Old 02-04-2014, 05:15 PM   #1
Sp4rks OP
Oddometer: 247
Pissed 2002 KTM 125sx, possible engine seizure. Help would be appreciated.
Alright guys, here's the deal. Took my bike out for a little blast around the neighborhood because it's fun to do and I was having a rough day(yeah, this didn't help) at school(yep, still in High School, just a few more month). Kicked it over on the third try, little bit of blue smoke, slightly more than usual, but nothing to bad. Let it warm up a bit, little bit over a minute. Went slowly down the road, wasn't even reving out first, didn't even get 20 yards out then the engine just sort of stopped. Like straight up, nothing.
Now, here's the weird part(or maybe not, I've never heard of this happening with an engine seizing, so it's weird to me), I dropped it into neutral to roll it back(again, only 20 yards). Figured I'd forgotten to turn the gas on or something. After I got it home, I took it into first, I pulled in the clutch, and tried to roll it(going to try and pop the clutch for some reason), clutch wouldn't engage. Like it wasn't even pulled in. So, would an engine seizure do that? I think it would, but I'm entirely sure. If it's in neutral, regardless of seizure it'll roll because the transmission is separated from the engine. If the clutch in engaged, the transmission is still with the engine, hence why you can pop the clutch to get a bike to start if it's already rolling.
Backround: The bike has an unknown amount of hours on it(never put a hour meter on it, figured I'd put one on after my first rebuild). It was bought about 2 years ago(previous own was military, didn't ride much), and ridden mildly sense then for trail use only. 5 hour rides on an appx. once a month basis(p. Air Filter clean after every ride, oil change every two rides. High grade pump fuel(I'm really hoping this is just ethanol building up and finally taking it's toll, cheaper than an engine rebuild) mixed with high quality premix at 40:1.
2002 KTM 125sx:
Acerbis Uniko handguards, KTM Powerparts skidplate, FMF Shorty Exhuast, FMF Fatty Expansion Chamber, Renthal Sprockets, Renthal Chain, Pirelli Hard Terrain tires, SDG Seat, Acerbis and UFO plastic.
Sp4rks screwed with this post 02-04-2014 at 05:41 PM
Sp4rks is offline   Reply With Quote
Old 02-05-2014, 04:44 AM   #2
Spikester300
Roll Tide!
Spikester300's Avatar
Oddometer: 126
Pull the clutch cover off and see if anything broke and jammed the primary gear.
2007 Suzuki DL650 V-Strom
1976 Suzuki GT750 Waterbuffalo
Spikester300 is offline   Reply With Quote
Old 02-05-2014, 09:30 AM   #3
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,270
+1
pull the clutch cover. from there you can see what turns and what doesn't. pull the spark plug so there's no resistance turning things...you'll know real quick what happened.
current bikes
stainlesscycle is offline   Reply With Quote
Old 02-05-2014, 12:41 PM   #4
Neil E.
Neil E.'s Avatar
Oddometer: 299
Pull the flywheel cover too, with the plug out you should be able to turn the engine forward or backward using the flywheel. This might help when you watch the gearing on the other side. If something is broken instead of jammed, often you can turn the engine one way or the other until the broken piece wedges.
If it's still stuck solid, maybe there's been a "piston event". Remove the pipe and look in the exhaust port.
Neil E. is online now   Reply With Quote
Times are GMT -7.   It's 03:56 PM.
