Old 06-16-2014, 05:07 PM   #841
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,527
Originally Posted by EL HUX View Post
Hi Off Road Ryder, is anyone selling these bulbs of yours south of the border (Mexico)?
Not Yet, but we are working on distribution. Thanks for asking
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 06-17-2014, 06:48 AM   #842
Jbone11 11
Jbone11 11's Avatar
Oddometer: 711
Just got my H4 for the 990 the other day and installed...or rather, tried to install last night.
Question, will I be able to get the rubber boot back on or is it meant to be left open at the back? We ride through a lot of water round these parts and that part of the bike definitely gets wet from time to time...has this been an issue for anyone?
At this point, unless Im missing something here, Im pulling the connectors out of the plastic plug housing and heat shrinking each wire individually in hopes of being able to get that rubber boot back on.
Does anyon have pics of the H4 installed on the 990 from the back? I'd like to see what the end result is supposed to look like.
Other than that, its BRIGHT! My jerk buddy flipped the switch while was looking right at the thing....couldn't see straight for about 5-10 minutes!
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
2003 Honda Hornet 600 (SOLD)
1969 BSA Royal Star - Let the Resurrection Begin!
Jbone11 11 is offline   Reply With Quote
Old 06-17-2014, 10:01 AM   #843
Off Road Ryder OP
Oddometer: 2,527
Water will not affect the bulb. If you need to remove the terminal holder the terminals come out of the H4 retainer very easily by using a small screwdriver or pick in the slot next to the terminal.
Push the tang on the terminal and pull back on the wire, there would be no need to reshrink wrap anything.
You should be able to get the boot back on, although you may need to slightly modify it if you don't want to remove the terminals from the retainer in order to fit them threw the hole. A slice in the boot at the wire inlet will take care of that.
I fit the cover back on intact and unmodified on my 950 headlight, same as 990.
The R2 (latest) version is slightly smaller than the original that this thread started with.
1-800-624-0278
Old 06-17-2014, 02:27 PM   #844
Off Road Ryder OP
Oddometer: 2,527
We temporarily are out of stock again on the H4's
nearly 500 units gone in two weeks
H7's are in stock
We will be shipping again next week, however we padded the date on the site a bit just in case there are any issues.
Thanks to all you for helping make this product a success!
1-800-624-0278
Old 06-17-2014, 09:43 PM   #845
phlazm
Oddometer: 10
R1100r
Anyone have any experience with this in an R1100R? Fit right in or any adjusting/modding necessary?
phlazm is offline   Reply With Quote
Old 06-18-2014, 02:06 AM   #846
Baroquenride
Oddometer: 809
Originally Posted by baddrapp View Post
Are you going to have a 9007?
Originally Posted by Off Road Ryder View Post
Yes however, it will be a different bulb than the H4
No time table as of yet.
I was swapping out my Trail Tech X2 for a new/original Husky headlight which is capable of running a 9007 halogen bulb, but I'd like to try one of these LED bulbs. I'll be anticipating this when you do get it out.
2000 Honda VFR800, 2008 Husqvarna TE-610
Baroquenride is offline   Reply With Quote
Old 06-18-2014, 06:41 AM   #847
Jbone11 11
Jbone11 11's Avatar
Oddometer: 711
Thanks Ryder, I managed to get everything on there and fitting well. Looking forward to putting it through its paces this weekend on the Dacre Rally
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
Old 06-18-2014, 07:32 AM   #848
Navy Chief
Navy Chief's Avatar
Oddometer: 1,544
Any luck tracking down an 08+ KLR to play with? I have not gotten around to grinding down my housing for the install yet and am still hoping for an alternative....
Navy Chief is offline   Reply With Quote
Old 06-18-2014, 08:25 AM   #849
GlassAnkles
Chip to Queso Ratio
GlassAnkles's Avatar
Oddometer: 1,938
Not in china If we do offer them I will give full disclosure, right now its irrelevant.
are you sure there not made in china by a company called NAO?
GlassAnkles is offline   Reply With Quote
Old 06-18-2014, 09:41 AM   #850
Off Road Ryder OP
Oddometer: 2,527
Ya Im pretty sure, These are made in Korea under our specific specifications and QA processes.
We will see all types of led bulbs that may or may not look like what we offer, just like in LED aux lights, just because it looks like a duck does not mean its a duck.
Clearly quality, light output and customer service is not for you.
Please go troll elsewhere.
Here is a great example of why many companies shy away from forum interaction.
1-800-624-0278
Off Road Ryder screwed with this post 06-18-2014 at 10:40 AM
Old 06-18-2014, 09:44 AM   #851
Off Road Ryder OP
Oddometer: 2,527
We are looking at a new design that should have a bit more space between the fan shroud and base plate, specifically for the KLR
We are also attempting to find a local customer and see if we can make a adaptor plate for the existing bulb in the KLR
1-800-624-0278
Old 06-18-2014, 10:37 AM   #852
Chad05gsa
Oddometer: 184
I'll call dibs on a test specimen in needed
samsung galaxy note 2
Chad05gsa is online now   Reply With Quote
Old 06-18-2014, 11:09 AM   #853
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,562
Used my bulb ALOT this past week on tour.
Lit up the night when needed!
I throw on the high beam when in traffic...drivers notice.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 06-18-2014, 04:00 PM   #854
Off Road Ryder OP
Oddometer: 2,527
Thanks.
The H11 and KLR H7 are priority right now, 9007 is coming but still a ways off.
Most Husky headlights that I am aware of use the Ba20 bulb or H4
we do have a base that can work with either.
1-800-624-0278
Old 06-18-2014, 04:03 PM   #855
Off Road Ryder OP
Oddometer: 2,527
Excellent, Have a blast at the Rally and let us know what you think.
1-800-624-0278
Times are GMT -7.   It's 06:29 AM.
