Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 03-01-2014, 02:39 PM   #1
JoeShoreline OP
Oddometer: 59
Ktm 1190 r adventure gearing?
Has anyone come up with a suitable gearing selection for off-road for the 2014 KTM 1190r? It seems to be geared tall enough for the road but way too tall for local fire roads I would like to make a change to the countershaft sprocket and drop one or possibly two teeth tried it here?
JoeShoreline is offline   Reply With Quote
Old 03-01-2014, 02:41 PM   #2
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,990
Dropped one on the front....worked out great....
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 03-01-2014, 02:50 PM   #3
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,414
I went up
Two in the rear. No chain mod required
ebrew is offline   Reply With Quote
Old 03-01-2014, 03:25 PM   #4
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 401
gearing
doing the same as nowwhat.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is online now   Reply With Quote
Old 03-01-2014, 07:50 PM   #5
JBird
Retriever
JBird's Avatar
Oddometer: 853
Went up 3 on the rear. Stock chain
JBird
KTM 1190R
KTM 950SMR
'08 Goldwing
'98 Golden Retriever
JBird is offline   Reply With Quote
Old 03-01-2014, 08:39 PM   #6
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
16 on the front.
PPiA is offline   Reply With Quote
Old 03-02-2014, 10:21 AM   #7
DirtJack
DirtJack's Avatar
Oddometer: 1,598
42 42 44 45 % 17 16 17 17
2.47059 2.625 2.58824 2.64706
Here are the ratios, stock 17/42, 16/42, 17/44, 17/45
Hard to notice the difference between 16/42 and 17/45. Nice that all of these can be done with the standard chain. IMO, changing the front is easier than the rear.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 03-02-2014, 12:02 PM   #8
kag
Wander Lust
kag's Avatar
Oddometer: 1,719
And here I am wanting it geared higher.....
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 03-02-2014, 01:25 PM   #9
DirtJack
DirtJack's Avatar
Oddometer: 1,598
Ok, so http://www.cs.trinity.edu/~jhowland/...00&final=17r42 is a link to compute:
Speed table for 2014 KTM 1190R
Primary drive ratio = 40r76
Rear Wheel Circumference = 2127 mm
Gear ratios = 12r35 15r32 18r30 20r27 24r27 27r26
RPMs = 1000 1500 2000 3000 4000 5000 6000 7000 8000 9000
Final drive ratio = 17r42
_ 1000 1500 2000 3000 4000 5000 6000 7000 8000 9000
1 6 9 12 17 23 29 35 41 46 52
2 8 12 16 24 32 40 48 55 63 71
3 10 15 20 30 41 51 61 71 81 91
4 13 19 25 38 50 63 75 88 100 113
5 15 23 30 45 60 75 90 105 120 135
6 18 26 35 53 70 88 105 123 140 158
So at idle (1500 rpm) your scooting along at 9 mph. Lot's of clutch slipping on single track.
You can copy/paste the above link and edit the very last entry 17r42 to what ever final gearing you want to use (say 16r45) to see what speeds you get with that gearing.
16/45 final gearing.
2008 KTM 690 Enduro
Old 03-02-2014, 01:37 PM   #10
kag
Wander Lust
kag's Avatar
Oddometer: 1,719
Ummmm......lots of time on your hands.......Like me .....
I have no real intention of gearing it higher....was occupying my time on a very cold and snowy day. So ready for winter to be over.
Also glad I gave up of Aeronautics and went medical prettier girls and all.....
Tarmac and gravel is about all I will do so gearing it lower for me serves no function and its already damn fast
Old 03-02-2014, 01:46 PM   #11
DirtJack
DirtJack's Avatar
Oddometer: 1,598
Yea, former education which is pretty much useless now.
2008 KTM 690 Enduro
Old 03-02-2014, 02:44 PM   #12
Harold Waikiki
Oddometer: 401
Wow!
I am WAY to dumb to understand/figure this out!!
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
Old 03-02-2014, 04:49 PM   #13
JoeShoreline OP
Oddometer: 59
Thank you for this post that's exactly what I was looking for. I am more than likely going to go from 17/42 to 16/45. That way the bike will still retain its street ability while being suitable for off Road. After all who here really has a use for 160+ miles per hour. On a sidenote; 1 tooth in the front is equal to three teeth in the rear.
Old 03-02-2014, 05:06 PM   #14
DirtJack
DirtJack's Avatar
Oddometer: 1,598
Click on the link in the message and it will take you to a web site which produces the table shown in the message.
On that page, the URL shown in the browser line ends in 17r42. This represents the OEM final gear ratio. Use the cursor arrows to change the 17r42 to some other set of sprocket values leaving everything else intact on the browser line. Press enter and the program will compute the speeds at various rpm's for each of the gears for the new sprocket values. Here's the link again.
2008 KTM 690 Enduro
Old 03-02-2014, 05:16 PM   #15
DirtJack
DirtJack's Avatar
Oddometer: 1,598
16/45 is what I used to run on my 2007 990. Worked great there. Probably will work even better on the 1190R.
This program assumes an 18" rear wheel. One of its inputs needs to be changed for the outside circumference of the 17" rear wheel if you have an 1190 Adventure. The value you input is 10 times the circumference in mm. In the example I used
circumference=21270
was for the 18" wheel. All these input values show up on the browser URL line and can be edited in the usual way on what ever computer/phone/pad you use.
2008 KTM 690 Enduro
Times are GMT -7.   It's 01:35 PM.
