Old 11-15-2013, 05:41 PM   #1
Wreckluse OP
Will work for beer
Wreckluse's Avatar
Oddometer: 444
Synchromate carb balancer
I have been waiting since July to see if Grok was going to start manufacturing the "Harmonizer" again. It has not happened, so when I found this deal
http://www.aircraftspruce.ca/catalog...clickkey=16307
on the Tecmate Synchromate TS-101, I ordered one.
If the price is honored, I should have it around Nov 28-30. I will post up once I see what happens and how it works.
Wreck
Indecision is the key to flexibility.
07 950 SM R
09 450 EXC dual sport
08 DRZ 400 SM Adventure
12 GasGas 250 Pro
Wreckluse is offline   Reply With Quote
Old 11-15-2013, 06:16 PM   #2
RsZk
RsZk's Avatar
Oddometer: 182
Subbed.
2013 ride report:http://advrider.com/forums/showthread.php?t=898211
2012 KLR 650, 2015 FJ 09
RsZk is offline   Reply With Quote
Old 11-15-2013, 07:38 PM   #3
SidecarDan
Noob
Oddometer: 10
I've also been waiting since July, I look forward to your update, thanks.
SidecarDan
2012 Ural Gear-Up
SidecarDan is offline   Reply With Quote
Old 11-15-2013, 10:52 PM   #4
Ravenslair
Oddometer: 481
They have already updated the price. Now it is $249
Ravenslair is offline   Reply With Quote
Old 11-16-2013, 08:43 AM   #5
joexr
Oddometer: 3,773
Get the Motion Pro.
Old 11-16-2013, 02:13 PM   #6
theregulator
Shut Up and Ride
theregulator's Avatar
Oddometer: 234
Just got my Carbmate and worked on my GSA. Super easy. Not sure how the Harmonizer could be easier, but, then again, I've never played with one.
Carbmate does everything my simple mind requires. Not sure i would use the additional features of the Synchromate. YMMV.
theregulator is offline   Reply With Quote
Old 11-16-2013, 06:06 PM   #7
avc8130
Oddometer: 1,570
I've used a Vacuummate and was very impressed. It is silly expensive for a home shop, but I borrowed it from a local boat mechanic.
The Synchromate and Carbmate are slightly simpler versions and I am sure everyone will be very happy with them.
I also don't see how the Harmonizer could be any better...
ac
avc8130 is offline   Reply With Quote
Old 11-16-2013, 09:51 PM   #8
joexr
Oddometer: 3,773
The gauge and electronic ones can get out of calibration. The mercury type don't unless you lose some mercury or what the new ones use instead.
Old 11-17-2013, 07:53 AM   #9
SidecarDan
Noob
Oddometer: 10
Do the Synchromate and Carbmate both show rpm's as well?
SidecarDan
2012 Ural Gear-Up
Old 11-17-2013, 08:42 AM   #10
joexr
Oddometer: 3,773
The Synchromate and Carbmate DO NOT allow you to look at all of your vacuum readings at the same time WHILE you're adjusting , the Motion Pro Syncmate does.
Old 11-17-2013, 10:44 AM   #11
theregulator
Shut Up and Ride
Oddometer: 234
I thought they do. Can you explain?
Old 11-17-2013, 11:00 AM   #12
avc8130
Oddometer: 1,570
He apparently wants to know what the ACTUAL vacuum is in a unit of measure. Like in-Hg or something.
I'm not sure why that is important, but to some it might be.
ac
Old 11-17-2013, 11:12 AM   #13
Wreckluse OP
Will work for beer
Wreckluse's Avatar
Oddometer: 444
Follow the link to Aircraft Spruce Canada in the first post. $152.95 Canadian. Prices seem to vary from $288 down to $153
Also $189 on Summit Racing website.
http://www.summitracing.com/int/part...-101/overview/
Here is a link to the manufacturer's description.
http://www.tecmate-int.com/synchromate_detail.php
07 950 SM R
12 GasGas 250 Pro
Old 11-17-2013, 11:16 AM   #14
Wreckluse OP
Will work for beer
Wreckluse's Avatar
Oddometer: 444
Motion Pro Sync Pro does not give you RPM.
07 950 SM R
12 GasGas 250 Pro
Old 11-17-2013, 02:44 PM   #15
avc8130
Oddometer: 1,570
RPM is useful when the bike has adjustable idle.
ac
Times are GMT -7.   It's 02:37 AM.
