Old 01-23-2014, 08:47 AM   #1
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 397
Tire delema
Hey all... So I had a set of Woody Wheels built for my 990 Adv with the rear being tubeless now. I just got a set of TKC80's and it appears the rear is a tube type. I thought I was getting a tubeless but didn't and no one has a tubeless that I can find in the US.
Can I run this tire without a tube? I can put a tube in but then I screw up my new tubeless rim and would have to send it back to Woody to re-seal. If I do that I would rather run the D908.
I got these for a Baja trip and am only hoping they last long enough for the trip. Probably 2000 miles total.
Thanks for any advise you all have.
skidxr is offline   Reply With Quote
Old 01-23-2014, 09:15 AM   #2
spafxer
spafxer's Avatar
Oddometer: 2,649
Most reports seem to say TKC's are too soft of sidewall for the rocks of Baja anyway.
606 front 908 rear. Oops, just checked them and they are both "tube type"
No opinion on running them tubeless. I usually trust the engineers over opinions. Must be a reason.
Got nothin'
spafxer is offline   Reply With Quote
Old 01-23-2014, 10:48 AM   #3
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,014
Run a Karoo 3 on the back.....
KTM 1190R...Adventure Beast, KTM 690 Quest...Rally Beast, Husqvarna 501...Trail Beast, KTM 950SE......Desert Beast, KTM 300xc...Woods Beast
Nowwhat is offline   Reply With Quote
Old 01-23-2014, 11:40 AM   #4
Wonway
KTM Fanboi #2
Oddometer: 432
See this thread: http://www.advrider.com/forums/showt...=943455&page=3
Revzilla will be stocking them soon.
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
2014 KTM 1190 Adventure R
Wonway is offline   Reply With Quote
Old 01-23-2014, 11:46 AM   #5
polishadam82
black sheep
Oddometer: 144
Get some k60
Sent from my HTC6435LVW using Tapatalk
Sometimes you find yourself in the middle of nowhere, and sometimes in the middle of nowhere, you find yourself.
"You can watch things happen, you can make things happen, or you can wonder what the fuck happened."
IBA#59715
polishadam82 is offline   Reply With Quote
Old 01-23-2014, 11:54 AM   #6
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,859
In response to your question, rather than just telling you to go buy new tires, yes I run tube type tires in a tubeless application all the time and it works fine. Right now I am running a 606 front an 908 rear tubeless an also a Michelin trials tire with a DOT legal Kenda front knobbie all tubeless an they all hold air just fine. Run it.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 01-23-2014, 11:59 AM   #7
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 397
Thank you all...
I was wondering if it would hold air and sounds like it does.
Old 01-23-2014, 12:22 PM   #8
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,859
Thank you all...
I will be very surprise if it doesn't but you can always add a touch of slime to be sure.
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 01-23-2014, 12:40 PM   #9
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Or maybe Stans (stuff used on tubeless mountain bike setups).
ben
______________________________
2013 KTM 990 Adventure Baja Edition
armourbl is offline   Reply With Quote
Old 01-23-2014, 06:58 PM   #10
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,154
Thank you all...
I run other rear tires tubeless on a similar setup (the mefo is a tube type, I think). It was a bit harder to seal the first time, but after the first ride it was fine. I think I added a couple psi every 2 days on a long trip- something I could easily do with a hand pump in 20 seconds kind of thing.
Brent, aren't you running a tubliss brand setup? or do you have plain old sealed rims too?
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 01-23-2014, 07:12 PM   #11
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 397
I mounted it and will keep an eye on it..
Thanks again for the input...
Old 01-24-2014, 08:45 AM   #12
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,859
Yes I am running Tubliss brand system but it doesn't change that the tire has to do the sealing.
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 01-24-2014, 09:04 AM   #13
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 397
No air loss at all after sitting overnight.
I don't know if running a sealant is a good idea or not with the sealing tape that Woody's used. I was thinking Slime or Ride On but Who knows...
Old 01-24-2014, 09:12 AM   #14
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
I'm not familiar with the sealing tape that Woody uses, but on my mountain bike using the Stans kit you seal the rim with tape. Been running the same tape for a couple of years with no issue. The one down side to Stans is it will dry out over time, especially in hot conditions and has to be refreshed. I do it through the valve stem after removing the core. Remember, I'm talking about a mtn bike. The theory should be the same for a motorcycle though.
I know some guys who run the Tubeliss brand system on their dirt bikes and also run Slime in the tire to get a good seal and deal with road/trail hazard punctures.
ben
Old 01-24-2014, 09:19 AM   #15
tkent02
Oddometer: 2,804
What is this sealing tape? I'm putting together some spoked wheels now and I'd like to go tubeless if possible. Have heard of using RTV but tape seems like a better idea.
tkent02 is offline   Reply With Quote
Times are GMT -7.   It's 03:06 AM.
