Old 07-02-2014, 10:00 AM   #961
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,675
Honda crf250l
the new Honda trail bike
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 07-02-2014, 10:00 AM   #962
dolomoto
Destroyer of Motorcycles
dolomoto's Avatar
Oddometer: 2,655
Originally Posted by doggitter View Post
...One post I read seemed to be saying these bulbs don't extend the high beam, just fill in better up close? Can you fill me in on that?
IIRC, the distance a headlight (regardless of bulb type) will produce light is entirely dependent on the reflector. You will have more light in the same area and may see objects at a greater distance (but only because there is more light).
YMMV,
Hot, Nasty, Bad-Ass Speed tours: 2008,2010,2014
Things I've ate/cooked.
dolomoto is offline   Reply With Quote
Old 07-02-2014, 10:02 AM   #963
Off Road Ryder OP
Oddometer: 2,675
Gs1200
Stock
LED
1-800-624-0278
Old 07-02-2014, 10:05 AM   #964
Off Road Ryder OP
Oddometer: 2,675
Vstrom
Lopsided low beam
Corrected high beam
1-800-624-0278
Old 07-02-2014, 10:07 AM   #965
Off Road Ryder OP
Oddometer: 2,675
another Gs 1200
1-800-624-0278
Old 07-02-2014, 10:51 AM   #966
I82l8
I82l8's Avatar
Oddometer: 121
Originally Posted by Off Road Ryder View Post
H4
2012 BMW G650GS Sertao
I got my bulb for my G650GS on Monday.
Anything special to consider when I'll install it?
Thx
I82l8 is offline   Reply With Quote
Old 07-02-2014, 11:53 AM   #967
Off Road Ryder OP
Oddometer: 2,675
Thx
We found it easier to remove the headlight, Very easy the two side screws remove and the entire headlight pulls out the front.
I cant remember if we tossed or cut a hole the boot
1-800-624-0278
Old 07-02-2014, 11:55 AM   #968
Off Road Ryder OP
Oddometer: 2,675
We will be closed tomorrow threw Sunday for July 4th. Going riding
Wishing you all a Great and Safe 4th
1-800-624-0278
Old 07-02-2014, 12:04 PM   #969
doggitter
Oddometer: 2,081
YMMV,
I would believe that is most, if not all of the case. Until the light source has been re-engineered, as is this case. A reflector can only do the same job if what it is reflecting stays in the same location, right?
So many rides, so little time.
Loren, somewhere on a DR350SE
doggitter is offline   Reply With Quote
Old 07-02-2014, 12:07 PM   #970
doggitter
Oddometer: 2,081
Originally Posted by hubrus View Post
I also didn't get the clarification was looking for, and draw the same conclusion as you did, mainly because the pictures shared from orangecicle installation. I can't see the difference in elevation between high and low beams.
That's the same post that brought me concerns.
Sorry if it seems I'm being picky but I don't want to spend more money on things I don't fully understand and will be disappointed with later.
Old 07-02-2014, 01:42 PM   #971
JB_Strom
IYAOYAS
JB_Strom's Avatar
Oddometer: 48
Laugh BOOM Shakalaka!
I see the D2S Projector retrofit I did last year going away for a set of these. One thing I miss about "normal" H4 bulbs vice the projectors is the size of the light oncoming drivers see farther away from you during the day (conspicuity).
Love it.
Jerry
Lopsided low beam
JB_Strom screwed with this post 07-26-2014 at 10:24 AM
JB_Strom is offline   Reply With Quote
Old 07-02-2014, 03:14 PM   #972
Off Road Ryder OP
Oddometer: 2,675
Originally Posted by JB_Strom View Post
I see the D2S Projector retrofit I did last year going away for a set of these. One thing I miss about "normal" H4 bulbs vice the projectors is the size of the light oncoming drivers see farther away from you.
Love it.
Jerry
I haven't messed around a whole lot with Projector beams.
1-800-624-0278
Old 07-02-2014, 03:16 PM   #973
Off Road Ryder OP
Oddometer: 2,675
I can understand this bulb may not be for everyone. To each their own.
But Ive never met a rider who did not appreciate being able to see better. This LED bulb certainly does do that.
1-800-624-0278
Old 07-02-2014, 03:20 PM   #974
PaperBoy
Dig that Crazy Beak
PaperBoy's Avatar
Location: Oroville, Washington, USA - 48.938665, -119.427047
Oddometer: 341
Giving it a try
Okay, I ordered one and will fit it in to one side of my TT dual headlight for the R1100GS -- that is if it fits. Test it out for awhile and if I like it order one for the other side as well. Any suggestions on which side I should try it on first, centerline (left) or fog line (right)? Might work nice as a combination of both Halogen and LED. I like the white light these are putting out in the photos. The last post sure shows the difference. The big trailee has a lot of electrical output, but like the idea of LEDs that last a long time and save wattage for things like auxiliary lighting and heated gear. Gary
My dog hates my bike!
1999 R1100GS - Blue & White, the fastest colors.
BMWMOA #142415
Valley BMW Riders member "Bigfoot"
PaperBoy is offline   Reply With Quote
Old 07-02-2014, 03:58 PM   #975
kbuckey
Oddometer: 862
A Duke followed me home yesterday. Anybody put one in a2013/14 690 Duke? It has an H4 bulb and looks like it should work.
kbuckey is offline   Reply With Quote
Times are GMT -7.   It's 03:31 AM.
