Old 03-04-2014, 08:40 PM   #151
ebrabaek OP
Oddometer: 4,709
Originally Posted by jengel451 View Post
Dammit, I think you took mine! ;)
Ha ha....Sorry....
Erling
Old 03-04-2014, 08:41 PM   #152
ebrabaek OP
Oddometer: 4,709
Originally Posted by SOP Dirt-Rider View Post
I'll start a new thread as my bracketry will be nothing near like the porn Erling has created, but the lights? Yes, took delivery today and I am busy making a temp bracket for my upcoming trip before I have a billet bracket made up. Let there be light!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ha ha ha.... saw your text..... Looks like we might be zapping cones through the desert in a few weeks...ehhhh...
Erling
Old 03-05-2014, 10:01 AM   #153
lousot
lousot's Avatar
Oddometer: 464
awesome work like always but so I don't have to go through this entire thread again where did you get the 60's
If you dump it in front of me.I promise I wont run you over.dit: And remember, "You can't drink all day if you don't start in the morning".
lousot is offline   Reply With Quote
Old 03-05-2014, 11:01 AM   #154
ebrabaek OP
Oddometer: 4,709
Thanks.
I got them from Rally lights......
http://www.rallylights.com/all/light...mp-module.html
The hid I used the ballast from 1offmotorsports. They are no longer in busyness, But I have a few extra kits on the shelf, if you are interested, pm me. I got the 9005 HID " bulb" from the retrofitstore.com. It was a good buying experience with them.
Erling
Old 03-06-2014, 06:43 AM   #155
mattlikesbikes
Oddometer: 194
One of these days I need to load the big 29'r up on the back of the GS and head to El Paso.
Until then, what are your thoughts on the Hella? As I look at all of the LED and other fog lights I keep thinking a nice projector set with HID's in them would be the best light. And at $50 each, not a bad price. So how elements proof are they on their own? I thought I would make, aluminum or CF, a set of 75% wrap guards (Like the Touratech lights have), but if I also needed to make outdoor bodies too I'd consider it.
2009 F 650 GS - Lava Orange
mattlikesbikes is offline   Reply With Quote
Old 03-06-2014, 08:19 AM   #156
ebrabaek OP
Oddometer: 4,709
Hands down, the best low beam I have ever seen. I have seen a lot of them, but this one takes the cake. There are a few reasons I say that.
First... Hella told me it was developed by them for Buel. That was an indicator of a high quality torch. Not because of Buel, but because of a mc single has to throw as much light as possible as there are only one lens.
Second, is the beam. It is very well balanced with throw, and spread, with no hot spots. Compare to the stock, and see all the hot spots ( can be identified with a high light saturation, as compared with surrounding areas) It falters in comparison.
Third...Beam cutoff control is tremendously sharp, with again no rouge torching.
Fourth.... inexpensive.
Fifth.... All of the above statements apply with or without HID in there, as you can see there are no difference in the pattern.
It is funny you would say that. As I got it in stock, I was thinking the same thing. I was considering making a CF housing, to mount it in, and market them as true aux low beams, as fog lights, and low beams are really not the same.
I would say go for it...... At that price, throw in a set of 9005 HID from retrofitstore, and you are still under $100 per light.
Would love to show ya a few of the all year around trails here in the desert. Here is a few clips from the local. For some reason my go pro mocked the sound clip, and after rolling one of the tecno's here, I napped on a cactus...... Ha ha ha, so ironic....
http://www.youtube.com/watch?v=u74N--zbGbo
One of the primo descends....
http://www.youtube.com/watch?v=kaJ3jJw3Hk8
Erling
ebrabaek screwed with this post 03-06-2014 at 08:34 AM
Old 03-06-2014, 09:01 AM   #157
BMacW650
BMacW650's Avatar
Oddometer: 747
So true. The 60mm low beam Hella projector is one the best kept secrete. When you fit an hid, for normal road riding, any aux light would be useless when it's on.
BMacW650 is offline   Reply With Quote
Old 03-06-2014, 09:05 AM   #158
mattlikesbikes
Oddometer: 194
Agreed, not fog lights but Aux low beams. After I had Lasik it seems like my already meh night vision is even worse. Add in the crap GS stock headlight and it can make night riding a bit scary. I like the LED aux lights but with HID kits so cheap it just doesn't make since to not go big.
I'll order up a set and get started fabbing.
Old 03-06-2014, 09:26 AM   #159
ebrabaek OP
Oddometer: 4,709
Indeed, I found this to be the fact. Thanks again for all your help....
Erling
Old 03-06-2014, 09:27 AM   #160
ebrabaek OP
Oddometer: 4,709
Awesome.... Cant wait to see the results.
Erling
Old 03-12-2014, 09:21 AM   #161
mattlikesbikes
Oddometer: 194
Erling, These things are HUGE!
Couple questions for you.
1. Are the four eye holes for the adjuster screws threaded on yours? Neither of my lights is threaded and I am not sure how they stay mounted.
2. Are you running a 35W or a 55W HID setup? Small space and plastic housing has me worried about heat dissipation.
Matt
Old 03-12-2014, 08:26 PM   #162
ebrabaek OP
Oddometer: 4,709
Matt
Matt.
The 4 bolts are used to mount the housing up against the front plate. I forwent using the adjuster, knowing that if I made everything plumb and square, then I did not need the adjuster.....
And you can see the front here...
So I just threw out the adjusters.
The HID is 35 watt. I think 55 watt is way overkill. Hope this helps.
Erling
Old 03-16-2014, 07:32 AM   #163
teomannaskali
Oddometer: 738
You want the 100w HID. :)
teomannaskali is offline   Reply With Quote
Old 03-16-2014, 08:49 AM   #164
ebrabaek OP
Oddometer: 4,709
As bright as the 35 is, I cannot even picture the 100W.
Erling
Old 03-16-2014, 02:17 PM   #165
runnr548
BMW Pilot
runnr548's Avatar
Oddometer: 119
Cool2
Awesome work! I love LED's!
runnr548 is online now   Reply With Quote
Times are GMT -7.   It's 12:06 PM.
