Old 03-09-2014, 12:11 PM   #16
Reaver OP
Outta Here
Reaver's Avatar
Oddometer: 4,368
Just speculating here:
The 1150's are getting older so only a mechanically inclined person could keep up with the maintenance. I can change a clutch on a twin in an hour, an R GS needs major disassembly so having the Dealer do a twin is much cheaper and convenient. Overall I think the twins are easy to work on over an R bike.
Leaving it all behind 2014
Pura Vida my Ass.
Reaver is offline   Reply With Quote
Old 03-09-2014, 12:20 PM   #17
ebrabaek
Oddometer: 4,873
That is because you have to lay up all the parts on a teflon coated table first, weigh the correct amount of oil to add for the spoonful you loose. I change it in 30. That is Garage gangsta to you sir.....
How we roll on the border...... Uhhhmmm southern one,
Erling
Old 03-09-2014, 01:20 PM   #18
Reaver OP
Outta Here
Reaver's Avatar
Oddometer: 4,368
Typical pilot response.
Just be thankful aircraft mechs double check their work.
Well, north of the border anyway.
Pura Vida my Ass.
Old 03-09-2014, 01:24 PM   #19
ebrabaek
Oddometer: 4,873
He he... Like flight 5481.....
Erling
Old 05-20-2014, 01:31 PM   #20
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Question... so the adjustment moves the threads down. If the threaded nuts are at the upper most limit then the cable is toast and/or the clutch is done?
The one in the pick is in the middle. On mine the threads are all below the bottom nut.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 05-20-2014, 07:08 PM   #21
Reaver OP
Outta Here
Reaver's Avatar
Oddometer: 4,368
The pic you quoted is a new clutch with the old PN cable. Before I replaced the plates I had about one thread left for adjustment on the top of the nut. When I measured the old plates they were on the minimum spec for re-install according to BMW. I therorize I had that one thread plus a few more (using the thin nut on top) before I got all wear possible out of it.
So then I took the old clutch plates (at min for re-install) and put them in a bike with the new PN cable and I have 5 threads left above the thick nut. I'll run it all the way down till it slips.
YMMV
Pura Vida my Ass.
Old 05-20-2014, 07:47 PM   #22
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Now this is interesting.
Old 05-20-2014, 09:17 PM   #23
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
YMMV
What's interesting is that my new clutch & new cable look exactly like that.
Old 05-22-2014, 03:55 AM   #24
speck
It's all about endorphins
speck's Avatar
Oddometer: 32
Many thanks for this post. I'm at the limit of adjustment on my 2011 @ 40k miles. Kind of hoped I'd gotten more out of it. Oh well. That's what she said.
"one fast move or I'm gone......"
speck is offline   Reply With Quote
Old 05-22-2014, 05:15 AM   #25
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
New clutch & new cable (longer cable? Vs the stock 09) installed. Much better & plenty of adjustment avail now.
Old 05-22-2014, 07:54 PM   #26
2Stamp
2Stamp's Avatar
Oddometer: 406
Thanks for this. I didn't realise mine was so bad (tight, no play). Went out this morning before work and had it adjusted in 5 min. awesome.
_______________________________
2011 F800GS
2014 350XCF-W
2006 450EXC
2014 Honda Grom (hers)
2Stamp is offline   Reply With Quote
Old 08-28-2014, 06:46 AM   #27
DanT0007
Oddometer: 4
I took my 2013 F800GS in for it's 6,000 mile service and they told me that the clutch had 10% life left and was adjusted as far as they could. When I asked them how much free play they left they said 1mm to 2mm.
So my question is, you mentioned that a bulletin went out... Do you know if that was supposed to go to all the shops and if so, was it only for specific models?
DanT0007 is offline   Reply With Quote
Old 08-28-2014, 06:52 AM   #28
Reaver OP
Outta Here
Reaver's Avatar
Oddometer: 4,368
You have a 2013 which changes everything for adjustment. The bulletin was put out in maybe 2009.
You still need to monitor the free play but I don't know what the published spec is. CERTAINLY more than 1-2mm!
Pura Vida my Ass.
Old 08-28-2014, 06:56 AM   #29
MikeMike
MikeMike's Avatar
Oddometer: 4,150
You went through your clutch in only 6,000 miles?
The parts and service guys are going to friend you on facebook.
Old 08-28-2014, 08:13 AM   #30
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,815
oh and now that the fun is over go fill out that profile noob
Loutre is offline   Reply With Quote
Times are GMT -7.   It's 07:01 PM.
