Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 04-21-2014, 07:04 PM   #31
DirtJack
DirtJack's Avatar
Oddometer: 1,595
Originally Posted by OhBoy View Post
Gear Commander is your friend.
If not already posted somewhere.
Let the web site do the math.
Or my site which you can do yourself and bookmark the results for later reference.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack screwed with this post 04-23-2014 at 07:27 PM
DirtJack is offline   Reply With Quote
Old 04-21-2014, 07:11 PM   #32
DirtJack
DirtJack's Avatar
Oddometer: 1,595
Originally Posted by ABuck99 View Post
DJ-
Is there enough room to slide the chain off the front CS with out breaking the chain?
Haven't tried it yet on the 1190, but there was enough room on the 990. What you do is slide the axle as far forward as possible (after removing the spacer block on the right side). Then you should be able to slide the sprocket (chain intact) off the drive shaft. Of course, you loosen the nut on the drive shaft before loosening the rear axle and you will also have to remove the front sprocket cover. If you do this by yourself, I find it is easier to use an impact wrench to remove the front sprocket bolt.
2008 KTM 690 Enduro
Old 04-22-2014, 04:11 PM   #33
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,162
Originally Posted by DirtJack View Post
Or my tool which you can do yourself and bookmark the results for later reference.
I am not going to click on your, "my tool" for fear that....
What has been seen cannot be unseen.
Start slow then easy off
OhBoy is offline   Reply With Quote
Old 04-22-2014, 06:57 PM   #34
DirtJack
DirtJack's Avatar
Oddometer: 1,595
Hey, you're right to not trust a fellow ADVRider, especially one who has a CS Ph.D. and rides an 1190R. Simple CGI script, nothing more. All of the bike data kept in the URL which allows you to save it in your browser like any other URL. So what do you know about gearing commander which makes you feel safe?
2008 KTM 690 Enduro
Old 05-06-2014, 06:28 PM   #35
mlyamkaw
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 549
This might be a dumb question, but how did you get the front sprocket off? Mine appears to not be able to get past the groove in the swing arm. Like you would have to take the swing arm off the get the sprocket off. There has to be a trick, right? I'm disassembled to that point, and took a break to research and have a couple of beers to think about it. don't think I will get too far tonight!
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
mlyamkaw is offline   Reply With Quote
Old 05-08-2014, 01:05 PM   #36
Milli13
Milli13's Avatar
Oddometer: 55
2013 1190 standard
I have the standard Adventure version and looking to gear it down a little to match some TKC 80's, But according to the manual is has the same primary drive ratio, gear ratios and final drive ratio as the 1190R, but it as a 17inch rear wheel? , is that possible? does it not mean it as a slower top speed?
Milli13 is offline   Reply With Quote
Old 05-08-2014, 01:19 PM   #37
PS-RagE
PS-RagE's Avatar
Oddometer: 642
Anybody actually gone to 16:45 yet? Did the chain fit?
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
PS-RagE is offline   Reply With Quote
Old 06-15-2014, 04:27 PM   #38
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,110
Complete ratio list, easy compare
http://www.jtsprockets.com/fileadmin...tgearratio.pdf
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is offline   Reply With Quote
Old 06-16-2014, 09:09 AM   #39
PS-RagE
PS-RagE's Avatar
Oddometer: 642
Yes, it fits just fine.
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
Old 01-15-2015, 10:30 PM   #40
J&K
J&K's Avatar
Oddometer: 354
Did you reuse the stock chain?
2013 F800gs (his) 2014 KTM 1190r (his)
2015 F800GS (hers) 2009 F800gs (hers) 2003 ural (dogs)
J&K is offline   Reply With Quote
Old 01-16-2015, 12:47 AM   #41
wilmar13
Oddometer: 744
17-45 fits with stock chain... Though just barely.
'14 KTM 1190-R
wilmar13 is offline   Reply With Quote
Old 01-16-2015, 09:14 AM   #42
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,399
Originally Posted by locul View Post
if you want longer life on the front keep it 17 and adjust at the rear.
+1
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 01-16-2015, 10:05 AM   #43
Fezztone
Oddometer: 38
I went16:45. Kept stock chain but had to flip the rear adusters to accommodate. Great set up for the trails and ok on the highway. But, seems to have killed my mpg...
Fezztone is offline   Reply With Quote
Old 01-18-2015, 07:10 PM   #44
kailwathne
Adventure Rider
Oddometer: 259
I have only had my 2015R for a few weeks, but it does seem like the gearing is pretty tall for low speed technical. I had a 17-45 on on my 950 and that worked well. on the 950 I had a 120 link chain. I counted the links on the 1190 tonight and it comes with 118. If I change the gearing I would put a 120 link chain on to keep the wheel base close to stock.
kailwathne is offline   Reply With Quote
Old 01-19-2015, 06:07 AM   #45
Black Hills
Oddometer: 1,231
I think I will try 17/44 ??
Black Hills is offline   Reply With Quote
Times are GMT -7.   It's 02:13 AM.
