Old 03-07-2014, 07:49 AM   #31
Katoom72
Katoom72's Avatar
Oddometer: 917
Get a multimeter and a 6pack
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 03-07-2014, 08:11 AM   #32
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
Originally Posted by DELTATANGO View Post
When the stater is pressed the headlight is disconnected so that the starter gets more juice. When starter button is released the headlight comes back on.
This is not a true statement for the KTM 950/990. There is nothing configured to disconnect the headlight circuit while the start circuit is energized. What you are seeing is a significant sag in system voltage and the head light is only dimming as a result. Some motorcycles do this (disconnect the headlight), Honda did it on some of the models, but for this application, it is not the case. There are 4 relays, one is the Primary Main that is controlled by the key switch that energizes the lights and several other circuits, and provides power to the Secondary Main, the Secondary main is controlled by the bar switch, this energizes the ECU and a couple other systems, the ECU then controls the Fuel Pump relay. The remaining relay is the Safety Relay which controls if the start button works or not depending on side stand, gear position, clutch position.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-07-2014, 08:49 AM   #33
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,799
The SE isn't the turd in this equation.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 03-07-2014, 08:53 AM   #34
rhodeydog
Childish adult
rhodeydog's Avatar
Oddometer: 90
Bit of a hijack here, but since we're on the subject of the SE's electrical system, I'd love to know if there's a reasonably straightforward way of installing a switch to manually turn the headlight on & off (when offroad). I installed this set-up on my 990 but it was easy -- KTM sells a Euro switch and it's just plug & play. Seems more complicated on the SE . . . .
rhodeydog is offline   Reply With Quote
Old 03-07-2014, 09:15 AM   #35
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
Yes its possible, however not a 'plug/play' like the ADV since the bar harness and main harness plugs are different between the two models.
Old 03-07-2014, 09:26 AM   #36
rhodeydog
Childish adult
rhodeydog's Avatar
Oddometer: 90
I also got it done on my 530 via a switch that came from Sicass Racing as I recall. I have HID's on all my bikes which run at lower amperage, but require slightly higher amperage than stock on start-up. The on/off option is nice since I can then wait a few secs. for the battery voltage to come up before switching on the HID. It's also to nice to have in the event you encounter an electrical issue and need to limp home.
Maybe you could add this onto your impressive lineup on advmachines?
Old 03-07-2014, 09:31 AM   #37
KTM450SX
Oddometer: 488
That sucks yours has an issue. Hardly a turd though you'll get it figured out.
I had the fuel pump die, other than that mines been good. I don't ride it as much as I would like so its only got 13,000 miles or something.
2014 KTM 500 EXC
2007 KTM 950 Super Enduro
KTM450SX is offline   Reply With Quote
Old 03-07-2014, 10:34 AM   #38
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,937
OK, I stand corrected. I'm new to these great motorcycles..
DELTATANGO is offline   Reply With Quote
Old 03-07-2014, 10:40 AM   #39
JRod152
will work for tires
JRod152's Avatar
Oddometer: 351
I'd love to know if there's a reasonably straightforward way of installing a switch to manually turn the headlight on & off (when offroad). . . . .
FYI...
THIS SWITCH is plug & play on the SE. I have one. Another inmate pointed me to it after I initially ordered the Euro switch for the Adventure, assuming it would work.
The SE molex plugs for those controls are wired like the EXC's & this switch pops right it. The "OFF" function works great. It has an LED indicator for turn signals, high beam, etc. on the top of the switch, which is nice for me, since I'm not running the stock instrument cluster.
Hijack over
"Never let the things you want make you forget the things you have"
JRod152 is offline   Reply With Quote
Old 03-07-2014, 10:51 AM   #40
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,062
Can I do my lawyer joke now?
KTM 1190R...Adventure Beast, 950SE......Desert Beast, KTM 690 Quest...Rally Beast, Husqvarna 501...Trail Beast, KTM 300xc...Woods Beast
Nowwhat is offline   Reply With Quote
Old 03-07-2014, 11:00 AM   #41
rhodeydog
Childish adult
rhodeydog's Avatar
Oddometer: 90
HEY! I resemble that remark! OK, OK, I've already heard most of them but there's always a chance somebody's got a new one.
Old 03-07-2014, 11:01 AM   #42
charlie264
charlie264's Avatar
Oddometer: 8,543
Old 03-07-2014, 11:02 AM   #43
charlie264
charlie264's Avatar
Oddometer: 8,543
Old 03-07-2014, 05:18 PM   #44
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,079
Without repeating what others have said maybe an auto/moto sparky would be a better choice than a mechanic?
Least they have the mindset to chase those gremlins that hide in our wiring harnesses.
Best to getting here sorted and turning her from a turd to shit hot!!
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 03-07-2014, 08:04 PM   #45
woodchuckexc
Oddometer: 801
I'm close to San Jose. I'll take the turd off your hands if you get to frustrated.
woodchuckexc is offline   Reply With Quote
Times are GMT -7.   It's 08:05 PM.
