Old 03-11-2014, 09:48 AM   #1
FZcruzer OP
Oddometer: 574
2010 990A electrical problem
Hello all,
Went to start the bike, turned the key on, put the kill switch into the run position and nothing. No dash movement, nothing.
Checked the battery voltage and it was at 2 volts. Thought maybe my cheap USB socket had drained the battery, and put the bike on the charger. As soon as I put the charger on I got the EFI light and heard the fuel pump start, this with the key off and the kill switch in the off psoition. Cycled the key and switch and it does not matter, with everything off the pump and dashboard trys to come to life
Removed the battery and charged it, have not tested it yet to see if it is toast or not, took a full charge and will check the standing volatge after work today.
I am thinking either I have a pinched wiring harness around the steering head like others have posted and have a short, or the ignition switch is bad.
Anybody have any other ideas before tear into it? Can not really think of another common point where this would happen.
Key off, even removed and the kill switch in the off postition and the bike is still powered.
FZcruzer is offline   Reply With Quote
Old 03-11-2014, 09:07 PM   #2
FZcruzer OP
Oddometer: 574
All fixed..
Went out and checked wiring, found that if I wiggled the two wires that go into the bottom of the ignition switch I could cause it to short. Took the two screws out and removed the base of the switch and popped it apart.
After removing the bottom of the switch I could see the insulation had pulled up on the wires and they could short.
Added some shrink wrap to insulate the wires.
Put it all back together and added some shrink wrap to add some protection.
All back together and seems fine, hope this might help somebody else.
Old 03-12-2014, 07:42 AM   #3
Hootowl
Oddometer: 1,268
Thanks for the pictorial
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 03-12-2014, 08:04 AM   #4
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 576
Thanks for the report. Nice solution you came up with. Might think of doing that to my 950's. It's strange there is no secondary anchor method for such an important wire. Yank on the wire and you are pulling at the solder.
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Old 03-12-2014, 08:28 AM   #5
Dan Diego
Oddometer: 1,014
+1
Much appreciated as this is likely a common issue.
I have no interest in living a balanced life. I want a life of adventure.
Dan Diego is offline   Reply With Quote
Old 03-12-2014, 08:51 AM   #6
FZcruzer OP
Oddometer: 574
One more thing, the two screws that need to be removed to take the bottom if the switch apart are normal Phillips screws. I was worried they might be security screws but no problems.
Old 05-08-2014, 08:49 PM   #7
two trackin fool
two trackin fool's Avatar
Oddometer: 1,302
2010
Luckly mine started acting up when I was home in the garage doing a 6 point park job
Stay Patient and Trust your Journey
two trackin fool is offline   Reply With Quote
Old 05-08-2014, 08:55 PM   #8
FZcruzer OP
Oddometer: 574
Cool you figured it out. The damage to yours is a lot different than what mine looked like.
Old 05-08-2014, 09:04 PM   #9
two trackin fool
Oddometer: 1,302
Thanks for the heads up !
I will tie my harness up better so I don't have the same issue as you !
Wondering about the thread too . Would think they could come up with a better design ........
Old 05-08-2014, 11:15 PM   #10
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,059
That is not correct.
In mine, the wires were tightly wrapped with a tie wrap around the switch barrel, as they come out. That bends them but keeps them still. The replacement I bought was exactly the same. Wires were tie wrapped on the switch barrel.
Cheers
gefr is online now   Reply With Quote
Times are GMT -7.   It's 04:45 AM.
