Old 02-25-2014, 04:28 PM   #91
jengel451
1 Cool MotherF#$cker
Oddometer: 804
Originally Posted by ebrabaek View Post
..... she will have to bear the pain....
She's used to it, years with me has made her numb to it all....
jengel451 is offline   Reply With Quote
Old 02-25-2014, 04:30 PM   #92
ebrabaek OP
Oddometer: 4,873
... Good to hear.
Erling
Old 02-25-2014, 07:38 PM   #93
ebrabaek OP
Oddometer: 4,873
Headlight beam patterns.
So It is time to compare patterns. When I installed the dual HID back in 2010, I took pictures, so same road, but diferent cameras, so perhaps a little bias, but good pattern comparison.
Stock halogen low beam.
HID stock housing Low beam.
Hella Halogen 60mm projector low beam.
Stock Halogen high beam....
HID stock housing High beam...
LED High beam ( note that I had to turn the low beam off. It would mess too much with the aperture, and the picture would not come out even close to the visual presentation, as there was simply too much light. Picture one is LED high beam, with Denaly D2, which really only adds a little front fill. Picture two is LED with low beam on, and you can see the camera mess...
LED high with low beam on. Note the yellow color....
When I took the pictures back in 2010, I used whatever setting of the camera to mimic the closest color temp, and then left it, for all the shots. Same today. I really like the pattern of the 60mm ( mind you it is a lousy stock 9005, as my HID has not arrived yet. The high is good, as the D2's fill in the immediate area. But as Darryl mentioned, there is a filter for the LED that by the flick installs, and I have more spread.
Here is the original HID thread....
http://advrider.com/forums/showthread.php?t=624794
Erling
Old 02-25-2014, 07:43 PM   #94
SOP Dirt-Rider
SOP Dirt-Rider's Avatar
Oddometer: 694
Nicely done!! Imagine a pair of the extremes!! I'll be seeing Daryl on Thursday. Gotta strike a deal
www.pssor.com
SOP Dirt-Rider is offline   Reply With Quote
Old 02-25-2014, 07:45 PM   #95
ebrabaek OP
Oddometer: 4,873
Man...... You get to go all the places.... First Rekluse..... Now Cyclops. Nice. I think the perfect combo is a pair of long range, one with the filter on to spread out.
Erling
Old 02-25-2014, 07:55 PM   #96
SOP Dirt-Rider
Oddometer: 694
My plan is clear 20 degree ran at %50. High beam second light at %100 with the amber 20 degree in conjunction with the low beam boosted to
%100. Add those to the standard LRs and 530 light bar I should be able to land 747s on Pikes Peak All that light at %100 will draw just over 100 watts.
www.pssor.com
Old 02-26-2014, 06:08 AM   #97
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,815
wtf mate o0 can you spell DAYLIGHT. Is that the thing they used in Indiana Jones?
Loutre is offline   Reply With Quote
Old 02-26-2014, 06:14 AM   #98
ebrabaek OP
Oddometer: 4,873
... No kidding, and truth to be told, the picture dos not come close. Real life it is not that blue. I would say 5500-6000 Kelvin, but there were so much light that the camera toned down white ballace, and ISA. I had locked shutter, and aperture. Pretty silly from one 25 watt LED emitter.
Erling
Old 02-26-2014, 07:46 AM   #99
teomannaskali
teomannaskali's Avatar
Oddometer: 824
Does that thing have an SST-90 emitter inside?
teomannaskali is offline   Reply With Quote
Old 02-26-2014, 08:28 AM   #100
jengel451
Oddometer: 804
why do these pictures make me all giddy?
Probably because I know how fun it is to ride at night off road with really good lighting.
Old 02-26-2014, 10:19 AM   #101
ebrabaek OP
Oddometer: 4,873
I actually have no idea, but ring them, and ask for Darryl. I am sure he can answer that. All I know, is that it is a 25 watt emitter.
http://www.cyclopsadventuresports.co...ight_p_61.html
Erling
Old 02-26-2014, 10:20 AM   #102
ebrabaek OP
Oddometer: 4,873
It is really not done justice by the camera. I will try to dive into camera settings a little better, as I was holding the low beam, in my hands, camera on tripod...etc.
Erling
Old 02-26-2014, 10:20 AM   #103
ebrabaek OP
Oddometer: 4,873
Hack time...
Time to hack the bracket to make the projector fit.
Erling
Old 02-26-2014, 11:18 AM   #104
jengel451
Oddometer: 804
I've seen first hand how insanely bright the LED is alone and agree, the pictures aren't doing even that part justice. So I can imagine what it's really like with both.
Old 02-26-2014, 12:32 PM   #105
ebrabaek OP
Oddometer: 4,873
Wink Hacking time....
Room was cut on the lower beam. Mind you, that I did this exact same thing to accommodate the top of the LED....
Then the front hole was cut, and ground into specs....
I like it....... In fact, it really added a nice look ( Pffttttt... Jengel..... don't show your wife....)
Now onward to repair the housing....
Erling
Times are GMT -7.   It's 04:01 AM.
