Old 02-14-2014, 01:24 PM   #91
tkent02
Oddometer: 2,772
Originally Posted by slartidbartfast View Post
I'm coming down on the same side of a disagreement as Wraith Rider for the first time ever.
If you overshoot into an intersection at a yellow light there are NO F***ING EXCUSES!! You screwed up and blaming your brakes is never going to change that.
I'm sorry, I need no excuse, I never shot into any intersection at all. I turned off the key and stopped normally. Another time I steered over to a smoother spot and stopped normally. None of the times the braking didnt work were hard stops at all, no where near any limits of traction. No slippery surfaces involved, not wet, not oily or sandy. Just routine stops, on a routine surface, with slight braking bumps in the asphalt. The same thing happens every time on washboarded gravel roads, whether you are braking hard or just slowing down a little bit. The brakes just don't come on.
tkent02 is offline   Reply With Quote
Old 02-14-2014, 01:26 PM   #92
Pecha72
Oddometer: 4,276
if there is, for example, a car engine, that is somehow prone to fail, can't there still be another type of car engine, that is not?
I don't get why every ABS system is the same either. They are not. (Even though it does make this discussion a lot more complicated).
Countries ridden FIN SWE NOR DK EE LV LT POL SK HU RO BG GR IT AT DE CZ CH SMR LIE NL BE FR AND ES GBR LUX SI HR BIH SRB MK TR IR PAK IND TH KH LA MY ID AUS CR USA ZA LS SWZ MZ NA BW ZM ZW
Pecha72 is offline   Reply With Quote
Old 02-14-2014, 01:30 PM   #93
tkent02
Oddometer: 2,772
I don't think anyone ever said they are all the same. I'm sure some are better than others, some probably work better on snow, some better in dirt, I have not tested them all. New ones seem to be a lot better than old ones.
Old 02-14-2014, 01:34 PM   #94
tkent02
Oddometer: 2,772
Is it possible that you might have been riding over a slick surface and the ABS actually saved your butt, preventing you from locking the front wheel and crashing?
In my case it was not. Like I said, I went around the block to do it over and over, got a similar result each time. It was not slippery. It was not wet. It was not sandy. Very easy stopping when the ABS was switched off.
Old 02-14-2014, 01:34 PM   #95
Pecha72
Oddometer: 4,276
But when somebody asks tips for using ABS, then somebody else tells to just switch it off, because his "had failed"?
Old 02-14-2014, 01:39 PM   #96
Wraith Rider
Oddometer: 1,604
Get the hell your bike to a mechanic and let him repair it.
Wraith Rider is offline   Reply With Quote
Old 02-14-2014, 01:40 PM   #97
tkent02
Oddometer: 2,772
Did someone say that? I must have missed it. What I said it that is should have a switch to allow you to disable it on the fly if needed.
The newer model (2010 or 2011, mine is a 2009) of my bike (F800GS) has this very switch, as standard equipment.
Old 02-14-2014, 01:40 PM   #98
tkent02
Oddometer: 2,772
There's nothing wrong with it, that's how they work. I have ridden others, exactly the same.
Old 02-14-2014, 01:48 PM   #99
Wraith Rider
Oddometer: 1,604
IF your description is correct, it's clearly broken. That's not how ABS works.
Old 02-14-2014, 02:16 PM   #100
jmq3rd
Oddometer: 277
According to quite a number of F800 owners, that is indeed how it works on that bike. I personally don't particularly care one way or the other. If I end up with a bike with ABS, I'll test it to decide if I like it or not. If not, I'll disable it.
I wouldn't pay extra for it though.
jmq3rd is offline   Reply With Quote
Old 02-14-2014, 02:30 PM   #101
tkent02
Oddometer: 2,772
Again, you prove your lack of knowledge by pretending to know everything.
That is indeed how it works.
Old 02-14-2014, 02:33 PM   #102
tkent02
Oddometer: 2,772
I don't disable it permanently, because it's great on snow, rain, slick surfaces in general. The slipperier the surface, the better it works. Usually I leave it on in traffic, turn it off on bumpy surfaces.
Old 02-14-2014, 02:47 PM   #103
Wraith Rider
Oddometer: 1,604
@jmq3rd
The F800 GS' ABS was tested by the magazine "Motorrad" in 2009 and did well. I prefer trusting professionels providing actual measured data over trusting someone on the internet saying "it doesn't brake".
Really, how tkent02 describes it, no ABS is intended to work. A working ABS on a working bike wouldn't interact at all under the circumstances he describes.
Old 02-14-2014, 03:13 PM   #104
tkent02
Oddometer: 2,772
@jmq3rd
Again, there is no one as dumb as one who will not learn.
Old 02-14-2014, 03:32 PM   #105
Wraith Rider
Oddometer: 1,604
Now that you know you are dumb, try to do better. Do some research on ABS and learn how it works.
Times are GMT -7.   It's 05:50 PM.
