Old 02-11-2014, 08:05 AM   #16
cliffy109
cliffy109's Avatar
Oddometer: 1,736
Originally Posted by jtw000 View Post
Get used to turning it off! ABS is a triumph of marketing over common sense. I've had it three bikes, it's as dangerous as bolting knives to your dashboard. On the first, a BMW R1200gs it kicked off on road and the brakes failed and I overshot the line by a few meters, enough to mean I had to swerve to avoid an oncoming car. Second, BMW F800gs, the brakes kept skipping every time I went over a bump, I nearly stacked it a number of times. It seems to work fine on my little BMW 650 but I switch it off routinely.
On my friend's KTM Adventure it failed in Bulgaria where the roads are very smooth. He overshot the stop and rode into the middle of three lanes of oncoming traffic. He was very nearly killed.
Just learn to ride and pull the fuse.
Based on your descriptions, I don't think the ABS is the problem.
cliffy109 is offline   Reply With Quote
Old 02-11-2014, 08:06 AM   #17
Pecha72
Oddometer: 4,220
Some people like the computers to do all the work of riding a bike for them. Personally I think that's funny. If you need ABS you shouldn't be allowed on a bike. If you think you need it, you probably shouldn't be allowed to vote.
for example Honda, the biggest 2-wheel manufacturer on the planet, seems to fully disagree with you, since they have declared several years ago they will be equipping all their road-going models with ABS.
But they of course have not got a clue about anything related to bikes, they just design & build them..
Countries ridden FIN SWE NOR DK EE LV LT POL SK HU RO BG GR IT AT DE CZ CH SMR LIE NL BE FR AND ES GBR LUX SI HR BIH SRB MK TR IR PAK IND TH KH LA MY ID AUS CR USA ZA LS SWZ MZ NA BW ZM ZW
Pecha72 is offline   Reply With Quote
Old 02-11-2014, 08:09 AM   #18
tkent02
Oddometer: 2,606
I guess I won't be buying any Hondas.
tkent02 is offline   Reply With Quote
Old 02-11-2014, 08:24 AM   #19
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
Another ABS vs non-ABS thread in the making????
Have tools, will travel!
Old 02-11-2014, 08:27 AM   #20
tkent02
Oddometer: 2,606
Not from me, I don't mind having it. I just wish you could shut it off on the fly, like a kill switch. Maybe I should rewire my kill switch to disable the ABS as well as killing the engine, being able to brake can be important more often than killing the engine.
Old 02-11-2014, 08:30 AM   #21
manfromthestix
Lost in Space
manfromthestix's Avatar
Oddometer: 2,250
I've never had any issues with the ABS on my BMW 1150GS, it just works when it's needed without any drama at all. I leave it turned on all the time (yes, even on gravel roads, wet roads, sand-covered roads, etc.) and never really notice it. This is my 3rd Beemer with ABS and I had the same experience with the other two as well. If used properly the ABS is not intrusive at all.
That being said, I've been riding for over 5 decades and learned to ride on bikes with shitty brakes, crappy brakes, good brakes without ABS, no brakes (flat-tracker, wooot!!!), and now brakes with ABS. The best advice I could give anyone new to ABS is to turn it off, learn to ride the bike without the ABS in all kinds of situations, then turn it on and let it be a safety margin like it was meant to be. If you are riding with full situational awareness, good skills, use engine braking, and can stop the bike within a safe distance without the ABS firing then it will be there when you need it in an emergency.
Enjoy your new toy!
Doug
"If it doesn't blow smoke and make noise, it isn't a sport!" - radio ad for shop in Bozeman, MT
manfromthestix is offline   Reply With Quote
Old 02-11-2014, 08:30 AM   #22
Pecha72
Oddometer: 4,220
"Some people like the computers to do all the work of riding a bike for them"
you have misunderstood something. The computer does nothing, unless you're about to lock a wheel. Also controlling the motorcycle, leaning, using throttle and gears, etc, the ABS computer has zero to do with any of those. It's just an emergency brake assist. And actually it does not brake for you, it cannot do that. All it can do, is release brake pressure from the hydraulic circuit momentarily.
Old 02-11-2014, 08:34 AM   #23
Pecha72
Oddometer: 4,220
there was one not so long ago.
I'd vote for an oil thread instead.
...Or HEY: what hydraulic fluid (other than what they recommend, of course) should I use on my ABS brake system??
Old 02-11-2014, 08:52 AM   #24
tkent02
Oddometer: 2,606
Usually at an appropriate time, sometimes not.
Old 02-11-2014, 09:17 AM   #25
Pecha72
Oddometer: 4,220
yes, for people like you it would be good to have an off-switch, so these useless systems would not get in the way of your superior skills.
Old 02-11-2014, 09:45 AM   #26
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
Well if you don't mind the annoying flashing lights, that may be easier than you think on a BMW and probably most other brands. But then if that BMW has the servos you sure don't want to disable that at the same time.
Old 02-11-2014, 10:01 AM   #27
tkent02
Oddometer: 2,606
Don't know about any servos, mine has no lights flashing, just a steady red light if ABS is disabled. The problem is you can't do it on the fly instantly, like when you need to brake and the ABS isn't letting you.
I think on the later ones you can. (F800GS)
Old 02-11-2014, 10:03 AM   #28
tkent02
Oddometer: 2,606
Has nothing to do with skills, sometimes on bumpy roads, paved or not, the ABS does not allow braking at all. Read what I wrote.
Old 02-11-2014, 10:47 AM   #29
Pecha72
Oddometer: 4,220
one thing to keep in mind is that 'ABS' is not one single thing. It is a common name for a system, that has many different generations and versions, and also the bike, that it is installed to, affects everything. So you can't generalize very much.
Old 02-11-2014, 11:04 AM   #30
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
Is your rebound dampening adjustable???
Times are GMT -7.   It's 05:49 PM.
