Old 06-05-2014, 09:02 AM   #91
grant22
grant22's Avatar
Oddometer: 479
I finally got my new ignition switch harness so it was time to install it.
Although I tried cutting back the plastic filler piece, it still seemed the harness didn't want to slip back and forth into the frame as I turned the bars. I cut more and more but it never really slipped, like it should to keep the bending of the wires over and over.
The harness is lengthy, so just removing the plastic filler pieces would solve the wire bending issue, but the harness would probably flop out.
I chose to zip tie the harness to the frame, but the zip ties are applied loosely to allow for slippage.
I have all the confidence in the world now in the harness.
grant22 is offline   Reply With Quote
Old 06-05-2014, 09:18 AM   #92
johnno950
Oddometer: 1,076
Sub standard layout of the wiring looms etc has been a thing with the ktms for years now,lets hope voncouldntgiveafuck is nearly ready for retirement from the assembly line.
johnno950 is offline   Reply With Quote
Old 06-05-2014, 10:08 AM   #93
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,518
This particular issue was a design problem, not assembly. Amazing they kept building it this way. My bike started dying intermittently when turning. Imagine if some took a left turn in front of oncoming traffic and had the bike stall? This would be similar to the recent GM ignition switch issue.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 06-09-2014, 04:24 PM   #94
PopQuiz
PopQuiz's Avatar
Oddometer: 27
My thanks to the OP. Checked mine today and sure enough...pinched and cracked sheathing with a crease in the sheath of one wire, but no apparent damage. Offending piece cut and sanded. It is easy to remove with right fairing off...except for that damn screw falling and ending up somewhere unknown...grrrrr hate when I do that. Luckily I have a good bin of screws and found one that worked.
Current: 2012 KTM 990R
Past: CT 90, KX 125, IT 250, Sonic 500, XS 1100
PopQuiz is offline   Reply With Quote
Old 07-14-2014, 04:39 PM   #95
micahsmith50
JonSmith
micahsmith50's Avatar
Oddometer: 2
Pissed Yup!
This just happened to me, on my 2013 KTM 99o, WTF is only 600 miles on it, it's going back to the stealership tomorrow.
micahsmith50 is offline   Reply With Quote
Old 08-28-2014, 09:55 AM   #96
NeptuneTriton OP
Oddometer: 262
Another victim claimed by the pinched ignition harness. Keep checking your bikes fellas!
http://www.advrider.com/forums/showt...4#post24950344
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
-Abraham Lincoln
Kronreif, Trunkenpolz of Mattighofen - Model 990, Adventure Baja
NeptuneTriton is offline   Reply With Quote
Old 09-06-2014, 05:45 PM   #97
RhodeHazard
ex halligan hooligan
RhodeHazard's Avatar
Oddometer: 658
KTMpossible
I just checked mine while performing another repair and found both wires to the ignition switch had broken through the insulation to bare wire. It was only a matter of time before this would have stopped her dead. Thank you!
I cut the broken wires out and soldered in new bits. I used wire that is more flexible and provided more length. I also trimmed the upper corner of the blocking plate to provide a bit more flex.
As I look at the stock setup, I believe the other issue is the rigid wires used in the ignition harness that tend to break rather than bend.
Ernie Young
'12-KTM-990adv '02-KTM-400exc '81-HONDA-XL185s
MotorBikeArtist.com motorcycle drawings * Turf & Surf: NE-NB 2011
RhodeHazard is offline   Reply With Quote
Old 09-23-2014, 07:55 PM   #98
deeve
DumbA$$
deeve's Avatar
Oddometer: 1,260
I checked my wire harness on the right side and the outer loom looks good. No hard kinks or anything. Would the collective suggest making sure the slack stays or open it up to make sure everything is good?
2010 KTM 990 Adventure-Nuclear Fusion Powered
deeve is offline   Reply With Quote
Old 10-13-2014, 08:49 AM   #99
RumRunner
Sit there, turn that
RumRunner's Avatar
Oddometer: 4,744
This thread really should be a sticky
DW
I became friends with someone just because they rode motorcycles from no-place to no-where.
RumRunner is offline   Reply With Quote
Old 11-13-2014, 05:02 PM   #100
RumRunner
RumRunner's Avatar
Oddometer: 4,744
TTT
And a pic for the trouble...
DW
Old 02-09-2015, 05:33 AM   #101
tntroutstalker
Oddometer: 14
Same issue on my 12. Good thing I found this again right after I had put it all back together from a ABS switch install. Was a quick 10-15 minutes to pull and cut the corner off the offending plate. Everything looked good but may expose the wires for a internal look next time I have it pulled apart.
tntroutstalker is offline   Reply With Quote
Old 02-10-2015, 10:07 AM   #102
KTM990R
Oddometer: 6
Thank you !
I just looked my 990R 11" and had cracked wire protection. Repaired that and cut the plastic cover to make bigger hole for wires.
So thank you anyway maybe one day bike would have stopped because of that in the middle of nowhere.
KTM990R is offline   Reply With Quote
Old 03-07-2015, 08:06 AM   #103
ripter
Pig Flogger
ripter's Avatar
Oddometer: 19
I had my bike apart for a canisterectomy, and install an open air filter system when I noticed that this wire harness was completely FUBAR. I literally only have two wires that are not completely severed, and one is the green... The thing I'm still trying to figure out here is how the bike is even running at this point?
I still think KTM should change its name to WTF!
ripter is offline   Reply With Quote
Old 04-10-2015, 01:12 PM   #104
sline
Oddometer: 9
Thumb Broken orange wire on 2011 Adventure 990 R
Bike was conking out a lot, more so when making right turns. Took it to Fay Myer in Centennial, CO and they charged me $600+ to replace the clutch. Didn't fix it. Read this post, opened up the wire casing, and my orange wire was broken all the way through. The sheath on the outside looked fine though. Fixed it for free myself. Thanks for the post!
sline is offline   Reply With Quote
Old 04-15-2015, 05:25 PM   #105
outbacktaz
outbacktaz
outbacktaz's Avatar
Oddometer: 659
Yep, it happened to me too!!
So, how the hell do I remove the ignition switch to repair it?
I rode the bike to work yesterday, and when I parked it, I moved the handle bar all the way to the left and the bike stopped...
I figured I had a wire problem. So when I came back Home, I parked it in the garage with the switch on, turned the bar to the left and it turned off again!! Tonight, I took it apart to check it, I disconnected the 2 plugs, but do I have o fix it in situ?
Or can I remove it to repair it on the bench??
Marty aka Outbacktaz!!
__________________________________________________
Only the dead have seen the end of War! George Santayana
To sin by silence makes cowards out of men! Ella Wheeler Wilcox
Peace is mostly valued by those who are sworn to protect it! Unknown
outbacktaz is offline   Reply With Quote
Times are GMT -7.   It's 05:11 AM.
