Old 08-12-2014, 09:12 AM   #1171
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,738
Originally Posted by murpies View Post
I realize that 2014 f800gs cap is different from 2011 model.
2014 model cover
Less room space for the LED driver so the cut hole is larger as it touched the cap.
2011 model cover
More room space for the LED driver so the cut hole is small n not touching the cap.
Nicely done!!!
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 08-12-2014, 09:13 AM   #1172
Off Road Ryder OP
Oddometer: 2,738
Originally Posted by 2kool2be4gotten View Post
Depending on the size if the sparate driver box (Altoids tin vs. toaster) i would be interested in trying a preproduction H3 on my KTM 990 with Euro Headlight (H3/H7 bulbs). Do you have dimentions of the driver box?
Not quite yet, should have all that info next week.
1-800-624-0278
Old 08-12-2014, 09:53 AM   #1173
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,887
Hope you don't mind if I post this write up I ran across this morning-
http://www.advpulse.com/adv-products...adlight-bulbs/
I have nothing to do with advpulse but thought it was worth posting here.
It's not an adventure until you cross a bridge , 2011 WR250, 2015 ktm 690r
findLadukebob
Ladukebob is offline   Reply With Quote
Old 08-12-2014, 11:23 AM   #1174
EKinOR
Oddometer: 270
I'd also like to see lower color temps - something in the 4.3k to 5k range would be great. The 6k+ light tend to have more back scatter.
- Eric
2002 BMW R1150GS
EKinOR is online now   Reply With Quote
Old 08-12-2014, 03:23 PM   #1175
Off Road Ryder OP
Oddometer: 2,738
1-800-624-0278
Old 08-12-2014, 03:26 PM   #1176
Warrewp
Oddometer: 4
About to get one of these for my Scrambler. I'm in desperate need.
Warrewp is offline   Reply With Quote
Old 08-12-2014, 03:54 PM   #1177
Johnrunner89
Oddometer: 49
So unfortunately I have the hard plastic rear cover on my 14' 500exc as opposed to the soft rubber rear cover like on my 13' 350exc so the H4 headlight won't fit I checked some other 14' models and they all appear to have the hard plastic rear.
Johnrunner89 is offline   Reply With Quote
Old 08-12-2014, 04:48 PM   #1178
YJake
Roaming
Oddometer: 434
Has anybody tried this in a nekkid Bandit 1200?
Are there any measurements on the bulb assembly I can use to check for fitment before hand?
Reckon I can just order one and ship it back if it won't fit.
-Jake
Touring The Gulf.
YJake is offline   Reply With Quote
Old 08-12-2014, 06:22 PM   #1179
murpies
murpies's Avatar
Oddometer: 156
Originally Posted by Off Road Ryder View Post
Thank You
What a great write up!! I can take some marketing tips from this..
One tip I might mention is that to remove the base push slightly down then twist.
Thanks again
Darryl
Hi Darryl I just PM u. Need some advice from u.
murpies is offline   Reply With Quote
Old 08-12-2014, 10:43 PM   #1180
Lexanez
Oddometer: 6
Oh, is there any dimensions available for the H7 bulb?
Lexanez is offline   Reply With Quote
Old 08-12-2014, 11:32 PM   #1181
murpies
murpies's Avatar
Oddometer: 156
Here you go. PM send too.
Old 08-13-2014, 10:01 AM   #1182
Spud Rider
Spud Rider's Avatar
Oddometer: 3,814
Did you bring out a newer, shorter version of the H4/H6M bulb? I believe this is a photgoraph of the original bulb.
Are these photographs of a newer, shorter version?
If you have a shorter version of the original H4/H6M bulb, does it have the same dimensions as the H7 bulb, and how much shorter is the newer H4/H6M bulb?
I think the original H6M bulb is too long for my CRF250X, and will hit the steering stem on the frame.
Spud
Old 08-13-2014, 10:56 AM   #1183
Off Road Ryder OP
Oddometer: 2,738
Spud
The newer version is slightly shorter than the original, by approx. 3/8 of an inch. The black version is the latest and should not hit the frame on the 250X or at least it does not on the 450
1-800-624-0278
Old 08-13-2014, 11:13 AM   #1184
Spud Rider
Spud Rider's Avatar
Oddometer: 3,814
Thanks for the quick reply. Three-eights of an inch shorter is a significant improvement.
Spud
Old 08-13-2014, 12:02 PM   #1185
chambersc
chambersc's Avatar
Oddometer: 402
H4 for WR250F
I just ordered the H4 for the 2003 WR250F I am dual sporting right now for my soon-to-be 14 year old kiddo. I'm pretty excited about how it does, as the stock is pretty anemic and the charging system is getting enough demands with the blinkers, brake light, etc that's being added right now. Last of the parts shipped yesterday to make this thing street legal so it will soon be road ready. Need to mount my DOT tires one night this week. I'll try to post some success photos of the new headlight.
It's no mistake that the word "silent" and the word "listen" contain the same letters.
chambersc is offline   Reply With Quote
Times are GMT -7.   It's 03:58 PM.
