Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 02-08-2014, 11:09 AM   #61
joexr
Oddometer: 3,773
Originally Posted by joexr View Post
Stupidest post EVER !!! EVER !!!
EVER !
Old 02-08-2014, 11:39 AM   #62
lulo
Cochino Aventurero
lulo's Avatar
Oddometer: 1,227
One on the clutch and 2 on the brake at all times, as a matter of fact I've tried riding without covering my brake and not only it felt really unnatural, I was very choppy on the gas.
Felipe
"Deus Ex Machina"
lulo is offline   Reply With Quote
Old 02-08-2014, 03:39 PM   #63
joexr
Oddometer: 3,773
It's just whatever you prefer , there is no wrong. I only rest one finger on the clutch all the time , but use three to clutch. I don't cover the brake , but I only use one finger to brake , even back when with drum brakes. It feels odd to me with a finger constantly on the brake.
Old 02-09-2014, 09:09 AM   #64
markk53
jack of all trades...
markk53's Avatar
Oddometer: 9,240
Remind me to:
  • not shake hands with you considering finger strength to get decent braking with drum brakes or
  • not ride in front of you!
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 02-12-2014, 07:20 PM   #65
irishal
irishal's Avatar
Oddometer: 44
You guys use your brakes off-road? Speed scrubbers.
2013 DL650 ABS Adventure
OKC, OK
irishal is offline   Reply With Quote
Old 02-12-2014, 09:01 PM   #66
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,128
Originally Posted by CaliKarl View Post
I've been told to keep one finger on the front brake at all times while riding off pavement. Well, easier said than done. My hands just cannot make that happen. I'll look into getting different levers and/or bars, but is it sufficient to keep that finger close and ready instead of resting on the lever? Thanks for your input.
I use two fingers on the brake at all times.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 02-13-2014, 04:54 AM   #67
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 5,018
Do my best to cover the front brake 100% of the time.
bemiiten is offline   Reply With Quote
Old 02-13-2014, 05:22 AM   #68
35xj
Oddometer: 964
ive always ridden with a finger on each. its a really hard habit to try to bereak
35xj is offline   Reply With Quote
Old 02-13-2014, 06:43 AM   #69
rbrsddn
3banger
rbrsddn's Avatar
Oddometer: 2,838
When ripping twisties, or in traffic, I'll cover the front brake. Other times, not as much.
rbrsddn is offline   Reply With Quote
Old 02-13-2014, 12:14 PM   #70
Jan from Finland
Registered
Oddometer: 571
Originally Posted by farqhuar View Post
Same, but TWO, not one, fingers covering brake and clutch ALL the time.
Same, but not all the time. There are three exceptions.
1) If going gets really rough, like on 1ft washboards, you have to hang on the bars.
2) If you must brake NOW on tarmac. Having two fingers between the lever and grip makes it impossible to pull the brake lever all the way down. Brembo monoblock rides no need to apply.
3) After too many hours and days on the saddle, your hands may become sore or even cramp. Time to rest...
If you are ever attacked by lion, your best defense is to shove your arm down
their throat, grabbing the back of their tongue and hope help arrives quickly.
- Pro Travel Tip by Overland Journal
Jan from Finland is offline   Reply With Quote
Old 02-13-2014, 12:17 PM   #71
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,128
Debatable, but generally yes.
Bleed the brakes or adjust your levers, even with my rather massive track gloves I can stand my 675 (monoblocks) or Speed Triple (axial 4 pots) on their nose. With two fingers, I have a hard time controlling the throttle with all four fingers on the throttle.
That doesn't really matter how you hold the grip, hands worn out is hands worn out.
Old 02-21-2014, 11:16 AM   #72
snarf
WFO and clueless
snarf's Avatar
Oddometer: 659
Originally Posted by tkent02 View Post
Even when braking isn't the best thing to do.
That's a shortcoming of poor habits. If you shouldn't be braking.. don't use the brakes :)
-Derek
'If you wanna play tough, you better be stupid!'
snarf is offline   Reply With Quote
Old 02-24-2014, 08:32 AM   #73
Pedersoli
Oddometer: 95
That's why I cut down the clutch and brake levers, so you can use them with two fingers. If you saw them off and bend a little curl into the end about 1/2 inch high they work great.
Pedersoli is offline   Reply With Quote
Old 02-24-2014, 09:59 AM   #74
tkent02
Oddometer: 2,909
So why the fingers on the levers?
Silly idea.
tkent02 is offline   Reply With Quote
Old 02-24-2014, 02:05 PM   #75
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,128
Silly idea.
To reduce reaction time, not a huge thing at street speeds but a big deal at tracks where you are over a ton the majority of the time.
Times are GMT -7.   It's 04:21 PM.
