Old 02-21-2014, 10:16 AM   #1
Jbone11 11 OP
Jbone11 11's Avatar
Oddometer: 711
CJ designs Oil Drain vs DIY Oildrain Valve?
Spring is in the air and I have been hard at work getting the 990 ready for this season. One of the big things on the list is sorting this oil change business out. I was originally going to go with the CJ designs kit, but after a Hall of Wisdom session I came across the DIY oil drain kit (http://www.ktm950.info/how/Orange%20...l%20valve.html), basically a oil drain with a locking lever with the same thread size as the drain plug. Zip tie some plastic tubing or go to a pumbng supply store for a length of breaded tubing such as the one CJ's has and you've just saved yourself about $60!
Just wondering how many have gone the DIY route and what kind of experiences you've had. One thing I worry about with the valve is it clicking open by itself....doubtfull as it locks, but call me paranoid.
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
2003 Honda Hornet 600 (SOLD)
1969 BSA Royal Star - Let the Resurrection Begin!
Jbone11 11 is offline   Reply With Quote
Old 02-21-2014, 12:31 PM   #2
Douf
Limey Bitch
Douf's Avatar
Oddometer: 771
Actually the braided hose solution was originally posted here and many of us went the DIY route before CJ made a bunch of 'em for the lazy bastards who couldn't/wouldn't make their own.
http://www.advrider.com/forums/showt...highlight=douf
Douf
Douf screwed with this post 02-21-2014 at 12:39 PM
Douf is offline   Reply With Quote
Old 02-21-2014, 12:38 PM   #3
Black Hills
Oddometer: 1,183
next time you change oil take the tank drain plug to your local hydraulic fitter. have them make a hose (17" I think it what I went) with that thread on one end and a plug on the other. I just had them use a metric female couple on the hose with a plug for it. cost me less than $20.
Black Hills is offline   Reply With Quote
Old 02-21-2014, 02:20 PM   #4
666
Agnostic and Orange
666's Avatar
Oddometer: 1,318
I have DIY drain and it works just fine. I think it was 26$ for the valve.
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 02-21-2014, 02:28 PM   #5
Mikef5000
Oddometer: 2,030
Douf
I used the above link and made my own last year for about $20. No need for a valve, just a 12" hose with an adapter on top, and a plug in the bottom.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 02-21-2014, 04:57 PM   #6
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 666
Yep. I cut a notch in the cast "lower tank cover" piece and installed a Fumoto valve. The only down-side is that once the valve is closed oil continues to drip from the drain tube for a while. I just keep .1/4" x .5" machine bolt screwed into the end of the drain tube to prevent those nuisance drips after the job is done.
HeatXfer is offline   Reply With Quote
Old 02-21-2014, 07:22 PM   #7
woodchuckexc
Oddometer: 801
Lazy bastard here. Installed the CJ in minutes. I almost look forward to oil changes.
woodchuckexc is offline   Reply With Quote
Old 02-22-2014, 01:14 AM   #8
MudratinOz
Adventurer in training
MudratinOz's Avatar
Oddometer: 913
Same here, except I just slip a piece of suitable hose (that I keep for the purpose) over the end of the valve, don't even have to remove the tanks
KTM 2012 990 ADV ABS - BLUE
The orange does grow on you. You will not notice it at first..but it starts with a few innocent KTM stickers,.progresses to a KTM key ring, to KTM coffee mug and next thing you know, you have gone completely mad and start wearing orange tee shirts.It is a very bad infection..is this yeast infection (Bronx)
MudratinOz is offline   Reply With Quote
Old 02-22-2014, 01:49 AM   #9
rattis
rattis's Avatar
Oddometer: 1,146
Thumb Iirc
it's a M14 thread and you can make a kit for less than 20 bucks, go to your hydraulics shop and they'll sort it out for you, and it does not have to be with the metal braid on the outside, any hydraulic hose will withstand a lot of pressure and they've all got a braid on the "inside" anyway.
If Touratech made them you'd pay a stiff 100 bucks
Use the difference on worthwile stuff like petrol or beer
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 02-22-2014, 08:40 AM   #10
Falconfixer
It is what it is....
Oddometer: 554
Had my drain line made at a local hydro shop two weeks ago, cost me $36.
Falconfixer is offline   Reply With Quote
Old 02-22-2014, 08:49 AM   #11
Scribe
£Bob£
Scribe's Avatar
Oddometer: 7,322
Or you could cut a notch out of the bottom of an empty plastic water bottle and use it as a funnel. Cost=free.
"Do or do not. There is no 'try.'"
— Yoda
Man Ball Rolls Through Coloutahrado 2014!
Scribe is offline   Reply With Quote
Old 02-22-2014, 08:57 AM   #12
Dru
Hardly an Adventurer
Dru's Avatar
Oddometer: 568
I'm a lazy bastard. Plus, CJ is a good guy.
Dru is offline   Reply With Quote
Old 02-22-2014, 09:50 AM   #13
AJ990R
motorcycle guy
AJ990R's Avatar
Oddometer: 216
another lazy bastard here...time IS money for me, installed cj hose in two minutes during my oil service, not worth driving my full size pick-up truck around chasing parts down
"saddle up or shut up"
KaTooM North
AJ990R is offline   Reply With Quote
Old 02-22-2014, 10:56 AM   #14
JoeMongo
¿Por dónde?
JoeMongo's Avatar
Oddometer: 501
Question
Hmmnnnn . . . so I assume that you didn't have to cut a notch out of the cast aluminum gas tank cross brace? Not wanting to weaken that part is the primary reason I haven't considered any of these options.
'08 990 ADV, '03 DR-Z400S
Anything worth doing, is worth overdoing.
JoeMongo is offline   Reply With Quote
Old 02-22-2014, 01:01 PM   #15
DirtyADV
DirtyADV's Avatar
Oddometer: 2,240
Plate need to be opened up some, tried make it as small as possible and rounded of:
At least in Sweden hydraulic stuff with small bits and pieces and a short length of hose would probably not be far from what I paid for CJs and its nice and fancy in color ...not that it will be seen.
Still like to support him also with the stuff he have done for the the LC8 adventure is worth a few bucks!
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Times are GMT -7.   It's 04:54 AM.
