Old 02-18-2014, 12:58 PM   #1
Scribe OP
£Bob£
Scribe's Avatar
Oddometer: 7,737
950 carbie float bowl gaskets
I took my carbs out to have a look at the needle valves. All looked good save for the float bowl gaskets, which have a little crud on them. But I can't find a source for just the float bowl gaskets. KTM has a gasket kit which costs the sun, moon, and a few stars ($180?), but I don't need them all. Just the bowl gaskets. Any sources? Anyone have a set lying about that they don't need?
"Do or do not. There is no 'try.'"
— Yoda
Man Ball Rolls Through Coloutahrado 2014!
Scribe is offline   Reply With Quote
Old 02-18-2014, 01:32 PM   #2
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,573
I've never changed mine. Just carefully clean the crud off w/ WD40, clean the mating surface and put 'em back together. No worries.
2013 KTM 690R Enduro
Chuckracer is online now   Reply With Quote
Old 02-18-2014, 02:29 PM   #3
Scribe OP
£Bob£
Scribe's Avatar
Oddometer: 7,737
That's exactly what I will do before spending that kind of money.
— Yoda
Old 02-18-2014, 04:17 PM   #4
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,280
I always put a fine coat of Mobil 1 grease on those rubber gaskets before they go back together. Never a problem.
Orangecicle is offline   Reply With Quote
Old 02-19-2014, 12:06 AM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,177
SUDCO would have these if anyone does.
"Son, you can't do both"
Old 03-31-2014, 07:43 PM   #6
Keith
Slabbing it
Keith's Avatar
Oddometer: 921
Has anyone found a source for these, before I start making calls tomorrow?
Random Crap
Keith is offline   Reply With Quote
Old 04-01-2014, 03:57 AM   #7
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
I bet an o-ring would work fine. Just have to find the right size.
I've been in a lot of these carbs and never needed to swap one yet.
Sporting Wood is offline   Reply With Quote
Old 04-01-2014, 04:33 AM   #8
Orangecicle
On a "Quest"
Oddometer: 3,280
Maybe you could find a source of a comparable O-ring. But, if you really want that piece of rubber from KTM, I think you have to buy the carb rebuild kit for something like $270 US. Like I mentioned before, put a little fine coat of Mobil 1 axle grease, and the original rubber part should seal.
Old 04-01-2014, 08:17 AM   #9
Keith
Slabbing it
Keith's Avatar
Oddometer: 921
I tried that last time, but whomever was in these carbs before me flattened out the gaskets. I was hoping the Factory Pro allen screws might help a little.
I thought about that o-ring idea too, might have to do some experimenting. The cheapest I've found that gasket so far is ~$130.
Random Crap
Old 04-01-2014, 06:44 PM   #10
ABuck99
0.0
ABuck99's Avatar
Oddometer: 651
60031099000- carb gasket kit is $139.03 + shipping from Munn- If you buy one before I get to it, please post up the contents; I am guessing this kit has float bowl gaskets, fuel inlet orings, TPS oring, U ring, diaphragm in the aircut valve- (anything marked by # in the fische)
FYI Mine looked pretty flat and had some crud growing on the oring as well- but cleaned with silicone grease- reinstalled, been back in and found the same build up again. They dont seem to be leaking so I wont be changing them for now.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 04-02-2014, 08:36 PM   #11
Keith
Slabbing it
Keith's Avatar
Oddometer: 921
I pulled my gaskets out of the float bowls today and cleaned them of whatever brown gasket adhesive/sealant stuff.
I'm trying this stuff out and will let ya know how it works.
http://www.permatex.com/products-2/p...sealant-detail
Random Crap
Times are GMT -7.   It's 08:46 AM.
