Old 02-24-2014, 02:57 PM   #1
toates89 OP
Oddometer: 211
Bar risers vs New bars
I been looking at a set of bar risers to help with my height and it got me thinking. Wouldnt it be smarter to install higher bars that use the stock mount? I am thinking that spacers just add an element that could fail.
So is there anything wrong with adding 1" spacers?
Bike in question is a dr350.
Im 6'3" but i have exceptionally long arms so you could say i am 6'1".
toates89 is offline   Reply With Quote
Old 02-24-2014, 03:17 PM   #2
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,855
In theory, you are right and spacers/risers are a bodge - adding an additional element. I practice, however, I have never heard of a riser failure so it's probably a pretty safe alternative. Personally, I'd go with whatever solution is cheapest or easiest to find. In my experience, significantly taller bars are surprisingly difficult to locate.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 02-24-2014, 03:20 PM   #3
motorat
TBD
motorat's Avatar
Oddometer: 922
it is easier to change back with bar risers.
both my bikes have them because i like the bends on the bars i just wanted them a little higher
to ignore the facts does not change the facts
motorat is offline   Reply With Quote
Old 02-24-2014, 03:41 PM   #4
Jan from Finland
Registered
Oddometer: 562
You may want to change both. You may need higher AND straighter bar. Height is just one function when looking for better fit.
Spacers rarely fail. Buy known name. And don't use the cheapest bolts you can find. Grade 8 is your friend.
If you are ever attacked by lion, your best defense is to shove your arm down
their throat, grabbing the back of their tongue and hope help arrives quickly.
- Pro Travel Tip by Overland Journal
Jan from Finland is offline   Reply With Quote
Old 02-25-2014, 06:36 AM   #5
ct-ktm
Oddometer: 3,178
On my DR650 I put higher bars on the WR250 I put spacers..
Go with bigger bars..Differant bars are not exactly hard to find..I see thousands of choices on the Web...Don't forget to look into ATV bars also they usually are higher.. If you are over 6' you will not want to go back to lower bars ever.!!.. My.02
ct-ktm is offline   Reply With Quote
Old 02-25-2014, 06:37 AM   #6
toates89 OP
Oddometer: 211
I Guess if bar risers dont often fail, but cheap bars do. you best options are risers or exp bars.
Anyone have recommendations on bars the are 1 or 2 higher than stock? I wanna look at them before i purchase risers.
Old 02-25-2014, 06:39 AM   #7
ct-ktm
Oddometer: 3,178
If you pick your bike up once in a while..spend the $$$ get protapers..
well worth every extra dollar..They will last for years.
Old 02-25-2014, 06:39 AM   #8
Yooper_Bob
Yooper_Bob's Avatar
Oddometer: 2,690
13K miles of mostly dirt with risers on my 640 Adventure......zero issues.
Yooper_Bob is offline   Reply With Quote
Old 02-25-2014, 06:46 AM   #9
Auto-X Fil
Oddometer: 653
The Rox-type risers that pivot allow more positioning options. Simple spacers allow you to revert easily, but that's it. They are plenty strong, so I wouldn't worry about failure. Loosening and slipping is possible, but that's easy enough to fix mid-ride.
If you want taller bars, "ATV" bend will get you a lot of height. I ended up going with higher bars on my ride because I wanted to keep things light and simple.
Auto-X Fil is offline   Reply With Quote
Old 02-25-2014, 07:59 AM   #10
slartidbartfast
Oddometer: 4,855
ATV bend steel bars can be picked up very cheaply but are usually narrower
Old 02-25-2014, 07:39 PM   #11
250senuf
250senuf's Avatar
Oddometer: 2,315
If you change bars make sure that there is enough room for all the controls, dirt bikes/ATVs don't need as much room as does a dual sport.
You might need longer cables, especially if you get risers and a different bar.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 02-26-2014, 06:26 AM   #12
toates89 OP
Oddometer: 211
I am going to look for new bars after all. There is no point in trying to cut the stock bars(dr350 stock bars are solid at ends) so that i can use brush guards.
I am looking for bars around 1.5" higher with about the same pull back and width.
Old 02-26-2014, 06:41 PM   #13
sperz1
UnStudly Adventurer
sperz1's Avatar
Oddometer: 927
I have no experience in this.....
But, ATV Hi bend bars on the DR are the Bees Knees!
It takes a lot of water to make dual sporting look this hard.
2009 Buell XB12xp
1998 Suzuki DR350se
sperz1 is offline   Reply With Quote
Old 02-27-2014, 11:36 AM   #14
bbagwell
Oddometer: 94
I think ATV hi bars would be the ticket. I have them on my TW200 and CR hi bars on my DR650. The ATV's are definitely taller then the CR's.
1995 Yamaha TW200
2009 Suzuki DR650
bbagwell is offline   Reply With Quote
Old 02-27-2014, 07:29 PM   #15
Soldier311
Oddometer: 1,654
On a DR350? Will they work without purchasing longer cables?
"It's more fun to ride a slow girl fast than a fast girl slow."
1999 DR350SEX
Soldier311 is online now   Reply With Quote
Times are GMT -7.   It's 05:28 AM.
