Old 03-17-2014, 12:25 PM   #1
StorckWhip OP
Oddometer: 65
Crashed in a rut-need some tips
So I need some input: Low speed low risk situation in a field where I was playing after successfully mounting up my first set of TKCs. Was having a blast and feeling increasingly comfortable so I elected to go through a section that is a bit of a small (2-3' ) rolling "whoop" with grass on one side where I had been riding around a set of ruts with muddy puddles at the bottom. I was not fully commited to the rut line and kind of went in 'last minute' and I don't think that I was quite lined up properly. I was standing on the pegs, weight neutral, but perhaps a bit stiff on the bars. Obviously this ended with me on the ground next to a sleeping beast that I had just filled with gas. The good news is that I'm confident that the bike crashes well with the AltRider bars and that 150lb of me can pick up the beast fully fueled when it's on it's side. My intent would have been to just line up in the center of the rut, stay loose, stay on the gas a little, and squirt right out. Is there any reason that that plan should have failed (other than the obvious coming into the rut at a slight angle).
What is the collective wisdom on how to ride in ruts? Or...perhaps...the wisdom is avoid when possible? But clearly there will be times when it's impossible to avoid them. So what then?
StorckWhip is offline   Reply With Quote
Old 03-17-2014, 12:33 PM   #2
Little Bike
Air/Clutz Sue
Little Bike's Avatar
Oddometer: 1,445
You mostly likely sneaked a peek at the side of the rut and where your eyes go, so goes the bike and you clipped the side. When I'm on stuff like that I only look where the bike needs to go; resist the temptation.
In your helmet, no one can hear you scream.
Old(ish) Chick on a Bike
V-Strom 650 Adventure "Maxwell"
DR-Z400s "Little Donkey2"
Little Bike is online now   Reply With Quote
Old 03-17-2014, 12:35 PM   #3
devo2002
-Devo
devo2002's Avatar
Oddometer: 3,921
be careful with ruts!!! Was going 5mph in a rut and fell down and broke my leg in 2 places, the good ole' tib/fib break.
Guys said afterwards its because my toes weren't fully pointing in towards the bike but out, so when I went down the toes caught on the side of the rut and twisted until snap!
Haven't been on a dirt bike since but will definitely not forget that piece of advice, better pass it along!
2014 DL650 Vstrom
devo2002 is offline   Reply With Quote
Old 03-17-2014, 02:24 PM   #4
folknride
Old Adventurer
folknride's Avatar
Oddometer: 688
Been there - done that - 4 days in hospital with a collapsed lung.
Did you high side? (I did).
If you're on a big bike riding slowly and drop your front wheel into a decent rut at a shallow angle, you're probably goin' down .
I've reviewed my dump many times in my head, and all I've come up with is:
Go faster - the suspension more likely to handle it.
Gas it to lift the front! Don't listen to your gut that says "danger - slow down"
Get a good steering damper.
And as others said - if you're in the rut with both wheels, ride it out and don't look down.
Or you could practice that thing they do in the GS Challenge where you side-slip along a log with the front on one side and the rear on the other
folknride is offline   Reply With Quote
Old 03-17-2014, 02:27 PM   #5
foxtrapper
Oddometer: 871
I'll disagree with staying loose in a rut, and even say that may have been part of what put you down. When you're loose, the rut controls, and will frequently ping pong the front wheel, to your detriment. Strong arm it, and stay in control. Many time, you can pull the bike back out of the rut.
foxtrapper is online now   Reply With Quote
Old 03-17-2014, 05:18 PM   #6
huskyKT
huskyKT's Avatar
Oddometer: 96
Last week I had a surprise get off. After going over it many times in my head I think figured it out. I was going straight on a sloppy gravel road enjoying the GRP stabilizer I installed before my trip. This was my first ride with a stabilizer and I was shocked as to how well it helped me handle the bike.
Then I hit about a 4" rock that shoved me into a shallow ditch. The bike stayed straight and I thought I was going to get out of it. Traveled about 40-50' and my right fork and crash bar caught a sapling. That's when the bike stopped but I did not.
The toe in is a great suggestion. I would think staying on the throttle would have helped you. Dual sport training teaches to stand up and lean to the outside when taking a turn slow.
Sent from my iPad using Tapatalk HD
HuskyKT
If it ain't dirty you ain't riding enough!
