Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 03-01-2014, 11:22 AM   #1
RichyRich68 OP
Oddometer: 36
KTM 1190 adventure std MTC failure, won't start. Need help.
Bike has been in garage un-riden. It has less that 100 miles on it. Went to show some family the awesome sound and the bike won't start. Hard MTC failure. Battery fuse does not fix problem. Help!
2014 KTM 1190 Adventure Graphite - 2008 KTM 505xc ..................Go orange or go home!.........................
RichyRich68 is offline   Reply With Quote
Old 03-01-2014, 11:38 AM   #2
Daveman
Oddometer: 36
What do you mean with "MTC FAILURE"? Does it show that on the display?
Daveman is offline   Reply With Quote
Old 03-01-2014, 11:57 AM   #3
RichyRich68 OP
Oddometer: 36
Yes. And shows in the code failure screen when you scroll to it.
Old 03-01-2014, 12:03 PM   #4
kag
Wander Lust
kag's Avatar
Oddometer: 1,530
Couple of things....good charge and connection with battery. On center stand or side stand and in neutral. Kill switch is on run. Cycle key a few times. Then hard boot it, disconnect battery and then reconnect
I am sure you checked these but just asking
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 03-01-2014, 12:30 PM   #5
RichyRich68 OP
Oddometer: 36
12.46vdc. Center stand in neutral. Kill switch in proper position. Cycled 20 plus times before going for the hard reset option. No joy.
-- called a local shop which provided the service I expected, no help. Nobody knows much of anything on this bike.
-- put the bike back together. Was ready to give up and tow it to a shop. One more turn of the key for t he heck of it. Started! Wtf over!
Old 03-01-2014, 01:58 PM   #6
kag
Wander Lust
kag's Avatar
Oddometer: 1,530
I am glad it came on line and started. Strange shit no doubt. I see your in the bay area...just curious what was the ambient temp in your garage?
Old 03-01-2014, 02:25 PM   #7
RichyRich68 OP
Oddometer: 36
Low 60s. I'm 7 weeks into my 12 week recovery from ankle surgery and so haven't ridden the bike except up the neighborhood. I would have normally had 3000 miles on this bike by now. My concern obviously is that this could happen somewhere where this is a big deal. 2nd time with no obviousness root cause nor clear recovery procedure.
Old 03-01-2014, 02:32 PM   #8
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 398
Could there be a loose connector in the tail where the MTC sensor is mounted?
RobZorba is offline   Reply With Quote
Old 03-01-2014, 05:12 PM   #9
speedy 1
Wizard
Oddometer: 8
12.46 vdc may not be enough
In the winter when it's cold 13.2V is what mine takes to start
Get a battery tender with a quick access pigtail for long stays in the barn
When it's going to be under 30F overnight put a tender on so you know it will fire in the morning
speedy 1 is offline   Reply With Quote
Old 03-01-2014, 05:38 PM   #10
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,099
Yeah, I'd start with the battery tender. A few garage starts of the new bike, and couple rides around the neighborhood...this is taxing the battery and it's not running long enough, or at high enough rpms to re-charge it.
2005.5 KTM 950 Adventure
2005 Ducati ST3
Chuckracer is online now   Reply With Quote
Old 03-01-2014, 05:54 PM   #11
cycleman2
Oddometer: 532
Most new bikes have a parasite draw that over a fairly short period of time will draw the battery down just enough that it may not start. The ECU looks for the proper amount of voltage before it will let the fuel pump etc start. As others have noted, put the battery on a tender and see if it improves.
Once you are riding the bike and it is running OK, let the bike sit for 24 hrs and then check the resting voltage of the battery. If it is below 12.6 then I would replace the battery. A good resting battery should maintain in excess of 12.6 for a 24 hr period.
1971 R50/5 Cafe Project
2013 DL650 Adv
cycleman2 is offline   Reply With Quote
Old 03-01-2014, 06:55 PM   #12
RichyRich68 OP
Oddometer: 36
Hmmmm. Interesting idea. I did start banging on the rear subframe with my fist. Partly out of frustration but partly to give the lean sensor a wiggle. If it happens again I will record each step to more accurately determine where the problem is coming from.
Does anyone have diagrams of where these components are? Start peeling back the skin, you will see what I mean.
Thanks for all the great ideas guys.
Old 03-02-2014, 02:51 AM   #13
rompe
Oddometer: 58
Before start playing with the electronics, I would substitute the battery for a GOOD one. OEM battery it's definitively not enough for this bike.
Sent from my XT1032 using Tapatalk
My other toy has tits . . .
rompe is offline   Reply With Quote
Old 03-02-2014, 09:22 AM   #14
DirtJack
DirtJack's Avatar
Oddometer: 1,452
Good advice. IMO the OEM battery has a marginal amp hour spec for the big motor. Short runs with winter electrical equipment on may leave the battery in a partially charged state for the next time it is used. Just wrenching on mine to install LED aux lights without riding (can't ride as my seat is out at James Renazco's place) had its toll on my battery. The bike could benefit from a bigger battery. Anyone know of larger amp hr which will fit?
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 03-02-2014, 03:50 PM   #15
RichyRich68 OP
Oddometer: 36
Problem is back. Hasn't even been off the stand since the last time.
Times are GMT -7.   It's 03:39 PM.
