Old 01-31-2014, 09:32 AM   #1
Colorado_Rider OP
Oddometer: 1,193
Bar weight myth
My ever since I started lightening my bars by removing the weights I've found the vibrations reduced by a huge amount. Discuss/argue/ignore doesn't matter to me I think it's BS.
Colorado_Rider is offline   Reply With Quote
Old 01-31-2014, 10:02 AM   #2
OrangeYZ
Oddometer: 598
When I installed bark busters on my KLR I left the weights off because I figured there wouldn't be any difference. Made it five miles, said "This sucks," went home and found bolts long enough to put them on.
On that bike it's true, I haven't had them on any others.
OrangeYZ is offline   Reply With Quote
Old 01-31-2014, 10:12 AM   #3
fast1075
Fasterizer
Oddometer: 256
My experience has been that it depends on the frequency of the vibe and the type of bar. The bar end weights help a lot with high frequency buzz, but often to little for low frequency rocking couple.
The older I get, the faster I was.
fast1075 is offline   Reply With Quote
Old 01-31-2014, 10:24 AM   #4
FrogAndTrumpet
Oddometer: 82
I recently fitted (OK, for "fitted" read "bodged" ) some KTM handguards on my SpeedTona, which entailed junking the bar weights. So far, I haven't noticed any uncomfortable vibes and buzzes in the 'bars - which is just as well because my bodge job means that I won't be able to remove the guards and refit bar weights very easily...
Fork 'andles
FrogAndTrumpet is offline   Reply With Quote
Old 01-31-2014, 10:41 AM   #5
Colorado_Rider OP
Oddometer: 1,193
This was on an I-4. A single or twin, I've yet to try it on, but the XR650L I had with just a bar, no weights didn't give me near the problems it should have considering how much is vibrated on the highway.
Old 01-31-2014, 10:48 AM   #6
phreakingeek
phreakingeek's Avatar
Oddometer: 507
on my DR650, the stock bars without weights were so bad that I didnt even make it 5 miles before going back home.
My handguards now do the job of weights to keep the vibrations from turning my hands into leaden nubs at the ends of my arms.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”
-Hunter S. Thompson
phreakingeek is offline   Reply With Quote
Old 01-31-2014, 10:50 AM   #7
joexr
Oddometer: 3,773
Laugh
What the hell is a SpeedTuna?
Old 01-31-2014, 10:53 AM   #8
FrogAndTrumpet
Oddometer: 82
A SpeedTona (with an "o" ) is a Triumph Daytona that's been turned into a Speed Triple (usually as a result of a SMIDSY moment).
Fork 'andles
Old 01-31-2014, 11:07 AM   #9
joexr
Oddometer: 3,773
Eh?
Old 01-31-2014, 12:22 PM   #10
Red9
Oddometer: 508
Yeah cause manufacturers were just looking for places to add additional weight...
Red9 is offline   Reply With Quote
Old 01-31-2014, 12:47 PM   #11
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 664
Bar weights cannot eliminate handlebar vibrations, they merely serve to shift the resonance point of the bars to some other point in the operating range. The 'vibrations' people notice are a resonance mode in the bars. You can shift where this resonance point is by either altering the mass or stiffness of the bars. Increasing the mass and decreasing the stiffness shifts the resonance point lower in the revs, and doing the opposite shifts it farther north.
You by lightening your bars are shifting the point farther north in the revs. I imagine if you ride a little faster, you'll again find the point where the bars do vibrate, just not where you ride most of the time.
It's Vibes...nothing more, nothing less.
-M
godwinmt is offline   Reply With Quote
Old 01-31-2014, 12:59 PM   #12
MacNoob
MacNoob's Avatar
Oddometer: 1,651
If the bars happen to resonate at a frequency that is some harmonic of the engine vibration, you will get vibrating bars. Bar end weights will change the resonant frequency of the bars so they will vibrate at a different RPM that may be outside your common RPM range, reducing the irritant.
I think I have finally learned that life is just too short for cheap butt connectors. And that's all I'm going to say about that.
MacNoob is online now   Reply With Quote
Old 01-31-2014, 01:35 PM   #13
toates89
Oddometer: 270
Frequency is equal to the spring constant over mass
omega=k/m
As mass increases omega decreases.
toates89 is offline   Reply With Quote
Old 01-31-2014, 04:51 PM   #14
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,900
And you've gained this great insight by removing the weights on how many bikes?
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 01-31-2014, 04:52 PM   #15
markk53
markk53's Avatar
Oddometer: 8,900
Nah, they got a good buy on them and had to do something. Or maybe it was part of the "bold new graphics" the second year.
Mark - klx678
Times are GMT -7.   It's 06:05 PM.
