Go Back   ADVrider > Bikes > Battle Scooters
Old 01-30-2014, 04:47 PM   #1
wheelbender6 OP
wheelbender6's Avatar
Oddometer: 168
Diesel Scooter by Hero
The front needs to be restyled, but I like the rest of it.
http://blog.motorcycle.com/2014/01/2...iesel-concept/
"Live every week like its Shark Week" -Tracy Morgan
wheelbender6 is offline   Reply With Quote
Old 01-30-2014, 04:54 PM   #2
Kubla
Oddometer: 1,397
I will take the turbo version, where do I sign up?
1996 Harley Tour Glide
1998 Honda Helix
1989 Honda Pacific Coast
2000 westward Go-4
1982 Bluebird wanderlodge
Kubla is offline   Reply With Quote
Old 01-30-2014, 05:13 PM   #3
RLK
4,949
RLK's Avatar
Oddometer: 6,518
2wd hybrid; go ahead and cross three bridges at once.
The engine also acts as a generator, with Hero claiming it can provide about 1500 W of continuous electric power or 6.5 A at 230V.
The optional electric hub-mounted motor produces 1.3 hp, but it works independently from the rear and is operated by a secondary throttle control. Both the electric motor and turbocharger will be optional.
Some of you morans might remember when I put together a Stupid Electric Bicycle. Shortly after that was a gas motor rwd bike. I crashed pretty hard on the electric one before I could get the electric front on the gasser and have a 2wd hybrid.
I'd love to see just the diesel part come off right.
It takes less time to do things the hard way than to be too nervous to even start at all.
-Juanito on the Yahoo!
RLK is offline   Reply With Quote
Old 01-30-2014, 05:32 PM   #4
bandito2
bandito2's Avatar
Oddometer: 270
WHAT THE __?
I noticed a lack of info about the type of transmission method for driving the rear wheel, top speed or whether it would be
road legal. (though mirrors and turn signals certainly would suggest that it would be)
From the motorcycle.com article : "The engine also acts as a generator, with Hero claiming it can provide about 1500 W
of continuous electric power or 6.5 A at 230V. Hero says the RNT also has mounting points for ploughs and harvesters."
It's a freekin 2 wheeled farm implement!!! (What!!!? No mowing deck?)
So maybe CaseyJones wasn't so crazy after all to suggest tractor tires on a scooter.
Who'd a thunk it?
Rochester Hills Michigan Dark Side Rider
Back to 4 Honda Reflex scooters and a FSC600A Silverwing too
Originator of the
"Darkside" Honda Reflex. "Yeah dude, that IS a car tire there on the back of my scooter."
bandito2 screwed with this post 01-30-2014 at 05:41 PM
bandito2 is offline   Reply With Quote
Old 01-30-2014, 05:54 PM   #5
wheelbender6 OP
Oddometer: 168
"I noticed a lack of info about the type of transmission method..."
Good point. No photo of that side. The swing arm makes it look
like it is not a conventional 150cc cvt drive train.
Old 01-30-2014, 06:05 PM   #6
bikeridermark
Oddometer: 2,386
When I googled it, one site said it was mated to a six-speed transmission.
bikeridermark is offline   Reply With Quote
Old 01-30-2014, 06:25 PM   #7
bandito2
bandito2's Avatar
Oddometer: 270
That, and this added info from the site:
According to Hero, the liquid-cooled TDI engine produces just 13.5 hp at 4000 rpm, but it’s the torque numbers that really shine, claiming 25.8 ft-lb. at just 1600 rpm.
Those rpm numbers are only about half of what conventional gasoline powered scoots employ with their CVT drives. The relatively low rpm diesel engine would need to use a quite unconventional CVT drive or more likely an auto clutched multi-ratio transmission with chain or shaft drive.
2 wheel drive? Makes me think of the Rokon, but that is more of an ATV and not fast enough to be practical for legal road use. Seems like there was another 2 wheel drive motorcycle that had a unique way to power the front wheel, flexible shaft drive to the front wheel or maybe it was hydraulically driven. But I don't remember where it was that I saw it or what it was called.
Originator of the
bandito2 screwed with this post 01-30-2014 at 06:33 PM
Old 01-30-2014, 06:52 PM   #8
T-rot 120
Oddometer: 11
Since its a diesel does that mean that the best oil for it is rotella? Grin
T-rot 120 is offline   Reply With Quote
Old 01-30-2014, 07:05 PM   #9
conchscooter
conchscooter's Avatar
Oddometer: 2,289
AWD Motorcycle
http://www.christini.com
http://www.keywestdiary.com
IBA#39,523
conchscooter is offline   Reply With Quote
Old 01-30-2014, 07:11 PM   #10
alphaBETAdog
alphaBETAdog's Avatar
Oddometer: 305
Christini
http://www.christini.com/bikes/christini-awd-450
'13 Suzuki Vstrom 650
'08 Beta 450 RS
'12 Kymco Gti300, '03 Aprilia Scarabeo 150
alphaBETAdog is offline   Reply With Quote
Old 01-30-2014, 07:20 PM   #11
bandito2
bandito2's Avatar
Oddometer: 270
Well, here is an article from a little over 10 years ago.
http://www.gizmag.com/go/2351/
It was the R1 that I was thinking about.
Makes me wonder though.... Don't seem to hear too much of very many 2 wheel drive or all wheel drive bikes these days.
Loose its appeal/not enough interest to continue manufacturing? Seems like a sound and proven concept. According to
the article, Yamaha had even mentioned the possibility of applying the drive system to the T-Max scooter..... wonder why
it was not done.
An AWD diesel scooter that can maintain highway speeds should be just about ideal... Enhanced traction and very fuel
efficient... can't go wrong with that.
Originator of the
bandito2 screwed with this post 01-30-2014 at 07:27 PM
Old 01-30-2014, 07:32 PM   #12
Kubla
Oddometer: 1,397
i wanted it when I read "diesel" rest was unimportant
1998 Honda Helix
2000 westward Go-4
Old 01-30-2014, 08:33 PM   #13
Chillis
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,159
If you look at most passenger car turbo diesel applications they have close to 90% max torque just off of idle(below 2000rpm) but still rev to 5 or 6000rpm.
This being a smaller lighter engine should still produce 4 to 5000rpm. Just a matter of ramp angles in the variator and appropriate weights. The rest is rear end gearing for desired speed range.
Chillis is offline   Reply With Quote
Old 01-30-2014, 09:03 PM   #14
gogogordy
gogogordy's Avatar
Oddometer: 2,003
Cue the...
"price too high/technology too new" discussion.
Should be along any minute.....
Isn't it past your bedtime?
gogogordy is offline   Reply With Quote
Old 01-30-2014, 09:18 PM   #15
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 3,188
I ll have you Now I m not a Moran but the last Girl I date did say I had AIDS : Asshole in denial sindrum . Great company and great bikes. If it makes it out the door as a real scooter instead of prototype it would be a hit in india etc. You get electrical gen were you may never ever had Electoral before . Transport etc.
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Times are GMT -7.   It's 09:33 AM.
