Old 03-09-2014, 09:14 PM   #1
RedHawk47 OP
RedHawk47's Avatar
Oddometer: 467
Stalling -24 times in 30 miles
Went for a ride today - 30 miles no problem. Two hours later I rode home - my F800GS stalled more than two dozen times on the way home. I'd pull in the clutch and wait 10 seconds or so and restart the engine. WTF?
More details: Last rode the bike two months ago. Parked it with 3/4 empty fuel tank. Filled up at beginning of today's ride. First 30 miles no problems. On the way home it was stalling when I stopped for a light and also as I was cruising at 40-50; about half each way. At five miles I found a gas station - they didn't have Techron so I put in half a bottle of fuel injector cleaner. Didn't help. The further I went the less distance between stalls. When it stalled I would wait a bit before restarting; it would usually start - if not, it would start ten seconds later.
I have been using Techron or Star-tron and Shell gas on a regular basis for the last two years. This fill-up was Conoco.
What happened? Bad gas? Water in the tank from being mostly empty? Crud plugging the injectors? ???
What to do now? Drain the tank and refill with fresh gas and Techron? Replace the injectors? (The bike is out of warranty)
Dan
It's never too late to have a happy childhood. -- Tom Robbins
13 Moto Guzzi Stelvio NTX
09 BMW F800GS
99 KLR 650 A13
RedHawk47 screwed with this post 03-09-2014 at 09:31 PM
RedHawk47 is offline   Reply With Quote
Old 03-09-2014, 09:40 PM   #2
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Make sure the charcoal canister isn't full of water for starters.
johngil is online now   Reply With Quote
Old 03-09-2014, 10:03 PM   #3
RedHawk47 OP
RedHawk47's Avatar
Oddometer: 467
How do I check that?
Dan
09 BMW F800GS
99 KLR 650 A13
Old 03-09-2014, 10:06 PM   #4
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Remove it and invert it. I was amazed how much water came out of mine.
It's most likely not the cause of your problem, but it pays to start w/ the simple stuff.
Good luck!
Old 03-09-2014, 10:35 PM   #5
Full Power
Oddometer: 1,538
How many miles since your last fuel filter change ?
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 03-10-2014, 03:11 AM   #6
GoneAgain
Huh?
GoneAgain's Avatar
Oddometer: 1,606
How many miles since your last fuel pump change.....
GoneAgain is offline   Reply With Quote
Old 03-10-2014, 04:27 AM   #7
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,273
Whenever I hear "ran fine, got gas, started to run like crap" I say water.
If the engine is missing on the highway as well as idle, seems to back it up. There is no return fuel system so the water accumulates in the injector rail and will get worse until it's burnt or removed.
I'd drain the fuel with a hose till the level is below the pump assy then pull the pump and look inside the tank. Fast and easy if you've done it before.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver screwed with this post 03-11-2014 at 09:43 AM
Reaver is offline   Reply With Quote
Old 03-10-2014, 10:10 AM   #8
J&K
J&K's Avatar
Oddometer: 351
Another quick way to get rid of water is a bottle of heet.
2013 F800gs (his) 2014 KTM 1190r (his)
2015 F800GS (hers) 2009 F800gs (hers) 2003 ural (dogs)
J&K is offline   Reply With Quote
Old 03-11-2014, 04:05 AM   #9
Mr B
Mr B's Avatar
Oddometer: 516
You might also ensure that your tank vent is not clogged. I had an instance where the bike stalled repeatably, when I opened the fuel tank to ensure that there was in fact gas in the tank!!!, I heard a rushing sound of air escaping or entering, was not sure. I have heard that a few times since and am sure that when it happens my vent line is pinched or something as I move it around and problem solved.
If the vent is clogged, as you burn fuel, you create a vacuum in the tank, and eventually the pump cannot pressurize the fuel system.
Next time it happens, it is a real easy check, just listen when you open your fuel tank.
Good luck!
"For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return."
Leonardo da Vinci[/FONT]
Mr B is offline   Reply With Quote
Old 03-11-2014, 03:12 PM   #10
JRWooden
Oddometer: 4,303
If you hold a slip of paper up to the tank opening and then pop the lid you can watch which way the paper deflects and will know if it's a pressure release or a vacuum. If it's vacuum you'll need to get that fixed ... likely canister and/or check valve ... long thread on that here....
If you go the HEET approach let me recommend that you buy the RED bottle HEET and not yellow ... the HEET website explains the difference and after reading it I can't figure out why anyone but the uninformed would by the yellow-bottle stuff...
Old 03-11-2014, 04:25 PM   #11
richard weed
richard weed's Avatar
Oddometer: 64
Stalling issue
Had a similar problem with my 2010 F800gs, here in Colorado. Clogged fuel injectors. Replaced under warranty, no issues since. Always used premium fuel from a major chain (usually Conoco). Interestingly, recently had my 12k service done. Fuel additive now recommended and installed by dealer at time of service. BMW Group fuel system cleaner plus. No mention 5k miles ago when the injectors were replaced. Good luck.
DW
richard weed is offline   Reply With Quote
Old 03-11-2014, 07:11 PM   #12
JRWooden
Oddometer: 4,303
The BMW branded fuel system cleaner bottle looks amazingly like the Techron bottle ... but probably costs more...
A comparison of the MSDS would be interesting .......
Old 03-11-2014, 11:18 PM   #13
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,775
Are you riding in rain? My canister sucked water up the vent line on my Alaska trip. Pulled the vent line up on top of the transmission and the problem went away. Did a canisterotomy when I got home.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 03-12-2014, 11:05 AM   #14
Trykart
Trykart's Avatar
Oddometer: 31
Just read this thread a night out two ago and now I'm sitting at a gas station waiting for a tow. Same issue, began sputtering while riding. Now it'll start and run for about 10seconds before it dies again. Any updates on what was wrong with yours?
Trykart screwed with this post 03-12-2014 at 11:36 AM
Trykart is offline   Reply With Quote
Old 03-14-2014, 05:56 PM   #15
Trykart
Trykart's Avatar
Oddometer: 31
Heard back from the dealer today. Ended up being a bad fuel pressure regulator. Replacing it under warranty.
Times are GMT -7.   It's 04:54 AM.