Husky TR 650 for the dirt
Suzuki GV1200 Madura for the road
huskyKT is offline   Reply With Quote
Old 03-17-2014, 07:06 PM   #7
smj
smj's Avatar
Oddometer: 207
No two ruts are the same, and every rut can change pending weather, the amount of use it gets, and type of vehicle doing the pounding! I would suggest pay close attention to your line, and the conditions there of. You really need to stay fluid on the bike and follow the front tires lead. That's not to say that the rear tire can't take you out, but you'll often have a chance to react to movement in back... Washing out the front can be really hard to recover from, and unlike when the rear drifts - correcting the front drift can sometimes be a bit counter intuitive. Go ride, and take notes!
Death is like an old whore in a bar, I'll buy her a drink but I won't go upstairs with her. Hemingway
smj is offline   Reply With Quote
Old 03-17-2014, 09:40 PM   #8
craigincali
Just hanging around
craigincali's Avatar
Oddometer: 2,166
I agree with this and also agree with whoever said to just ride it out. Don't try to get out of it once youre in it. Look where you want to go, like someone else said. Everyone is giving good advice, no one is wrong. experience will fix you. It takes time...
Me
I am usually drunk when I post so dont take it personally !
2010 KTM 990
craigincali is offline   Reply With Quote
Old 03-18-2014, 01:16 AM   #9
PeterW
Oddometer: 2,742
It's not normally the ruts themselves that drop me. The killer is getting the front on one side of the centre ridge, the rear on the other, if it's at all slick, odds are you are kissing dirt no matter what you try and do.
Survival means correcting the wheel placement as a priority and the few times I've managed it's been brutal and ugly - basically, whatever worked.
Pete
PeterW is offline   Reply With Quote
Old 03-18-2014, 03:34 AM   #10
Eddie G
Oddometer: 40
I spend most of my time at slow speed in fields and seated is better than standing when riding through ruts and loose terrain. Seated seems to connect you to the bike and lets you throw it around a little better when you need to.
Be the bullet...
Eddie G is offline   Reply With Quote
Old 03-18-2014, 06:16 AM   #11
Seth650
Seth650's Avatar
Oddometer: 464
I compromise, butt off the seat, knees bent and weight on the pegs, but thighs on the tank allowing some leverage.
2011 WR250R 2009 DR650
Seth650 is offline   Reply With Quote
Old 03-18-2014, 07:04 AM   #12
wizze
Wizze = Wise
wizze's Avatar
Oddometer: 1,134
Stand up weight back, stay loose, head up looking far ahead where you want to go, get ready to dab and pray. works for me most times.
2009 BMW F800GS
2009 Yamaha FZ-1 Retro
2012 KTM 500 EXC
2005 BMW R1200RT
Is that it?
wizze screwed with this post 03-18-2014 at 07:39 AM Reason: spelng
wizze is offline   Reply With Quote
Old 03-18-2014, 10:05 AM   #13
DougFromKentucky
Just a good 'ole boy
Oddometer: 439
What has always worked best for me with ruts is to avoid them. If I can't avoid them then all of the above applies.
Namaste'
Doug from Kentucky
2009 Suzuki Burgman 650 Executive, 1980 Honda Express NC50
USMC 1970-1978: HMH-463 Evacuation of Saigon - April 1975, Evacuation of Phnom Phen during the Killing Fields Spring of 1975
DougFromKentucky is online now   Reply With Quote
Old 03-18-2014, 03:18 PM   #14
StorckWhip OP
Oddometer: 65
I'll take this all into account, thanks! I elected to enter the rut just to 'see.' Well, now I feel like I need to go back and get it right! I'm sticking with standing up though as I'm afraid of being crushed under 600lbs of Tenere.
Old 03-18-2014, 04:29 PM   #15
Kommando
Kommando's Avatar
Oddometer: 7,389
Stand up, go with the rut until you're ready, get your weight back, and give it the gas when you want to pop the front end out of it. With the front end unweighted, you can steer right out of it. Don't pussyfoot around with the gas either. GIVE IT THE GAS. Even tug a wheely if you have to. You want the front to pop out of the rut, and not drag along in it.
Don't ride with your toes hanging down or facing outboard. Ride with the balls of your feet on the pegs. Keep your toes pointed straight ahead or slightly inboard when they're on the pegs.
Kommando is offline   Reply With Quote
Times are GMT -7.   It's 07:00 AM.
