually come off". You'll most likely drop a valve which will punch a hole in the top of the piston. That, or throw a rod, are the most common cause of engine failures you'll see on a race track.
They don't just run and run. In fact high-revving motorcycle engines have quite a short life before compression and performance start to drop. The high-revving is hard on rings and bores and as wear is gradual it goes unnoticed. The bike will still run, but nowhere like it did when new. The harder you ride it, the shorted the time till performance starts to deteriorate. About 50 thousand kilometers and a bike is ready for a top end rebuild. A petrol car engine 300,000?, a diesel 500,000+?
A race engine may be rebuilt after every outing, that's how much toll a hard life takes on an engine.
JohnCW screwed with this post 01-26-2014 at 03:16 PM
JohnCW is offline   Reply With Quote
Old 01-26-2014, 07:52 AM   #169
henshao
Bained
henshao's Avatar
Oddometer: 610
Piston speed is everything.
henshao is offline   Reply With Quote
Old 01-26-2014, 08:02 AM   #170
Tripped1
Oddometer: 8,064
Yeah, that is why oversquare is a thing.
I would wager my 675 turning 10,000 and a Harley 103 turning 3100 have about the same piston velocity.
Tripped1 is offline   Reply With Quote
Old 01-26-2014, 08:21 AM   #171
farmerstu
Oddometer: 527
piston speed is not quite everything,have to consider the weight of the reciprocating components when they change direction.
farmerstu is offline   Reply With Quote
Old 01-26-2014, 08:28 AM   #172
ragtoplvr
Oddometer: 6,533
Yes, container ship engines operate at about 100 RPM but with a stroke measured in feet, the piston speed is significant. BTW on all of them the lowest fuel consumption is at about 80% load. There are some low revs for you.
Roc
ragtoplvr is online now   Reply With Quote
Old 01-26-2014, 08:36 AM   #173
Tripped1
Oddometer: 8,064
Roc
Well yeah when you can walk around in the crank gallery lol
Old 01-26-2014, 08:50 AM   #174
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Roc
Ahh but the real question arises. Is a container ship more aerodynamic then a freight train?
Old 01-26-2014, 09:15 AM   #175
Tripped1
Oddometer: 8,064
At 12 knots, who cares
Old 01-26-2014, 11:08 AM   #176
SteelJM1
Undercover KTM rider
SteelJM1's Avatar
Oddometer: 1,734
No, but the ships usually have a tailwind. Trade routes and such. Theres even ideas to attach retractable sails to them to further improve efficiency
Sent from my Tandy 1000 mobile using DOS
SteelJM1 is offline   Reply With Quote
Old 01-26-2014, 12:43 PM   #177
randyo
randyo's Avatar
Oddometer: 1,779
what's below water counts more, hull design has improved quite a bit
modern submarines can travel faster submerged
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is offline   Reply With Quote
Old 01-26-2014, 03:10 PM   #178
Tripped1
Oddometer: 8,064
They also have nuclear power plants.
......yet the carrier is the fastest ship in the fleet....all hundred,-thousand tons of it
Old 01-26-2014, 04:00 PM   #179
aterry1067
aterry1067's Avatar
Oddometer: 286
Uncomfortable? Dude, I can sleep on an airplane in coach for 8 hours straight and wake up refreshed. My Tundra is 10 times more comfortable then an airplane. And sleeping while I'm riding my motocycle is pretty damn dangerous.
There are no such thing as better, long lasting tires. There's either long lasting which is relative to who's riding on them as just an example I get about 2500 miles out of a Pilot Road 3 on a 55 HP V-Strom, or there's better.
If you are getting 2500 miles out of a set of PR3's on a V-strom, then YOU are completely doing it wrong; you have chosen the wrong tool for the job. You should stick with you Yamakazuki 1500 super sport show-mobile.
aterry1067 screwed with this post 01-27-2014 at 05:08 PM
aterry1067 is offline   Reply With Quote
Old 01-26-2014, 04:15 PM   #180
Kommando
Kommando's Avatar
Oddometer: 7,389
THAN, Muffinbutt. You're gonna wake Klay up.
Kommando is offline   Reply With Quote
Times are GMT -7.   It's 07:46 AM.
