Old 02-02-2014, 01:35 AM   #1
gunsports OP
Oddometer: 75
Bike frontal cross section v speed perception
Perhaps some of the experts can help here. Down here, one of the main causes of bike/car accidents is where motorists will stop to turn into or cross a lane, causing an approaching bike to collide with the car. One of the 'excuses' for their action is that; they did see the bike; but did not realise the bike was travelling so fast.
I am both a biker and cager. So, I started paying special attention to this 'excuse'. And it's true; at least by my observation. It appears that one can better judge the approach speed of the wider car, than the approach speed of the narrower bike.
More, I have noticed that; where bikes have additional riding lights; arranged in a form of a triangle with the riding lights on the extremeties of the bike; judging their approach speed seems to be better and more accurate.
Any thoughts?
gunsports is offline   Reply With Quote
Old 02-02-2014, 03:04 AM   #2
scootrboi
scootrboi's Avatar
Oddometer: 1,584
Any thoughts?
The changing size of the triangle sounds significant.
42 years on a Heinkel Tourist
scootrboi is offline   Reply With Quote
Old 02-02-2014, 04:38 AM   #3
filmfan
Oddometer: 671
The triangle gives our range-finding binococular vision something to work with.
With cars, there are generally distinct, widely-spaced details to judge with, for example the headlights, whether they are lit or not.
It let your brain compute the changing angles of those points, more precisely, the rate of change, which gives you a perception of the speed.
filmfan is offline   Reply With Quote
Old 02-02-2014, 08:51 AM   #4
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 7,270
Any thoughts?
Combine the triangle of light with hi-viz, a white helmet, and lateral motion. Remain ready to avoid the pinheads who pull across in front of you anyway. I've been cut off while running code in an ambulance, so there's always a chance they're suicidal or something.
Some are guard dogs of the flock. Some herders, search/rescue, or companions. We Devildogs are those, and also retrievers. Hell is our blazing dogpark, our frigid swimming hole. The fallen are our tennis balls. We don't leave the fallen behind, even if the master has to bring them home for us. Semper Fi, my friends.
Kommando is online now   Reply With Quote
Old 02-02-2014, 09:03 AM   #5
manfromthestix
Lost in Space
manfromthestix's Avatar
Oddometer: 2,193
I put some high-intensity LED driving lights down low on my fork tubes and feel that they dramatically increase my visibility, both from the added brightness and the triangle of lights now visible to on-coming motorists or those I'm following. I've read about the theory and thought it was plausible, then have tested it and now totally agree. This isn't the best photo of what I'm talking about, but it's all I've got right now - the bike is buried in the garage 'cuz it's frigging Winter here .
The added light is also VERY NICE for night riding and the low-mount position doesn't blind on-coming vehicles.
Doug
"If it doesn't blow smoke and make noise, it isn't a sport!" - radio ad for shop in Bozeman, MT
manfromthestix is offline   Reply With Quote
Old 02-02-2014, 10:26 AM   #6
74C5
74C5's Avatar
Oddometer: 948
We sense approach or departure by the rate of angular growth or shrinkage of an object. This was originally couched as angular acceleration....perhaps more true at night when one might be able to only see two taillights while overtaking a slow, or stopped, object. Headlamps poses a more complex issue with being unable to look at them directly if too bright (hence the inherent lack of wisdom for high beams on a bike 24/7/365).
If the angle starts small, when it becomes slightly larger is probably more difficult to perceive. If the angle is larger to begin with, I think we can all agree that growth is easier to notice.
Another factor is the squish likelihood. How often do people fail to notice the 60,000 lb tractor-trailer that will give another vehicle a really bad day. Inherently knowing that you will get seriously messed up tends to elicit behaviors that help with continuing your genetic lines......for most.
Then again, some people are just stupid and not only pull out in front of motorcycles but, trucks as well.
R1200RT (R1100RT gone)
KLR650 - gone
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 02-02-2014, 10:49 AM   #7
orangebear
orangebear's Avatar
Oddometer: 1,253
i keep my head light turned off in good weather so that if i go over a bump a car driver wont think i have flashed him and pull out in front off me.
suzuki gsxr 600 srad sound fun bike
bmw r100gs i sold as it be came to unreliable.
road legal stomp pitbike sold
Klr 650 the worst ever made
Honda xl125rc powered by a cg125 block fun wee bike
orangebear is offline   Reply With Quote
Old 02-02-2014, 11:31 AM   #8
Idle
Oddometer: 703
Honestly, I get left turners pulling out at the last minute in the pickup much more often than when on the bike. I don't bother honking the horn, I just let off the gas a little and then continue on. (in the truck)
I believe the reason is that I can't really weave in the truck like I do on the supermoto. So I think that even with even a large profile vehicle, speed can not be judged accurately.
