Old 02-01-2014, 08:16 AM   #1
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
AluFlange - protection for the R1200 rear wheel flange
Hi all,
I have started to make these protections for the R1200 series. They fit on the outside of the aluminum flange, making it more robust and less prone to cracking. Google has a lot of search results for "rear wheel flange crack"
So, the R1200 series, RT, GS, R, etc. have this aluminum flange that connects the rear wheel and the brake disc to the hub. This part is known to crack, so BMW made an upgraded flange, made out of a steel.
Indeed, the new one is better than the aluminum one, but it has one big disadvantage - it is ~ 2/3 wide. This means that the rear wheel and the disc can develop play, in respect to the spline hub. Since it is narrower, it also has a spacer ring to compensate that extra width. This is bad, since with the new upgraded flange, the spline contact surface decreased.
There's another reason that the upgraded flange is not fit for this application. The material that it is made of is now hard, and it can destroy the splines on the hub. That is why first, they made it out of Aluminum, so that the flange would wear first, since it would be more easy to replace.
So, the protection I make, is also made out of Aluminum, 7075. This is a hard alloy, used in making auto parts mostly. The protection is precised cut on a CNC and then anodized, for a good, long, corrosion protection.
Installing it is pretty easy. First thing, put the bike on the center stand and take off the rear wheel.
You now have to clean really good the outside of the flange, cannot allow any dirt to get in there. I am using an old toothbrush and some brake cleaner for this, because I don't have to rub that much.
After you are sure you cleaned everything well in there, you can start to put in the protection. Hover it over the flange and then, using a rubber mallet, gently tap on the outer side of the flange, going round, little by little. Heating the AluFlange prior to installing does not hurt. It will only make your job easier.
If you do not have a rubber mallet, you can use a metal hammer, but DO NOT hit the protection using the metal side! Use a piece of soft wood, in order to not destroy the finish on the protection.
Go round and round until the AluFlange protection rests on the brake rotor. You can then put in the 5 pins provided. Tighten them in by hand until they start to get to the other side. Then mount the rear and check the gap between the pins and the wheel hub. Then take off the wheel and un-do the pins, until they would almost touch the wheel hub. Then use the nylon nuts and secure the pins.
When installing the wheel, make sure NONE on the pins touch the wheel hub. They should be near the wheel center hub, but not touching it. Their purpose there is as safety, in case the protections tends to com off the flange (it won't, but it's OK to be safe).
Then you can mount the rear wheel, tighten the bolts to specs (check the manual for that torque) and spin the wheel by hand, make sure all is in place. Then take the bike for a round.
Like I said, the AluFlange is made out of 7075 anodized aluminum. It is very strong and light(~190 grams w/ screws and nylon nuts). It's worth keeping the OEM aluminum flange on the bike, as long as you have this protection on.
The price for one AluFlange is 135$ (USD), shipping included, worldwide. I also have a version for the GSA spoke wheel.
So this is a 135$ part that saves a ~400$ part. You do the math if it's worth buying it or not. Not to say that it can keep you from being stranded in the middle of a trip.
Orders can be processed trough my webstore HERE.
Thanks,
Dan Cata.
02.16.2015 - Updated pics
Dan Căta screwed with this post 02-16-2015 at 12:17 PM
Dan Căta is offline   Reply With Quote
Old 02-26-2014, 04:36 AM   #2
Lucian
Lucian's Avatar
Oddometer: 5
Managed to install the part quite easily following Dan`s instructions.
The aluminium flange is very lightweight and doesn`t have any kind of negative effect.
After having a fellow gs`er who faced this problem, I'm so glad I taken care of the flange crack issue
Lucian is offline   Reply With Quote
Old 03-12-2014, 01:47 AM   #3
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
Hi,
If it's cracked in just one place / "spoke" then yes, you can still have it on, to strengthen the OEM flange.
Not sure if you can mount it if the spoke is cracked in 2 places/spoke and the part started to move towards outside. I am saying I am not sure because my part is a tight fit, perhaps you cannot press it in.
I have mounted some so far and it worked on all the flanges. But none of them started dezintegrating, they were only cracked.
Thanks,
Dan.
Old 04-11-2014, 06:19 AM   #4
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
Forgot to mention, they are machined so that they do NOT interfere with future FD oil changes.
They come for both spoke(hp&gsa) and cast wheels(the rest of 1200 hexhead models).
Thanks,
Dan.
Old 06-27-2014, 10:18 PM   #5
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,184
Well done Dan, once again you are thinking outside the box!
Old enough to know better....
Young enough to try it again
GS Addict is online now   Reply With Quote
Old 07-04-2014, 02:28 AM   #6
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
Thanks, it means a lot coming from someone like you ;)
Dan.
Old 07-06-2014, 12:15 PM   #7
KaptSlo
DirtBikeStuff.net
KaptSlo's Avatar
Oddometer: 275
Your website shows they are out of stock. Do you anticipate having more soon?
Thanks.
**The forum member previously known as ConTeacher **
All that is required for evil to prevail is for good men to do nothing. ~ Edmund Burke.
KaptSlo is offline   Reply With Quote
Old 07-06-2014, 01:07 PM   #8
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
Not sure why it appears you that is not on stock, because it is... I just tested and I get to the point of paypal login, so the transaction can be finished...
I will send you a private message with details, in case you want to order. But webstore management is out of my reach, sadly...
Thanks,
Dan.
Old 02-16-2015, 11:29 AM   #9
mondrage
Oddometer: 156
Originally Posted by Dan Căta View Post
Hi all,
Thanks,
Dan Cata.
Dan, that is correct.
I replaced a cracked Alu flange with the "correct" steel one plus the spacer.
The new flange worn the splines rendering my final drive (on a K12R) useless.
Ended up buying a complete swingarm with a good FD and flange from a similar bike.
I can't see your pics.
Very interested.
BMW K1200LT 2006
BMW K1200R: "Drophammer" 2006
Honda CB550Four 1978 (still away...)
BMW R1200GS 2008
mondrage is offline   Reply With Quote
Old 02-16-2015, 11:44 AM   #10
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
The pics were embedded and the source got them mixed up. I will come up with a fix ASAP.
Dan.
Times are GMT -7.   It's 11:20 PM.
