Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 03-26-2014, 12:52 PM   #31
ErikDK
Oddometer: 207
My 1978 Guzzi California had an exact copy of the Harley kickstand - right down to bolt pattern and everything.
On the Idro-convert sister model, which couldn't be parked in gear, since it had a torque converter instead of a real clutch, the kickstand automatically operated a parking brake caliper on the rear disc.
ErikDK is offline   Reply With Quote
Old 03-28-2014, 12:56 PM   #32
SgtDuster
SgtDuster's Avatar
Oddometer: 3,461
2010 Buell Ulysses
1984 Suzuki GR650 "Tempter"
SgtDuster is online now   Reply With Quote
Old 03-29-2014, 10:02 AM   #33
devo2002
-Devo
devo2002's Avatar
Oddometer: 4,003
Originally Posted by Sl0rider View Post
Ah motorcycles! Alternately making you feel like a king, then completely tearing your ego to pieces. There's nothing else I've found quite as good at doing that. But we will always going back for the king feeling...!
Women
2014 DL650 Vstrom
devo2002 is offline   Reply With Quote
Old 03-29-2014, 10:27 AM   #34
DustyRags
Idiot
DustyRags's Avatar
Oddometer: 891
People
Sent from my Nexus 7 using Tapatalk
DustyRags is online now   Reply With Quote
Old 03-29-2014, 07:06 PM   #35
jnclem
True Airhead
Oddometer: 503
I'm a Noob, and I have, unbelievably to me, ridden off twice, TWICE, with my kickstand down. '89 GS, no switch. Both times were when I was on trip, fully loaded, out of town, unfamiliar surrounding. Lots of extra things to think about, and I brain locked. The good news is that in both cases, I started a gentle left turn, touched the kickstand, and it just came up into place. Barely even felt it.
Upon realizing what I had done however, it took a while to get the heart rate under control. I've been clean for over a year now. Hope it lasts.
jnclem is offline   Reply With Quote
Old 03-30-2014, 04:23 AM   #36
C/1/509
Oddometer: 6,284
Small, thirty second checklist in your head, double check that the stand is up and secured, last thing, before you ride away.
C/1/509 is offline   Reply With Quote
Old 03-30-2014, 05:13 AM   #37
jnclem
True Airhead
Oddometer: 503
Exactly. And I do that. But I didn't. That's why I was surprised by my own ability to do something so stupid. As a former hang glider pilot, I'm big on pre-flight check lists, and doing things the same way each time, then double checking. But apparently I'm not quite as competent and infallible as I thought. Good lessons. For me without consequences.
Old 03-30-2014, 07:31 AM   #38
orangebear
orangebear's Avatar
Oddometer: 1,280
My old bmw r100gs had a spring load sidestand. Which meant i had to get of the bike and hold the stand down with my foot to stop it coming back up when leaning the bike over.
some old bikes i have cut the saftey switch wires and soilder them to gether so i wont be stuck when the switch fails.
suzuki gsxr 600 srad sound fun bike
bmw r100gs i sold as it be came to unreliable.
road legal stomp pitbike sold
Klr 650 the worst ever made
Honda xl125rc powered by a cg125 block fun wee bike
orangebear is offline   Reply With Quote
Old 03-30-2014, 07:57 PM   #39
jnclem
True Airhead
Oddometer: 503
I have an aftermarket stand on it. The BMW stand is spring loaded, and a real pain to deploy, but it does retract as soon as you lift the bike.
Old 03-31-2014, 08:35 AM   #40
DOGSROOT
OUTSIDE
DOGSROOT's Avatar
Oddometer: 838
A better idea is to install a male-female connector on each side of the safety.
Cover connexions w/ shrink tube.
Switch still works, but if it fails, you can access your built-in male-female bypass.
(If you pay attention to installation orientation.)
Did this on my old R1100GS.
I miss her!!
In what sense can economics still claim to be a science if its predictive capacity is so dismally low?
Timothy Garton Ash
This drug won't cure you...but it will put your symptoms to shame
DOGSROOT is offline   Reply With Quote
Old 03-31-2014, 12:09 PM   #41
SloMo228
World Class Cheapass
Oddometer: 1,854
My old GL1000 had the rubber safety nub on the kickstand. It did work, sort of. It would at least push the stand up enough so that you didn't jack the rear tire off the pavement, but didn't quite kick it all the way up into its stored position. I imagine if you really railed over for a hard left turn you'd still biff.
--------------------------- Steve----------------------------------------
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 03-31-2014, 01:47 PM   #42
The Jerk
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,662
Originally Posted by RedShark View Post
BMW's early K-bikes had a lever-arm off the clutch-actuator that engaged a tab on the side-stand - if the bike was off the stand it would automatically retract, if it was ON the stand you couldn't pull in the clutch lever.
Yes. Very clever. Until you park your rented K75 in a gravel parking lot, and, in an effort to make sure the side stand is fully deployed and the bike is securely parked, give the bike a little tug backwards while it's leaning on the side stand. This action, given the side stand / clutch cable interlock, puts a strain on the clutch cable and the ball end of the cable just pops right off the clutch end of the cable, leaving you stranded with a broken clutch cable 20km outside Bamberg...
2000 Kawasaki W650
The Jerk is offline   Reply With Quote
Old 03-31-2014, 02:03 PM   #43
C/1/509
Oddometer: 6,284
LOL - well, sometimes scaring yourself (hopefully without consequences) is the best way to remember. Infallible? Nah, don't want that - someone would have to build a temple for you and it would get all complicated.
Old 03-31-2014, 08:32 PM   #44
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,412
Learn to ride on a kick start bike. The kickstand hits the ground when you kick the motor over, forcing you to put it up. Now I put it before hitting the magic button.
2009 Aprilia Dorsoduro 750 (adventurized): http://www.apriliaforum.com/forums/a...893274&thumb=1
High Country Herb is offline   Reply With Quote
Old 04-01-2014, 04:05 AM   #45
Newbedonnie
Oddometer: 273
Originally Posted by DudeClone View Post
yea i was ridin' on the bike the other day leaving a parking structure and the woman in the booth waved me ahead after the gate lifted for a car in front of me. outstanding, free parking!!!
as i rode through behind the car, the gate came down on my head, thunking my helmet good
noob
I can't help but begin to think you really can't be this inept...but rather just trolling right along.
Newbedonnie is offline   Reply With Quote
Times are GMT -7.   It's 08:29 AM.