I always drive and ride a little faster than the speed limit, and on the bike I'm always riding to distance myself from the traffic around and behind me.
That puts me in a position (on my own) where I need to make myself visible. I stand when cresting hills, and gently ride back and forth in my lane most of the time.
The nano-second I see a left turning car appear on a side street, or in a center turn lane, I swerve towards them, and then back and forth a few times as I close in.
It's far from a smooth subtle weave, I push on the bar hard, it's an abrupt change of direction, followed by more of them.
My headlight beam is doing a figure eight (fork mounted) so it's flashing around like a search light, just not a very bright one.
I've had people start to pull out that could have easily made it. They then do a "I'm sorry" wave, and it's returned with a "no prob, thanks for waiting and not killing me" wave.
It is the changing of profile and direction that allows our speed to be judged more accurately.
More lighting is always a good idea if it doesn't blind anyone.
Idle is offline   Reply With Quote
Old 02-02-2014, 01:47 PM   #9
manfromthestix
Lost in Space
Oddometer: 2,193
That's why I went with the low fork-mounted LEDs. If I lived where there wasn't much traffic (or raced the Dakar or something) I'd have high-mounted lights, but here in Virginia there's a lot of on-coming traffic all the time. The Clearwater Lights "Glenda" model also have a cool feature in that you set the output on low beam to whatever you want with a rheostat switch, then when you switch to high beam they automatically go to 100% output. They are VERY bright on full power but not retina-burning when tuned lower.
I'm not so sure about all this weaving business... If it works for you that's great, but I think I'll stick to less dramatic methods of conspicuity. With all the traffic here I'd be weaving like a drunken sailor every inch of every ride.
Doug
Old 02-02-2014, 02:00 PM   #10
scootrboi
scootrboi's Avatar
Oddometer: 1,584
This face has kept me visible for many years.
Old 02-02-2014, 03:25 PM   #11
foxtrapper
Oddometer: 755
Any thoughts?
I stumbled onto that decades ago with an old vetter fairing and the running lights down low. I frequently got comments about how visible I was, and how well they could judge me. From friends on their bikes, to cars at traffic lights. The difference was and is substantial.
Big Harley's carry this advantage as well, it's their stock lighting configuration. They also have physically large running lights.
foxtrapper is offline   Reply With Quote
Old 02-02-2014, 05:35 PM   #12
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 969
And, riders that come in easy to see sizes, too. Right or wrong, I couldn't resist.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 02-02-2014, 05:50 PM   #13
kiwi_outdoors
kiwi_outdoors's Avatar
Oddometer: 107
yup
Any thoughts?
this is why they added ditch lights to locos on Caltrain (commuter rail, insecure right of way)
kiwi_outdoors is offline   Reply With Quote
Old 02-03-2014, 06:25 AM   #14
No False Enthusiasm
a quiet adventurer
No False Enthusiasm's Avatar
Oddometer: 4,455
I can remember passing a old farm truck on a moonless night on a two lane Farm to Market Road. I could see oncoming headlights, but they appeared to be far enough away to insure my safe pass.
I accelerated but stayed in 5th gear. Just as I drew abreast of the pickup, I realized that the oncoming vehicle was much closer... I grabbed 4th and pegged the throttle...
The oncoming vehicle was a Jeep CJ-5, with headlights mounted closely together, just outside of the grill. The narrow headlights made the vehicle appear to be much farther away.
It was a hellova wake-up...
NFE
No False Enthusiasm is offline   Reply With Quote
Old 02-03-2014, 04:46 PM   #15
dduelin
Oh boy that was close
Oddometer: 1,408
Yes, I agree. I also do not wear a seat belt in the car so I can be thrown clear in case of an accident or if my car flies off the road into a canal I can swim to safety. Sorry, I couldn't resist. I hope your lighting tactics work for you but I'm not sure the lack of lighting is a good thing when the intersection does not have a bump.
Seriously, anything that increases our visibility to other motorists is a good thing and studies document this. Lighting, clothing and helmet color all are factors.
Still, if you hold up a pencil at arm's length it's width completely blocks from view a head-on motorcycle just 60 feet away. It is incumbent on us to chose positions of relative safety in traffic and expect the worst and act accordingly.
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is online now   Reply With Quote
Times are GMT -7.   It's 01:28 PM.
