Old 07-03-2011, 05:22 PM   #1
farqhuar OP
Lone Wolf
farqhuar's Avatar
Oddometer: 1,143
Making my own snorkel - best place to buy flexible duct/hose?
10 days now till I leave Melbourne for the ride to the tip (Cape York).
I've decided I'm not going to being able to make it across some of the deep water creek crossings - particularly bridge creek - without a snorkel for the Burgman.
Now on the Burgie the airfilter is mounted top left inside the front fairing. Space is very tight in there and if I mount a permanent fixed snorkel I am going to lose steering lock (I could always avoid left turns, but hmm ), so what I am looking at doing is making a semi-permanent extension that I can push-in the inlet tube for each of the crossings, and then remove it in between crossings.
Not having needed to do this before (deepest water crossings I have done so far have been around 70cm) I'm looking for a bit of advice from some of you more experienced fellas. In particular, where's the best place to buy a thin wall flexible hose around 40-45mm external diameter and where would I buy a coil spring to fit inside so the hose retains its shape when I bend it a tight 90 degrees upwards (to what will hopefully be air and not H2O)?
Originally I was thinking radiator hoses but unless I strike lucky, and find one just the right shape, I doubt it.
farqhuar is offline   Reply With Quote
Old 07-03-2011, 05:27 PM   #2
greggs
Oddometer: 60
DIY Snorkle
Easy - Clark Rubber have hoses on all sizes. Swimming pool stuff is good.
Or, pinch the hose off a vacuum cleaner.
Report on how you go.
Deep water fording on a Burgman - gotta see a picture of that !
cheers
possum
greggs is offline   Reply With Quote
Old 07-03-2011, 05:31 PM   #3
farqhuar OP
Lone Wolf
farqhuar's Avatar
Oddometer: 1,143
Thanks for the tip possum, I'll drop into my nearest Clark rubber at lunchtime and see what I can find.
Old 07-03-2011, 05:33 PM   #4
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,889
sorry to ask but do you have to go the way that there are deep crossings,sorry dont know your route,
i would like to know myself if you could do the tip with out the deep crossings??? anyone?
You suck. And your mother dresses you funny.
I've just been to my first muslim birthday party. Musical chairs was a bit slow but F**k me, pass the parcel was bloody quick.
mickd is offline   Reply With Quote
Old 07-03-2011, 05:51 PM   #5
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,676
Farqhuar may need a snorkel where others wont...
Unless there is anyone else mad enough to take an overgrown step through scooter to the cape
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is online now   Reply With Quote
Old 07-03-2011, 06:25 PM   #6
Russ
Russ's Avatar
Oddometer: 16,481
There was a pic some where on ADV where a guy used swimming pool cleaner hose to make a snorkel .
Russ is offline   Reply With Quote
Old 07-03-2011, 08:16 PM   #7
farqhuar OP
Lone Wolf
farqhuar's Avatar
Oddometer: 1,143
mickd, no you don't have to worry about deep crossings if you go straight up the development road but if you want to do the Old Telegraph track you will.
.... and let's face it, that's why people ride to the tip - for the fun of the water crossings.
Trev, it wouldn't be an adventure if I wasn't doing the ride on something totally inappropriate to the task at hand.
Russ, the pool cleaner hose is what I have in mind - only problem is I have a tight right hand bend coming out of the existing filter orifice and I'm concerned the hose will collapse if I bend it too tightly.
The other option I'm looking at is finding a radiator hose with an existing 90 degree bend, if it is pre-formed that way then it shouldn't collapse.
Old 07-03-2011, 08:45 PM   #8
fayeslane
Rankest of amateurs
fayeslane's Avatar
Oddometer: 1,739
Air seeder hose from a farm equipment supplier. Stronger and more flexible than pool hose.
fayeslane
Faster than a speeding pullet
2002 Yamaha TDM900
various BMW airheads
fayeslane is offline   Reply With Quote
Old 07-03-2011, 11:44 PM   #9
itsgunnahurt
Gravity Enhanced!
itsgunnahurt's Avatar
Oddometer: 1,949
purple pig
Have you checked them out? seems lots of guys with 4wd get various rubber pipes and hoses from them.
I hate it when the voices in my head go silent...
˙˙˙buıuuɐןd ǝɹɐ sɹǝʞɔnɟ ǝsoɥʇ ʇɐɥʍ ʍouʞ ɹǝʌǝu ı
itsgunnahurt is offline   Reply With Quote
Old 07-03-2011, 11:46 PM   #10
Clancy
Clancy's Avatar
Oddometer: 5,924
+1 on Purple Pig. Huge range of stuff.
And he sees the vision splendid of the sunlit plains extended,
And at night the wondrous glory of the everlasting stars.
Clancy is offline   Reply With Quote
Old 07-04-2011, 12:04 AM   #11
farqhuar OP
Lone Wolf
farqhuar's Avatar
Oddometer: 1,143
The 'pig sounds like the place to go guys. Went down to Clark rubber during lunchtime, nothing that fits unfortunately so went to Repco and found a Fairlane radiator hose that may do the job - will do some experimentation tonight. If not, looks like I'll be paying the 'pig in Stud Rd a visit tomorrow morning.
Old 07-04-2011, 12:25 AM   #12
funguschops
Oddometer: 203
just a though
bunnings do grey water pipe which may be suitable
funguschops is offline   Reply With Quote
Old 07-04-2011, 12:27 AM   #13
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,978
Have seen old model Lasers pulling trailers as far up as New Mapoon via the Developmental Rd. Hardest part through to there was the entry into Laura from the crossing if it is chewed up a bit. The Developmental Rd is as boring as though.
Met a guy on an R1 who had just returned from the top and was heading into Lockhart River so it isn't too hard up the middle.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 07-04-2011, 12:35 AM   #14
STIGOSAURUS
STIGOSAURUS's Avatar
Oddometer: 23
Snorkel
I used pool cleaner hose on GS1200. Worked perfectly on a Cape trip.
BORN TO BE WILD.........made to behave.
STIGOSAURUS is offline   Reply With Quote
Old 07-04-2011, 07:38 AM   #15
farqhuar OP
Lone Wolf
farqhuar's Avatar
Oddometer: 1,143
Thank you for all the feedback guys.
I did a bit of fiddling around with the Fairlane hose tonight and lo and behold - I think it's gonna work.
It gives me 1.1 - 1.2m clearance - any thoughts on whether this is going to be enough height for Nolans or do I need more? If so, I can easily thread in and duct tape on a length of coil hose (pool cleaner / grey water, whatever).
Times are GMT -7.   It's 10:00 PM.
