Old 09-12-2005, 08:23 PM   #1
motobrett OP
Dazed and Confused!
motobrett's Avatar
Oddometer: 183
Question KTM Overheating
So I have this outstanding 2005 KTM 450 EXC that rides like a dream. I bought it in January and have put on a few fine miles, such as the Nevada 200. Now I'm sad - the last two times I've taken her for a ride, she's gotten steamed at me.
Two weeks ago riding Webster Pass and Red Cone on a cool day and she starts spewing half way through the ride. At home after she cooled off I added about a cup of fluid to the radiator. I talked with Don at Elite Motorsports in Loveland and his response was that they've found that the 10mm over the fins instructions from KTM lead to too much fluid in the radiator for high altitudes. Fair enough.
So Saturday I'm playing on Shrine Pass and Ptarmagin Pass with the buddies and my orange beast gets pissy again. When I got home I ended up adding about 18 oz to the radiators. I cracked the bleed valve and got but a few bubbles.
Of greatest concern is that on Webster Pass I was riding with another 450 EXC that didn't overheat. This weekend I was riding with a 525 EXC and a WR450 neither of which overheated.
So the question is...is it my bike? Is it the model year? Suggestions? HELP!
"Sometimes it takes more than one tank of gas to chase the demons from my head."
motobrett is offline   Reply With Quote
Old 09-12-2005, 08:56 PM   #2
309
Special Purpose
309's Avatar
Oddometer: 5,466
KTM fan kit is less than $100.
My 525 came with one and has never boiled over, even when tortured.
309 is offline   Reply With Quote
Old 09-12-2005, 09:49 PM   #3
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
Bad rad cap?
Isn't there a larger water pump impeller kit available for these beauties as well?
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack is offline   Reply With Quote
Old 09-14-2005, 09:47 PM   #4
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,681
Can I assume you checked all the regular stuff?
Choke is not stuck
Jet is correct (and STILL screwed in)
Proper plug
Clean airfilter
etc.
I had problems with my MX/C the first couple rides. It was a jetting issue along with a broken reed valve.
You may have to take a few things apart. Start with the thermostat.
Bon chance.
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is online now   Reply With Quote
Old 09-27-2005, 09:05 PM   #5
jrscott
Oddometer: 4
KTM overheating - it's the jetting!
My new 2004 625 SXC did the same thing for the first few months I had it. I kept bringing it back to the dealer and worked with KTM and finally after bringing it to another dealer the problem is fixed. The dealer I bought the bike from rejetted it to supposedly make it more rich. Once the second dealer put the factory original jetting back in the problem went away. So the jetting on these Mikuni carbs being off can definitely make your bike overheat and even boil over.
The first dealer tried to tell me I needed a fan kit as well, but I didn't give in. It's the jetting. Get it rejetted properly and it will run like a champ. -- JR
jrscott is offline   Reply With Quote
Old 09-27-2005, 10:11 PM   #6
soloyosh
Dad and husband
soloyosh's Avatar
Oddometer: 5,480
I second the rad cap post. Cheap to try.
Cheers
Brett
2007 Aprilia RXV 5.5
soloyosh is offline   Reply With Quote
Old 09-28-2005, 05:22 AM   #7
techieguy
Lost in the woods
techieguy's Avatar
Oddometer: 354
The stock SXC carb is the FCR Keihin and does come from the factory very lean causing high temps in the engine. Rejetting does wonders for the power and keeping it cooler. Factory jetting is way lean.
Techie
techieguy is offline   Reply With Quote
Old 09-28-2005, 06:45 AM   #8
cap
Vice of Reason
cap's Avatar
Oddometer: 2,403
Did you buy it there? They claim to jet their bikes properly before selling. It seems unlikely to be a jetting issue, since the jetting hasn't changed since you bought it, and the overheating is a recent development. Furthermore, at the high altitudes around here, and the places you describe riding, a smaller jet is appropriate. But, it is worth checking to see if something shook loose in the carb.
cap is offline   Reply With Quote
Old 09-28-2005, 06:51 AM   #9
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
I gotta agree. Don and Roger know their stuff on jetting and at the altitudes of the passes you were on, the OEM jets, as lean as they are at sea level, are likely somewhere between just right and too fat....
I'm guessing that jetting is not your prime candidate for the warm running.
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 10-05-2005, 02:45 PM   #10
EbarDP48
Got Adventure?
EbarDP48's Avatar
Oddometer: 816
Ditto some of your other answers....Bigger pilot and add the fan.
Bert
04 KLR 650
05 KTM 525 EXC
Once you've gone adventure, you can never go back.
09 KTM 530, 07 KTM 300 XC, 07 Triumph Tiger,1967 Honda P50, 2001 Honda XR70,
EbarDP48 is offline   Reply With Quote
Old 10-05-2005, 08:45 PM   #11
KTOOMER
ad-vent-ure man
KTOOMER's Avatar
Oddometer: 533
I added the fan today..simple solution and insurance as well..try it it costs $100
"one man crazy...the other half-sane"
2005 KTM 450EXC
2007 BMW 1200ADV (ON ORDER)
W6ZZW
KTOOMER is offline   Reply With Quote
Old 10-06-2005, 03:48 AM   #12
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
Swap rad caps with your mate who has the 450exc also.
Does your mate have more miles/hours??are you riding in low gears and leaving it ticking over when you stop??(i always hit the kill switch when i stop and restart it when i wanna go........never had an overheat problem although on my last ride the guy i was with who also has a 450exc(same as mine) kept his running whilst at the bottom of a sphincter twitching hill climb for about a minute or two and when he got to the top he still had it ticking over and eventually it spewed!!
BLUE(UK) is offline   Reply With Quote
Times are GMT -7.   It's 06:38 PM.
