Old 03-18-2014, 01:43 AM   #1
bz_OFFROAD OP
Oddometer: 5
990 ABS problem
Hi,
I have a strange problem. My ABS light sometimes just lighten and some of the time is closed and all is good...
I have notice that only (and only this to actions) when I pulling the clutch and close the throttle (doesn't matter if it while driving or standing) the light is off. Putting little throttle and it turn on again.
I have replaced to ABS sensor year and 9 month ago.
G
bz_OFFROAD is offline   Reply With Quote
Old 03-18-2014, 03:23 AM   #2
coconuttele
Oddometer: 78
I had the similiar issue on mine, but also lost the speedo at the same time. I replaced the sensor as the shop said with no luck. Ended up being the voltage regulator. Found out thru the site here. Test yours with a volt meter and see what it is putting out. Hope it helps
coconuttele is offline   Reply With Quote
Old 04-02-2014, 03:40 AM   #3
bz_OFFROAD OP
Oddometer: 5
Thanks!!
Thanks man,
you have been really helpful.
It was the regulator and my mechanic wanted to replace the ABS sensor...
Well, at list he learned something new and I didn't need to buy the sensor cable.
Wish you great rides and hope that you won't have a lot of troubles with our wonderful but not very reliable machine :)
Times are GMT -7.   It's 10:11 PM.
