Old 02-20-2014, 09:36 AM   #1
SauceSquatch OP
SauceSquatch's Avatar
Oddometer: 283
Sticky Shifting
I've been experiencing some sticky shifting recently, it's not terribly noticable but I am noticing it. I have just a month left on warranty so I'm also feeling keenly for any issues to be resolved.
It's a 2010 990, about 15k miles on it. For oil I was using Motul 4T (10-50w), then I went to mobile 1 and really started to feel the sticky shifting, then changed oil after only 1k miles and went to AMSOIL 20-25w, that felt good.
This bike is my daily commuter and trip bike so during heavy traffic I use a bunch of clutch, what is the expectancy on the clutch plates?
I've heard of some slave cylinders going bad and I'm curious how you diagnose that, what signs am I looking for?
At my 10k maintenance I cleaned the pilot jet, it was clean.
2010 KTM 990 Adventure
2006 DRZ
1978 Harley FX cut down
SauceSquatch is online now   Reply With Quote
Old 02-20-2014, 09:41 AM   #2
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,471
Ever bleed the clutch?
For Sale: 2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 02-20-2014, 09:46 AM   #3
SauceSquatch OP
Oddometer: 283
nope.
I'm googling how-to right now... got a good like to the procedure?
2006 DRZ
Old 02-20-2014, 10:08 AM   #4
AlxT
AlxT's Avatar
Oddometer: 68
+1 on bleeding the clutch and checking it's fluids status to see if there is any missing which would indicate failing slave cylinder.
Wouldn't really worry about the plates, I have 38000 klm on mine and the just barely slip for the past few thousand kilometers. That's fairly easy to diagnose, does the bike rev up without actually gaining speed?
AlxT is offline   Reply With Quote
Old 02-20-2014, 10:14 AM   #5
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,488
Originally Posted by SauceSquatch View Post
nope.
Just like bleeding brakes: open the nipple, squeeze the lever, close the nipple, release the lever- repeat until clean fluid comes out. Be sure to not let the reservoir run dry. (Yes, there are other ways, but you need only an 8mm wrench and a Phillips screwdriver to do it this way.)
Or, to do a really thorough job, I take the cylinder apart to clean, because the way it is designed, old fluid and moisture can rest in the bottom.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 02-20-2014 at 10:30 AM
MortimerSickle is offline   Reply With Quote
Old 02-20-2014, 10:46 AM   #6
SauceSquatch OP
Oddometer: 283
You mean rev in neutral without it wanting to creep forward?
Or do you mean when I'm moving from a stop light, do I rev the hell out of it and it feels like it doesn't go anywhere? If so, that's not the case.
From the stop light to full speed it feels just fine, I haven't rev'd it in neutral in a while. But I am always looking for a reason to make all the other dads in the neighborhood jealous
I'll get some mineral oil and bleed the clutch soon and report back.
2006 DRZ
Old 02-20-2014, 10:46 AM   #7
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,471
Bookmark this site:
http://www.ktm950.info/
Old 02-20-2014, 11:35 AM   #8
mousitsas
mousitsas's Avatar
Oddometer: 2,975
Make it fork oil
Old 02-20-2014, 12:07 PM   #9
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 594
To check for a failing slave cylinder, you may see a dribble of oil down there. You'll notice over a short (say 30 min) period an increasing drag on the clutch and the lever will come closer to tha bars when you want to disengage. Soon you'll have no clutch! i.e. the lever comes all the way to the bars, squashes the 3rd and 4th fingers that should be there, and you say to yourself "No! This is the kind of thing that happens to other people. Not ME" Thats worst case. There may be others in between working and not working.
To check your clutch for slip...ride down a straight road in a high gear. Give yourself some space. Wind on some throttle to put it under load. Pull the clutch a little and release straight away. The revs will shoot up and when you dump the lever the clutch should grip and instantly bring the revs down again to fully engaged. If it doesn't fully engage, back off the power and investigate. Ensure you have free play at the lever.
I must say if I was commuting in city traffic every day I would fit a Rekluse with new Slave cyl, and get gefr's stainless re-sleeve for the Master cyl. I'm doing that anyway
Other folk have found other ways around this but with the OEM system it's just a matter of time before you are stuck with no clutch.
950 SE
WR250R
950 ADV
ICERIDER screwed with this post 02-20-2014 at 12:19 PM
ICERIDER is offline   Reply With Quote
Old 02-20-2014, 07:58 PM   #10
BoznBlack
Go Big
Oddometer: 64
I've found that the brand and type of engine oil makes a big difference on the stickiness of my bike's shifting. Tried some expensive Silkolene 15W-50 full synthetic ester based oil, and it was noticeable how sticky the shifting was. Currently running Castrol racing fully synthetic 10w-50 and quite happy with the smooth shifting. Pretty cheap on Amazon too. About half the cost. If you've been experimenting with different oils, might just be the cause.....
BoznBlack is offline   Reply With Quote
Old 02-20-2014, 08:32 PM   #11
SauceSquatch OP
Oddometer: 283
Thanks for the advice everyone, I think I might ride this by the dealership and pop the master cylinder off in front of them and see if it is low on oil. Now that I'm reading about this and learning I think my slave was leaking a bit. I've been seeing oil in drops on the top of my skid plate. I thought it was coming from an oil extension hose I installed over chirstmas. Things are starting to make sense now.
If it's low then I'm sure that oil was coming from the slave and it should be covered under warranty. That's my cheapest and best option at this point. Then I can start saving for the new slave + rekluse
2006 DRZ
Old 02-20-2014, 08:34 PM   #12
MKJ
Married w/ Children
MKJ's Avatar
Oddometer: 593
You guys use your clutch for shifting? Imagine that.
MKJ is offline   Reply With Quote
Old 02-20-2014, 08:37 PM   #13
SauceSquatch OP
Oddometer: 283
I use my foot sometimes too
2006 DRZ
Old 02-20-2014, 09:20 PM   #14
Dusty
Dusty's Avatar
Oddometer: 1,302
Just another one to ponder...
I changed from motorex after a couple years then went to Castrol Power RS Racing 4T 100% Synthetic Oil - 10W50 for the last 3-4 years, i thought it improved the shifting.
My last oil change i had to go back to motorex, i ran out of my Castorol... I was blown away how much better it shifted, it even seems to shift better without the clutch, i cant even feel it going into gear i just know my foot moved up, that fukin slick... it was a huge surprise to me, i never expected that. Oh and didnt clean the oil jet on that change.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 04-02-2014, 07:03 PM   #15
SauceSquatch OP
Oddometer: 283
Just thought I would bring some closure to this thread. Turned out to be a leaky clutch master cylinder which was covered under warranty. I didn't even see it until I went to bleed the clutch, removed the boot on the lever and saw oil everywhere. The leak down by the clutch slave was a bad o-ring (or gasket) on the neutral sensor (so i've been told by the dealership).
Bike is still at the dealership and I'm pretty happy KTM backs their warranty throughly. That being said I'm pretty sure they are just doing a rebuild kit for the master cylinder, sounds like that will fail down the line as well, I'll be keeping an eye on it.
2006 DRZ
Times are GMT -7.   It's 01:49 PM.
