Old 02-15-2014, 02:46 PM   #1
canoeguy OP
Oddometer: 324
I want to cross rivers...tell me how.
So let's talk about river/creek water crossings. I want some advice on techniques and some idea of how deep I can push my KLR(up to the intake I assume).
So "slow and steady" or "hold my beer and watch this"
And..... go...
canoeguy is offline   Reply With Quote
Old 02-15-2014, 02:50 PM   #2
farqhuar
Lone Wolf
farqhuar's Avatar
Oddometer: 1,213
Put the bike in your canoe.
farqhuar is offline   Reply With Quote
Old 02-15-2014, 02:52 PM   #3
canoeguy OP
Oddometer: 324
There is barely room for me in there! I am a white water boater...but I like your thinking.
Old 02-15-2014, 02:56 PM   #4
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,863
Ive done many creek crossings in my 40 years of trail riding,they can go smoothly or the wrong rock can be found at just the wrong time and you can be swimming, with no bike visible in a matter of seconds.
I personally will go almost any amount of distance to avoid deep water crossings,they can be a deal ender if the bike sucks too much water.
Especially a 4 stroke.
Normal 1.5' of water splash through crossings are no biggie.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 02-15-2014, 03:21 PM   #5
farqhuar
Lone Wolf
farqhuar's Avatar
Oddometer: 1,213
You got the wrong sort of canoe then - I put my Yamaha in a dugout canoe to cross the Bangui river from the C.A.R. to the Congo, fast flowing, deep and wide.
Lots of dugouts for rent on the banks of the river so no need to carry one with you on top of the bike.
Old 02-15-2014, 04:42 PM   #6
tokyoklahoma
75%has been25%wanabe
Oddometer: 1,722
Talking Dakar 2014
Sometimes you just can't help but get wet.
This is how the best in the world do it:
http://youtu.be/EQHqXSn2MMI
You can call me TKO
tokyoklahoma is offline   Reply With Quote
Old 02-15-2014, 04:46 PM   #7
Rango
Phaneropter
Rango's Avatar
Oddometer: 1,200
yabba, yabba, we want to see that.
Can we? Please, please, can we?
Moriunt omnes pauci vivunt
Rango is offline   Reply With Quote
Old 02-15-2014, 05:13 PM   #8
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,172
Your odds of succeeding improve if you can see the bottom.
If in doubt walk the crossing first. Sure your boots will get wet but, that is better than pushing your drowned out bike for miles with wet boots. Or possibly spending an hour disassembling your bike to get the water out.
Otherwise, if you are skilled, just carry your speed and let momentum and your ability to react get you thru.
Start slow then easy off
OhBoy is offline   Reply With Quote
Old 02-15-2014, 05:33 PM   #9
canoeguy OP
Oddometer: 324
So let's talk about what to do in the case of drawing in water. Obviously kill the bike as soon as possible. So where do I go from there. Not having horizontal heads on my thumper makes pulling the plug and draining water impossible.
Any good sources for obtaining a base knowledge on some enduro skills to apply to adv riding?
Old 02-15-2014, 05:40 PM   #10
tkent02
Oddometer: 2,597
Just go riding with some of the people on here that do this stuff all the time.
Really nothing to it up to the gas tank. If the bike is set up for it, you don't find a deeper spot, and you don't hit that big rock.
And if there's not much current. Or too slippery. Or the bank is too steep.
Slip the clutch, you can't go fast enough in deep water to keep the engine running without slipping the clutch. Keep it reved up some, it takes quite a bit of power to go forward, even slowly.
Was riding with this one guy, makes a big deal about this big water crossing, scouted it out to see where it was deepest, but we couldn't see it. Muddy water, thin film of ice on top, a few chunks of wood stuck in the ice. Didn't look like much but he was concerned. Finally he went, and got across with dry rims. Two inches deep, max.
The opposite has happened too, you get in there and find out it was much deeper than you thought… This probably happens a lot more often.
Have ridden a 1976 Honda 750 up to the gas tank for about a mile, down a flooded highway, back in about 1978. It ran fine.
tkent02 screwed with this post 02-15-2014 at 06:05 PM
tkent02 is offline   Reply With Quote
Old 02-15-2014, 05:50 PM   #11
Bucho
Oddometer: 2,035
The most important rule in deep water crossing.
1. Always let someone else go first
Bucho is offline   Reply With Quote
Old 02-15-2014, 05:52 PM   #12
bigdog99
CJ's bitch
bigdog99's Avatar
Oddometer: 278
Much technique depends on what you're doing. If you're on an "adventure" ride, alone, far from help, and -have- to cross, then I'd probably park and walk through the crossing with a stick, etc. and find out just how deep it is. If it's too deep to ride, you can often "push" it down stream-ish with the engine idling or off, and the bike leaned against your hip. If you're out with your buddies, then the "hold my beer..." method can make for a fun afternoon. Cover the kill swith with your thumb, if the engine intakes water under power it's easy to bend a rod.
Early season scoured rocks or sand: easier
Late season mud and mossy bottom: put on your snorkel
bigdog99 is offline   Reply With Quote
Old 02-15-2014, 07:21 PM   #13
Kommando
Kommando's Avatar
Oddometer: 7,389
And..... go...
The others covered many good points. Generally:
- Ride with others.
- Let somebody else go first.
- Scout it out on foot first, otherwise.
- Carry a tow rope/strap.
- Give it a bit of gas.
- Cover the killswitch and push it if the intake is going under. Drain the airbox and blow out the cylinder before trying to restart.
- Pull the sparkplugs and crank it to blow out water.
- Check your oil for water contamination.
- Be mindful of crocs/gators, snakes, hippos, or other critters that may not like you in their swimming hole.
- If it's moving fast, even if it's pretty shallow and just up to the pegs, consider your other options. Fast-moving water can be very dangerous.
Kommando is offline   Reply With Quote
Old 02-15-2014, 07:23 PM   #14
Sp4rks
Oddometer: 247
Well, obviously not like this.
Or like this.
2002 KTM 125sx:
Acerbis Uniko handguards, KTM Powerparts skidplate, FMF Shorty Exhuast, FMF Fatty Expansion Chamber, Renthal Sprockets, Renthal Chain, Pirelli Hard Terrain tires, SDG Seat, Acerbis and UFO plastic.
Sp4rks is offline   Reply With Quote
Old 02-15-2014, 07:34 PM   #15
Wlfman
Wlfman's Avatar
Oddometer: 1,291
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Times are GMT -7.   It's 01:54 AM.
