Old 02-28-2014, 01:35 PM   #31
keener
Speed changes you.
keener's Avatar
Oddometer: 959
Originally Posted by Chuckracer View Post
That's a good point.
Thinking about it today I thought of a solution for those who are hell bent on using the drain hose . Stick a strong magnet to the oil tank somewhere close to the drain hole using double sided tape or to the tip of the hose if its steel as close to the tank as possible.
Take the magnet off right before draining the tank.
Might work even better than the drain plug magnet.
04 ADV 950
keener is offline   Reply With Quote
Old 06-26-2014, 06:18 PM   #32
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Bringing this one back to life.
Like Keener, I'm hesitant to get this hose (though I really want my oil changes to be as easy as they should have been without me buying more parts) mainly because of the lack of the magnet.
Are you guys not worried about catching the metal flakes?
ben
______________________________
2013 KTM 990 Adventure Baja Edition
armourbl is offline   Reply With Quote
Old 06-26-2014, 06:22 PM   #33
ADVill
Oddometer: 609
Making mine(drain line) right now. Looking like around $30-40 ... To have someone make it for me.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 06-26-2014, 06:56 PM   #34
backpain
Oddometer: 52
Fumoto probably makes one that is the right size - they just don't market one for KTM )or motorcycles generally). They've been around for awhile. A few other manufacturers also. Avg price <$40 and a few different configs avail.
http://www.fumotousa.com
http://www.qwikvalve.com/size-chart.html
backpain is offline   Reply With Quote
Old 06-26-2014, 07:08 PM   #35
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
I'd like to make the one in the original post with the parts list, but with a rubber hose instead of steel braided. Again, the metal shavings/magnet thing is holding me back at the moment.
ben
Old 06-26-2014, 07:10 PM   #36
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Looks like the F-109n: ENGINE OIL DRAIN VALVE 12MM-1.5 is the right size -- don't take my word for it though please.
http://www.qwikvalve.com/fumoto-f109n-valve.html
ben
armourbl screwed with this post 06-26-2014 at 07:12 PM Reason: linked the wrong part originally. It is right now.
Old 06-26-2014, 07:24 PM   #37
Barekat
Looking to get dirty
Barekat's Avatar
Oddometer: 512
+1 on the Fumoto valve... makes quick work of oil changes. :)
ben
2015 KTM 1290 SA 229kg/160hp/104ft-lb... Ordered and waiting north of Toronto
Barekat is online now   Reply With Quote
Old 06-26-2014, 09:29 PM   #38
pdxthmper
pdxthmper's Avatar
Oddometer: 408
If your really worried about the magnet, add one to the engine drain plug, or buy one with it in it.
KTM 990 ADV MAKING GROWN MEN ACT LIKE HOOLIGANS
XR 650"L"
pdxthmper is offline   Reply With Quote
Old 06-27-2014, 04:22 AM   #39
advrider963
Oddometer: 7
I just did my first oil change. Based on what was stuck to the magnet on the stock tank plug I am not going to install the drain hose. As a side note I replaced the stock magnetic plugs with zip tie racing plugs, the magnets are much more powerful and the kit included a third magnetic plug that replaced a non magnetic plug on the bottom of the engine case.
advrider963 is offline   Reply With Quote
Old 06-27-2014, 04:54 AM   #40
ABuck99
0.0
ABuck99's Avatar
Oddometer: 609
ben
The plug on the bottom of the engine also has a magnet ( or at least mine does). Also, motion pro and a few others makes an oil filter magnet if you want redundancy.
I've installed the fumoto valve ( F109N 12mm 1.5 thread pitch) with a little clear PVC tubing from HDepot all together for about $30. IMO the valve is not a perfect solution. Downside is that the small lever that opens the valve can be hard to get to. The supplied gasket has a lot of squish room, so it's hard to get feel as to how tight it needs to be so it doesn't leak and still have the lever positioned for easier access. You have to be careful not to screw it in too far as the valve threads could break off in the bottom of the oil tank, & too loose it leaks, and in between the valve lever is not accessible. I like CJ's idea or similar home made better than the valve.
But The basic cheapo home made plastic water bottle funnel worked fine before I went with the valve.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 06-27-2014, 05:16 AM   #41
ADVill
Oddometer: 609
Yeah bottom plug has magnet on my '08
'00 520 EXC
'14 500 XCW
Old 06-27-2014, 06:32 AM   #42
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
We've been using these drain hoses on all our bikes for years now and have not seen any issues. We service the tank screen at valve checks when the tanks are off, about every 10,000 miles. But have seen some bikes with 20,000 plus miles and these was never cleaned. I've not seen any of these screens anymore than 1/8 of it's length covered with stuff.
Saves us lots of time on the road and servicing.
The main engine drain plug has a magnet on it, All years have this.
Because of the concern some had about losing the magnet pickup on the oil tank drain, we make an Oil filter cap that now has a magnet it in.
The oil filter flow pattern is from the inside to the outside, so if you want to inspect what your filter is catching, you need to cut open the paper pleats and look INSIDE. This magnet, magnetizes the steel filter body and helps pick up extra fine bits that pass through the filter. It also helps aids in filter removal.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 06-27-2014, 07:29 AM   #43
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Unless I'm missing it somehow, I don't see it on your site.
ben
Old 06-27-2014, 07:46 AM   #44
ADVill
Oddometer: 609
ben
http://www.cjdesignsllc.com/products...tank-hose-kit/
'00 520 EXC
'14 500 XCW
Old 06-27-2014, 07:53 AM   #45
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
I was talking about the oil filter cap with the magnet.
ben
Times are GMT -7.   It's 07:09 AM.
