Old 06-02-2014, 06:43 PM   #751
dvfisher
Oddometer: 46
Originally Posted by kelsow View Post
Excellent!
I'm looking forward to the installation in my f800.
I'll try to take some pix as well.
Please do, I'm waiting for confirmation that it's fits before ordering one for my bike.
Dave
Dave
2012 BMW F650GS (twin)
Canadian Military Engineer
dvfisher is offline   Reply With Quote
Old 06-02-2014, 10:36 PM   #752
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,436
Originally Posted by ErikMotoMan View Post
Can't wait to get a set from you for my 2003 K 1200 GT, as you can see even the 'super plasma ultra deluxe go to the moon' $ 29,95 Sylvania H7 is a joke. Clearly, the Clearwater lights definitely are the overkill bomb, but not everyone is going to spring that kind of money, so am hoping you bulbs are as good as we would all like them to be!
Those are bright, but its the other view that counts.
Please don't think this or any headlight bulb will ever compete with a set of good LED Aux lights. Its just not so. You will see a very noticeable difference in conspicuity and an improvement in overall performance.
Now for Aux lights, and all out performance, our long range series at half the price of the Clearwaters, will put them to shame
How much is spent is not a reflection of performance or quality
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 06-02-2014, 11:15 PM   #753
Off Road Ryder OP
Oddometer: 2,436
Gs 800 2013
To be clear this is only a headlight bucket, I have not installed one on the bike yet.
The base plate on the LED bulb removes by pushing down slightly and rotating.
Remove the covers and factory bulbs, attach the base plate with the stock clips
On the small side of the headlight bucket, pull the factory connector out threw the hole, Insert the LED bulb and twist to lock the cams.
Plug in the terminals, ground (green) to the bikes Brown, and the Blue to the Other socket.
There is a circuit board half way down the cord, use the attached Velcro or zip tie this to keep it from flopping around.
On the Large side do the same thing but tuck the board and terminals inside the headlight surround. Install the factory cover, we recommend adding a few holes in the back of this cover to allow a little air flow.
This one was premodified for a HID.
1-800-624-0278
Old 06-02-2014, 11:42 PM   #754
rayycc1
Oddometer: 5
Ulysses fitment?
Has anyone tried these on A Ulysses yet?
rayycc1 is offline   Reply With Quote
Old 06-03-2014, 12:56 AM   #755
doggitter
Oddometer: 1,939
So I also checked and found the DR350 uses the same bulb as the DR650, that has already been tried.
So many rides, so little time.
Loren, somewhere on a DR350SE
doggitter is offline   Reply With Quote
Old 06-03-2014, 08:30 AM   #756
Off Road Ryder OP
Oddometer: 2,436
H4 correct
1-800-624-0278
Old 06-03-2014, 01:05 PM   #757
Off Road Ryder OP
Oddometer: 2,436
As you guys are receiving your bulbs I will be on a 1500 mile plus dirt ride and most likely be out of service until early next week.
Should any issues arise you can contact Sandra or I will return at the latest next Wednesday.
I think we had our largest shipping volume in Cyclops history yesterday.
Thank You very much, your business is more than appreciated
As some might notice there was a small design change on the H4 to allow for a little more fit room. We gained about a half an inch in depth clearance, That mod was mainly for the KTM dirt bikes.
Im very happy with the outcome.
1-800-624-0278
Old 06-04-2014, 07:24 AM   #758
Navy Chief
Navy Chief's Avatar
Oddometer: 1,544
My H7 is marked as out for delivery!
New toys when I get home!
Navy Chief is offline   Reply With Quote
Old 06-04-2014, 07:24 AM   #759
Off Road Ryder OP
Oddometer: 2,436
For you riders getting the H7 remember the base comes off with a cam action, push down and twist. You can see the cam by looking down on the base plate.
Most should be arriving to you today.
Ill try to check in on this thread once I get some cell service on Friday.
Thank you!!!
1-800-624-0278
Old 06-04-2014, 02:54 PM   #760
Navy Chief
Navy Chief's Avatar
Oddometer: 1,544
H7's arrived today, these look very well made. I am not sure that these are going to work for my application unfortunately. I test fit one of them on my 08 KLR and the fan housing hits the headlamp housing before the light is seated all the way. There is just not enough depth between the flange on the bulb and the fan housing.
I need to decide how far I am willing to modify my headlamp housing to make these fit. It will require grinding approximately 1.5-2.0mm off of the headlight to make it fit. This will have the consequence of making going back to a halogen impossible as it will grind off all the stock lamp retina hardware. Not a problem providing that these are available for the rest of my bikes life, or that they never fail.....
The other possibility is to make a spacer to move the entire led flange back the 2mm to make it fit, I don't think this is a good idea because it will change the relationship between the led emiter and the reflector changing the light output and pattern....
Time to think, any input from the crowd?
Old 06-04-2014, 04:31 PM   #761
Chad05gsa
Oddometer: 179
Crap! mine just arrived today. Also was planning on fitting them to a 08 klr. I'm not sure I'm down with the modified headlight housing either? Keep us posted if you get it to work somehow, I won't be able to tear into it until the weekend.
samsung galaxy note 2
Chad05gsa is offline   Reply With Quote
Old 06-04-2014, 06:01 PM   #762
thesprocket26
Oddometer: 13
Received and they look great, thank you. I'll be ordering the h4 soon. Here is a pic with halogen in the top left, LED top right, HID center
2001 Aprilia Futura, hey it goes off road sometimes!
thesprocket26 is offline   Reply With Quote
Old 06-04-2014, 08:16 PM   #763
WindSailor
WindSailor's Avatar
Oddometer: 648
Navy or Chad
If you don't want the H7, I am interested to see if it will fit in my GSA... PM me... to keep me up to date on what you guys decide. I only want one...
Sent from my Samsung Note 3
WindSailor screwed with this post 06-04-2014 at 10:09 PM
WindSailor is offline   Reply With Quote
Old 06-04-2014, 08:32 PM   #764
JDE
JDE's Avatar
Oddometer: 6
Mine arrived today!
JDE is offline   Reply With Quote
Old 06-04-2014, 08:57 PM   #765
GlassAnkles
Chip to Queso Ratio
GlassAnkles's Avatar
Oddometer: 1,870
Hack it navy chad, its an 08 KLR so a used "like new" headlight assembly is going to run you $125...think about that price 4 years from now when you want to go back
GlassAnkles is online now   Reply With Quote
Times are GMT -7.   It's 11:34 PM.
