Old 03-01-2014, 04:51 PM   #16
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Went straight to the garage and cut away some plastic. Thanks for the heads up.
ben
______________________________
2013 KTM 990 Adventure Baja Edition
armourbl is offline   Reply With Quote
Old 03-01-2014, 04:53 PM   #17
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Originally Posted by GJ990 View Post
Just checked mine. Same problem, can I just remove the black plastic thingy?
There is a matching plastic thingy on the other side. They are joined together in the middle. If you remove one you need to remove the other. It looks to me that these are kind of simple water dams or something of the sort. With them removed you can see that snorkel/pre-filter would get more fresh air. Tempting for sure to remove them.
ben
Old 03-01-2014, 09:33 PM   #18
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,704
I did the same thing. Mine had just started to bother the outside sheath.
I guess the Austrians are every bit as stupid as the Germans.
ben
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 03-01-2014, 09:43 PM   #19
MKJ
Married w/ Children
MKJ's Avatar
Oddometer: 570
Love my 990R. Too bad KTM is too arrogant to recall this flaw.
MKJ is offline   Reply With Quote
Old 03-02-2014, 06:51 AM   #20
GJ990
GJ990's Avatar
Oddometer: 321
Fixed this and the "other' issue
Well I fixed it and then decided to fix the other well known "design flaw" you would think KTM could have addressed by themselves.
Wiring Harness:
Mud guard cutting the swing arm:
Fixed:
Thanks to the OP for the heads-up on the harness. Much appreciated and another endorsement of the good folks on this forum.
990 Baja
GJ990 is offline   Reply With Quote
Old 03-02-2014, 07:02 AM   #21
rockitman4x4
ol retread
Oddometer: 94
Yeah thanks. I fixed mine while I was doing the oil change. I trimmed a nice hole for the wires to move through. Good job, thanks again.
Stay thirsty my friends
rockitman4x4 is offline   Reply With Quote
Old 03-02-2014, 07:10 AM   #22
sstewart
sstewart's Avatar
Oddometer: 1,058
Done
Fixed mine last night
sstewart is offline   Reply With Quote
Old 03-02-2014, 07:35 AM   #23
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,704
I'll get at my mudguard when I swap tires in a month.
...Dick
Smugmug
Old 03-02-2014, 08:29 AM   #24
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,678
i just checked my 990, and the sheathing is broken.... i will fix this before taking it out again.
thanks again neptune for posting this up, it is very appreciated!
Originally Posted by DUCATIJAY
Don't quote me in your signature, you make me sound like an a55hole...
2015 Rides: Katie M Big girl, Berg Hoon'icycle, Katoom 3hunny (pic)
Rodknee is offline   Reply With Quote
Old 03-02-2014, 09:59 AM   #25
dondesmo
Senior Squid
dondesmo's Avatar
Oddometer: 95
I just checked mine on my '11 990 Dakar. I have 7500 miles on the clock and so far things look okay. The wire lome is really tight when the steering head is at full lock to the left, so I will keep a check on wires until I pull the tanks for the valve check. It looks to me that the cover that applies pressure to the wires can be relieved in that area eliminate the problem
dondesmo is offline   Reply With Quote
Old 03-02-2014, 10:12 AM   #26
tacosupreme
tacosupreme's Avatar
Oddometer: 278
I took the covers off without removing any body work. Just lock the steering to the left. The screw is the same size as the small torx that hold the glove box on. My sheathing wasn't broken, but the wires were. Unplug the wires and carefully slit the sheathing back and you will see where the wires are pinched. Don't assume your wires are ok, look at them.
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Old 03-02-2014, 10:24 AM   #27
dondesmo
Senior Squid
dondesmo's Avatar
Oddometer: 95
Thanks. I needed something to do today while it's raining. So much for waiting until I do the valves.
Old 03-02-2014, 02:30 PM   #28
Vector Leto
Vector Leto's Avatar
Oddometer: 169
Part number
Does anyone know the part number? I did some searching, but I'm not really sure what I'm looking at.
Looking for the next cool thing.
Vector Leto is offline   Reply With Quote
Old 03-02-2014, 03:40 PM   #29
2kool2be4gotten
2kool2be4gotten's Avatar
Oddometer: 39
Thanks of the heads up!
Checked my '12 990 ADV - 10,000 KM - same pinch point and sheath wear, didn't open it up to check the wires but i'd bet at this point the damage is done (plan to call my dealer in the AM as a warrantee issue).
Regarding part numbers - this post LINK (which was provided by the OP) lists 60111066050 - Munn has the part listed for about $100..... (before Chip's discount) - check your year / model
Thanks to the OP (and others) that have posted this issue!!!
knobby tires on a gravel road....
2kool2be4gotten is offline   Reply With Quote
Old 03-02-2014, 03:50 PM   #30
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,071
From your picture it looks like KTM changed the routing just below the ign switch. Yours show the wires zip tied up to the bottom of the switch. Mine just had the wires hanging with a small zip tie Very Tight around the sheathing. That's where mine broke. The replacement switch had no zip tie.
The best solution is for the wire to make a big loop, so it bends across its entire length.
"Son, you can't do both"
Times are GMT -7.   It's 02:18 AM.
