Old 03-11-2014, 10:23 AM   #1
AdvRonski OP
They call me......Ronski
Location: Wishing I was back in Grand Junction, now in MN
Oddometer: 714
2014 Upgrades, An Auxiliary Fuel Pump, and General Bulletproofing
My past projects have been fabricating my own skid plate, radiator guard, and auxiliary fuel tank. You can find the list
This long, cold Winter turned out to be longer and colder than it's bee in quite some time, so I decided to go big in the garage this year.
I have a 2004 950A, with 47K, and I already went through the top end and put new cam chains in at 25K. But I always regretted not splitting the cases and putting the updated shift drum and trans oiling tube in.
So, I started there-
Here's where the original drum is known to fail. You can see the wall of the channel is quite thin-
The new drum has fixed that-
And an updated shift arrestor, because the old style has been known to spit it's little balls all over the inside of your nice, clean engine-
But, on to the fuel pump. I put a Facet pump in at 25K, and it's been trouble-free, but there have been reports of failures.
Carrying a spare sounds fine, but then you might be stuck swapping out a fuel pump in the middle of BFE, if Murphy's Law has anything to say about it. I am running a Facet 40171 pump, with a check valve and shut-off valve, to keep it from flooding the carbs when you park the bike.
I decided to run a Facet FEP 04SV pump inline in the fuel system. The 04SV has no check or shut-off valves, so fuel runs through it freely.
Here's how it looks mounted in place-
So, in normal operation, the main pump pushes fuel through pump 2 easily.
In the event of a pump 1 failure, pump 2 will not pull fuel through pump 1, since it has a shut-off valve in it.
A bypass is needed. You could use a check valve, but it would defeat the shut-off valve of pump 1, so instead I used a simple fuel shut-off valve-
For a system operational test, I measure the output of pump 1-
I measured 14 GPH, good for roughly 140 HP. Great!
I'd like to note how badly plugged the Facet fuel filter was after 20K miles. I didn't check output with the old filter, but it couldn't have been to good.
Next, I pulled the fuel pump fuse, turned on the bypass valve, and plugged in pump 2. Notice I used and SAE connector for pump 2, since there are 2 power cords right there, one has battery voltage all the time, which I use for the Slime air compresssor, and the other is key-on power, so pump 2 is only on with the key on-
I measure pump 2 output at about 16 GPH, so we are looking good. Now we have a backup fuel pump ready to go with little drama.
You might be thinking this is overkill, but I really don't like having to do trailside repairs, or being stranded at awkward moments. (Murphy's Law, remember?)
I've been an Auto Tech for 40 years, and I'd rather be riding than wrenching.
So, here's a look at the somewhat complicated fuel delivery plumbing-
Complicating the already limited available space for the fuel lines is the Shindengen R/R, also a new upgrade. The fuel line from the rear tank comes in over the alternator cover, and tees into the fuel pump inlet, with the main tanks line going out the other side. In between, the bypass tees off to the valve, the goes forward to the fuel pump outlet-
With this setup, I can run off the main tanks only, the rear tank only, or both together. And, with a twist of the valve, run on pump 2 if needed.
The Shindengen R/R upgrade allows for more consistent system voltage, and eliminates some small gauge wiring from the charging system.
But, it really takes up some space, too-
I also added a 990-style battery power access post-
Now I don't have to drop the skid plate to either give or get a jump start.
I guess another place I learned you can never over-prep is racing. After 40 years and many boxes of trophies, I've found my confidence level is higher when I know my bikes are fully prepped.
So, another reason I like to read ride reports here, is learning what kinds of failures people experience on the trail. One inmate riding on a rocky back road had a rock crack the end off one of the fuel crossover valves on the main tanks. It's really not surprising, especially with a high fender. Those valves are just hanging out there in the breeze.
I fabbed a pair of guards that mount to the crash bars-
More fiddling- I added bracing to the rear of the subframe-
And, just for fun, I fit an old M4 muffler I had laying around to the 950-
Now, if that snow would just melt a little faster.
Ronski
Enduro Racer & Big Bike Adventurer
AdvRonski is offline   Reply With Quote
Old 03-19-2014, 05:28 PM   #2
AdvRonski OP
Oddometer: 714
Well, since the snow piles are still pretty deep around here, I decided to look into what it would take to relocate the battery under the seat to shift some weight towards the rear. Well, after reading through the battery relocation thread, I started by just sticking the battery in the under seat box, and was surprised there was still room for the OEM tool roll, and a few extra items.
My first idea was pretty straightforward, just run a long cable from the battery to the starter relay up front, and a shorter ground cable to the engine. Then it occurred to me it seemed counter-productive to route such a long cable to the front, and another long cable back up to the starter motor.
There was plenty of low-amp wiring there to move the starter relay back up to a position between the battery and the starter motor.
I just had to move the spare fuel pump over a bit, and then found it was possible to use most of the original battery and starter cables.
I just needed to make a 8 gauge wire to run down to the old starter relay area, to the battery power access post, and the Shindengen regulator/rectifier.
After some careful routing and abrasion protection, the setup works great.
It even makes access to the relay and main 30A fuse a little easier. I even used the empty spot where the battery was to stash an 18" HD tube for backup.
Ronski
Old 04-01-2014, 09:39 PM   #3
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,891
Nice work man! My 950 deserves these mods.
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is online now   Reply With Quote
Times are GMT -7.   It's 09:16 PM.
