Old 02-16-2014, 08:02 PM   #46
Hesaid
Hesaid's Avatar
Oddometer: 1,306
Shouldn't be too hard. You might have to make your own out of local materials, maybe a rock and a log?
http://youtu.be/Q4tQhI5eO0I
Shorter, crashier highlight video here:
http://youtu.be/WJNf9s2PoeE
Sorry, I don't have much to add that hasn't been covered already. I'll just second the "Look before you leap" mantra.
MV
DR Feelgood , Tipsy Wombat, Pinkfoot, FatCat, and how they got their names: What the hell is a wombat? And now, the tales of their adventures.
Hesaid is offline   Reply With Quote
Old 02-17-2014, 04:53 AM   #47
KX50002
NooB, my ass
KX50002's Avatar
Oddometer: 1,825
Originally Posted by Jan from Finland View Post
Thank you, I didn't have video of the time I did that on my DR350, the pond was a but smaller and I made it all the way across.
Sent from my KFTHWI using Tapatalk
SOTGMOTT Some Of The Gear Most Of The Time
KX50002 is online now   Reply With Quote
Old 02-17-2014, 05:41 AM   #48
team ftb
Befuddled Adventurer
Oddometer: 1,730
I never stumble into this section of ADV and look what i found, some fun stuff!!
Footdragger hit all the major points on resuscitating a drowned bike. Also if you use an oiled foam air filter you can generally just squeeze (not wring) all the water out of it and let it air dry whilst you go through the fun a ridding the rest of your bike of water. Air filter drying on the seat of the 690 in the background whilst we drain the water out of the exhaust.
I hate lifting 300 pound bikes upside down so i just remove the spark plug, drain the float bowl and then some on the removed spark plug to rinse the water on it off, allow the plug to air dry with your filter and I just kick the bike through a bunch of times until there is no more fluids coming out of the spark plug hole. With no spark plug, kicking (even a hi compression 570 KTM) is dead easy.
Rather than hauling the bike on your back across rivers too deep to cross just use some thick branches threaded through the wheels and carry.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 02-17-2014, 11:52 AM   #49
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,753
It's do-able, or so I've been told...
--Bill
'73 R60/5 Toaster
Old 02-17-2014, 07:13 PM   #50
tyrsmkkyle
off the ground.
Oddometer: 250
This thread is so full of awesome!
tyrsmkkyle is offline   Reply With Quote
Old 02-18-2014, 03:30 AM   #51
PeterW
Oddometer: 2,666
That pic summarized my preferred technique.
"Throw the KTM in first"
Pete
PeterW is offline   Reply With Quote
Old 02-18-2014, 05:10 AM   #52
KX50002
NooB, my ass
KX50002's Avatar
Oddometer: 1,825
Pete
Old 02-18-2014, 05:37 AM   #53
Tinker1980
Tinker1980's Avatar
Oddometer: 1,395
This guy explains it all.
Tinker1980 is offline   Reply With Quote
Old 02-18-2014, 07:32 AM   #54
team ftb
Oddometer: 1,730
Pete
i think my friends have been listening to you.
Cheers,
Team FTB
Old 02-18-2014, 07:44 AM   #55
riverflow
Adventurous Commuter
Oddometer: 878
Originally Posted by ragtoplvr View Post
mossy crossings can be so slick that you can not walk them.
There is an invasive moss known as rock snot. If you encounter it, do not cross, the next stream you hit may not be contaminated and you will spread this stuff. That is assuming you make it across at all, which is unlikely.
One drop of water is all that is needed to spread this stuff.
If motorcyclists get to spreading this stuff, expect many more closings.
Rod
Have you posted this in the conservation thread forum?
-Tyler
'05 BMW F650 GS Dakar
"There is no such thing as bad weather, only the wrong clothes" ~ Billy Connolly.
riverflow screwed with this post 02-18-2014 at 07:57 AM
riverflow is offline   Reply With Quote
Old 02-18-2014, 07:50 AM   #56
cliffy109
cliffy109's Avatar
Oddometer: 1,709
I don't have a lot of experience in water crossing but I would like to share an experience that might help. Back in September, I attended the BMW GS Trophy Challenge Qualifier. One obstacle was a fairly long water crossing (probably 100' long and maybe 20" deep give or take). The bottom was known to be slate rocks laid into the road and it was pretty even with no hidden protrusions. The water came to a point just below the intake of the GS bikes.
I completed this in a very uneventful manner by riding slowly through and keeping my revs up. I then waited on the other side to see how others did it.
The slow guys just plowed on through with little drama.
Other guys hit it a little faster and you could see a bow wake build in front of the bike. As they approached the end, the wake hit the bank first and started coming back toward the rider. As long as they kept up the speed, they were OK but if they had slowed at that point, the wake would have hit them before they rode up the bank.
Still others rode faster and created a big bow wake and then they accelerated and rode through their own wake, flooding the intake and stalling them in the middle. I think 5 guys did this out of 70 riders. One other tipped over in the middle.
The lesson was, the slow and steady worked with eyes on the far bank. Too fast, or inconsistent was the way to fail. Every flooded bike was a boxer engine. There were no F800's or 650's that got water in the intake. The new GS has a much higher intake as well.
cliffy109 screwed with this post 02-27-2014 at 07:08 AM
cliffy109 is online now   Reply With Quote
Old 02-25-2014, 09:16 PM   #57
rt rider
Oddometer: 8
Cry
Make sure to have at least a couple of the carb vent lines routed as high up as possible. If all of the vent lines get submerged the bike will stall. Usually right in the middle of the crossing
rt rider is offline   Reply With Quote
Old 02-25-2014, 09:45 PM   #58
tkent02
Oddometer: 2,469
If they are routed up, when you drop the bike and gas runs out, it will not drain out of the hose, the carbs won't vent, the engine will have troubles. Like not running anymore.
Hence the T mod for deep water. Mount one end of the T up near the snorkel someplace, the other down low near the stock location so any water or fuel in the line can drain out. The engine will run until the snorkel floods, it will run a long time in deep water if necessary.
tkent02 is offline   Reply With Quote
Old 02-25-2014, 10:03 PM   #59
bonox
Tryin Hard
Oddometer: 2,972
Originally Posted by tokyoklahoma View Post
Sometimes you just can't help but get wet.
This is how the best in the world do it:
http://youtu.be/EQHqXSn2MMI
I remember watching this at the time thinking that either
a) the locals just always know where to stand for a good show, or
b) they painted the causeway with pig phlegm.
Either way, i've never trusted my riding buddies not to have the same train of thought, so I always let em go first :)
He immediately paid me the one of the highest compliments an Advrider can receive: "You're nuts!" (Alcan Rider)
bonox is offline   Reply With Quote
Old 02-27-2014, 02:19 AM   #60
CallMeBoog
Oddometer: 6,135
I will second the advice to look before you ford.
Sometimes things are a lot deeper than they look, and shit hits the fan rather quickly.
I was playing on my old 250 after a rainstorm, on an ATV trail following a powerline - pretty mild terrain. I was skipping through the puddles all day, as they were merely inches deep. I came upon this 'puddle' which looked the same as all the rest - murky and grassy. turns out that was some long grass, and a deep puddle.
Before I knew what happened, my 21" wheel disappeared and I went flying over the handlebars. I landed on the grass on the other side of the puddle. I was alone, and the bike was hard to get out. after about 15 minutes of farting around, it came out of the mud with a great sucking sound.
CallMeBoog is offline   Reply With Quote
Times are GMT -7.   It's 09:48 AM.
