Old 06-18-2014, 08:07 PM   #856
Igotthis
So Close...
Oddometer: 60
If your looking for a local 1190R I'd be happy to volunteer. I'm about an hour north of you and have Fridays off. I'd be welling to drop the bike by and drink your coffee.
Igotthis screwed with this post 06-18-2014 at 08:32 PM
Igotthis is offline   Reply With Quote
Old 06-19-2014, 01:33 AM   #857
Baroquenride
Oddometer: 824
Originally Posted by Off Road Ryder View Post
Thanks.
The H11 and KLR H7 are priority right now, 9007 is coming but still a ways off.
Most Husky headlights that I am aware of use the Ba20 bulb or H4
we do have a base that can work with either.
I'm using a 9007 bulb in the lamp in place of the Ba20 bulb/socket so that I can use the existing pins and not convert the pin style to the wider H4 style.
2000 Honda VFR800, 2008 Husqvarna TE-610
Baroquenride is offline   Reply With Quote
Old 06-19-2014, 06:12 AM   #858
WindSailor
WindSailor's Avatar
Oddometer: 666
Sorry it's early in the morning - what is going to be the difference between the KLR H7 and the other H7 you offer?
Smaller in overall dimensions - if I got that one right... But I want to make sure.
Sent from my Samsung Note 3
WindSailor is offline   Reply With Quote
Old 06-19-2014, 08:13 AM   #859
Jbone11 11
Jbone11 11's Avatar
Oddometer: 713
Excellent, Have a blast at the Rally and let us know what you think.
Will do. I'll try to snap some pics during the night phase...had a quick blast around the block last night and its like Im riding a new bike! I can actually "see" whats in front of me at night now!.....whether the on coming drivers could see anything after I passed them....well that's a nother story...
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
2003 Honda Hornet 600 (SOLD)
1969 BSA Royal Star - Let the Resurrection Begin!
Jbone11 11 is offline   Reply With Quote
Old 06-19-2014, 10:24 AM   #860
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,541
The KLR has a depression or ridge around the headlight socket that prevents our current H7 from fitting.
We are working on another design and or plate to service the KLR.
It will not be a smaller bulb, if anything slightly longer.
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder screwed with this post 06-19-2014 at 05:31 PM
Off Road Ryder is offline   Reply With Quote
Old 06-19-2014, 10:25 AM   #861
Off Road Ryder OP
Oddometer: 2,541
Glad to hear!!
1-800-624-0278
Old 06-19-2014, 05:24 PM   #862
Off Road Ryder OP
Oddometer: 2,541
H4s back in stock
We just received 1000 H4s and 500 H7s
stock supplies should be a bit smoother going forward.
If you are a dealer and would like to carry the Best and by far the brightest LED bulb available please give us a call or send an email
1-800-624-0278
Off Road Ryder screwed with this post 06-19-2014 at 05:30 PM
Old 06-20-2014, 02:13 PM   #863
Shooplick
Oddometer: 51
Just ordered 4 h4. I'll let you know if they fit into speed triple housings!
Sent from... Wait, where am I?
Shooplick is offline   Reply With Quote
Old 06-20-2014, 05:44 PM   #864
Off Road Ryder OP
Oddometer: 2,541
Thank You
From what I have been told they do and work very well.
please let us know what you think.
1-800-624-0278
Old 06-20-2014, 06:33 PM   #865
Nnordsman
Nnordsman
Oddometer: 331
Super Tenere
Can you think of anyway to make these work on a Super Tenere other than omitting the back covers?
Nnordsman is offline   Reply With Quote
Old 06-20-2014, 08:26 PM   #866
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,582
If the S10 has the same mounts as my FJR, they are an easy fit - you just need to trim the boot.
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is offline   Reply With Quote
Old 06-20-2014, 08:54 PM   #867
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,948
Cool2 Completely different...
Originally Posted by Mr. Canoehead;24441451[I
]If the S10 has the same mounts as my FJR, they are an easy fit - you just need to trim the boot.[/I]
Not even remotely close...
The FJR uses H4 hi/lo beam dual element bulbs in a rather traditional and conventional reflector housing.
The Super Tenere uses H7 single element bulbs in a shuttered, solenoid controlled projector housing.
As for using the Cyclops H7 bulbs in the Super Tenere, best I can figure is the center section of the round caps would have to be cut away to allow clearance for the fan unit.
Just FYI...
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is online now   Reply With Quote
Old 06-21-2014, 10:52 AM   #868
Willy510
Master of none
Willy510's Avatar
Oddometer: 111
Could I get the dimensions for the H7 unit?
I'd like to try them in my '14 Tuono but there's not a lot of extra room around or behind the housing cap.
'14 Tuono V4, '07 Guzzi Griso, '96 Guzzi 1100 Sport, '73 Guzzi Eldorado
Willy510 is offline   Reply With Quote
Old 06-23-2014, 10:07 AM   #869
Off Road Ryder OP
Oddometer: 2,541
Do you have a set and know the covers need to be removed?
WE have found they fit under the factory covers on most bikes. On others that they do not, like the high beam on the F800 the fan completely fills the hole and makes a very nice install.
We are waiting for the word from an S10 customer who should be installing any day.
1-800-624-0278
Old 06-23-2014, 01:51 PM   #870
Off Road Ryder OP
Oddometer: 2,541
Its hard to say yes or no from the photos.
here are the important dims of the bulb
from the back of the base plate to the outer edge of the shroud the dim is approx. 1 3/8 inches, the connector is on a lead so you do not need to add that in.
the diameter is 1 7/8"
1-800-624-0278
Times are GMT -7.   It's 07:38 AM.
