Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 03-14-2014, 07:07 PM   #1
irongrady OP
irongrady's Avatar
Oddometer: 241
1190 Fuel pump noise..
I just picked up my 1190 R from the dealership today and I have a question for the inmates. I did a bunch of searching but came up empty. After switching the key on I can hear the fuel pump prime and it sounds like it shuts off. The problem is the bike continues to make a whining whirring noise all before starting it up. Can anyone comment as to whether their bike makes some kind of mechanical noise anytime the key is switched on? I took the long 150 mile way home from the dealer and the bike is amazing. I just hope that this isn't a sign of a faulty fuel pump from the factory.
irongrady is offline   Reply With Quote
Old 03-14-2014, 07:17 PM   #2
irongrady OP
irongrady's Avatar
Oddometer: 241
I was also wondering what the plug under the seat is for on top of the battery cover next to the slots for spare fuses. When I got home from the dealer and went over the bike that plug wasn't connected. Is that the bad fuel dongle or is that a separate purchase from KTM. The 1190 owner manual is lacking compared to my 500exc manual. Thanks for any help
Old 03-14-2014, 07:47 PM   #3
rpthack
Oddometer: 9
Mine does the same, but not 100% of the time. I haven't been able to figure it out either.
Sent from my DROID RAZR using Tapatalk
rpthack is offline   Reply With Quote
Old 03-14-2014, 08:23 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,927
I do not own a 1190.
However, 950s and 990s prime for a while and then stop. Maybe it is similar. Hope that helps.
Cheers
Old 03-14-2014, 08:51 PM   #5
Clink
Beer break???
Oddometer: 26
Mine does the same. I'm sure it's normal.
KTM 1190 ADV-R
CRF250X
YZ450
Clink is offline   Reply With Quote
Old 03-14-2014, 09:37 PM   #6
scudrunner82
human whoopy cushion
scudrunner82's Avatar
Oddometer: 2,170
Normal.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is online now   Reply With Quote
Old 03-14-2014, 10:01 PM   #7
irongrady OP
irongrady's Avatar
Oddometer: 241
Thank you very much advrider.. I'll sleep a little better tonight now.
Old 03-14-2014, 10:13 PM   #8
Fezztone
Oddometer: 38
what color is the plug? It is most likely for the heated seat when/if you add it. Congrats on the new bike! I love mine.
Fezztone is offline   Reply With Quote
Old 03-14-2014, 10:28 PM   #9
BCBelstaff
BCBelstaff's Avatar
Oddometer: 73
If you want to play around in the menus without the fuel pump running just flip the kill switch and the pump will shut right down
See my ride videos here - http://www.youtube.com/user/unsightednight
BCBelstaff is offline   Reply With Quote
Old 03-15-2014, 08:09 AM   #10
irongrady OP
irongrady's Avatar
Oddometer: 241
The plug is white/clear. It connects to a dummy plug that has a spot next to the spare fuse slots. It makes sense that it's for the heated seat.
Old 03-15-2014, 09:09 AM   #11
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 402
if it's the white multi-way connector, then It's for two things, first it's where the service center plug in the KTM diagnostic computer and do firmware updates to your 'bike, and second it is where the bad fuel / off road dongle lead plugs in. There should be a blanking plug for it, when it's not used otherwise.
The heated seat wiring is installed separately when you get the dealer to fit the Ergo seats, there are wiring harnesses and 3-way illuminated push switches supplied in the kit.
RobZorba is offline   Reply With Quote
Old 03-15-2014, 09:25 AM   #12
irongrady OP
irongrady's Avatar
Oddometer: 241
Thanks RobZorba. I figured it had to be something like that being that it only mates up with a dummy plug.
Old 03-23-2014, 09:47 AM   #13
Timppa111
Oddometer: 3
I think that whining noise comes from the fly-by-wire throttle.
Timppa111 is offline   Reply With Quote
Old 03-23-2014, 10:29 AM   #14
Wonway
KTM Fanboi #2
Oddometer: 425
Yep
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
2014 KTM 1190 Adventure R
Wonway is offline   Reply With Quote
Times are GMT -7.   It's 03:41 PM.
