Old 03-19-2014, 12:19 PM   #1
E-Bum OP
E-Bum's Avatar
Oddometer: 729
New shock for long-term reliability... help me out.
I am completely redoing my 1988 Africa Twin RD03 at the moment and have put off deciding what to do with my rear shock until now. The original Showa shock needs replacing/rebuilding as it has vey little damping (needs reecharging) left and I believe the spring to be a bit tired.
My biggest priority is reliability and rebuildability. Ideally whatever replacement should be able to endure a RTW. I realize that at some point during this RTW the shock is going to need an overhaul, or replacement. The idea is to go with whatever solution gives me the best reliability. Secondary is race-spec performance. I want to explore what options are available and recommended with price being the last priority.
With many of the original AT components being of above average quality, is rebuilding the original Showa on option I should consider based on reliability? Should I instead go for a modern supension which undoubtedly be more performant, yet perhaps less reliable? If so, which?
Thanks in advance!
E-Bum is offline   Reply With Quote
Old 03-22-2014, 08:39 AM   #2
E-Bum OP
E-Bum's Avatar
Oddometer: 729
anyone?
Old 03-23-2014, 09:52 PM   #3
BergDonk
BergDonk's Avatar
Oddometer: 3,923
Well I've had excellent service with Ohlins. They work great once sprung and valved to suit, and are easy to serrvice when needed, and have never failed on me. 3 Ohlins on 3 bikes now and over 100,000 kms.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 03-23-2014, 11:07 PM   #4
Calikatoom
Norcal Moto Nut
Oddometer: 289
Works Performance will build you a custom rebuildable shock and it won't break the bank either
Calikatoom is offline   Reply With Quote
Old 03-24-2014, 08:51 AM   #5
yamalama
wet coaster
yamalama's Avatar
Oddometer: 1,290
The Wilber i installed on my Super Tenere 750 has been great, so far.
yamalama is offline   Reply With Quote
Old 03-24-2014, 10:51 AM   #6
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,385
The Penske is supposed to be easier to rebuild. I never found out on the one I had for 40k. miles as it had no issues.
Several good shocks to choose from.
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 03-24-2014, 03:39 PM   #7
Gustavo
Motociclista Errante
Gustavo's Avatar
Oddometer: 2,292
I've had a couple of Wilbers shocks that worked pretty well. Both were made to my custom order and arrived just as I ordered them (even when I made a mistake, they made exactly what I asked for, so I can't complain ). I have an Elka that works OK now but was a pain to get right initially, so I do not recommend them if you are in need of something that will show up as you needed to continue your RTW trip.
Gustavo
Gustavo is offline   Reply With Quote
Old 03-24-2014, 03:52 PM   #8
E-Bum OP
E-Bum's Avatar
Oddometer: 729
How have people's experiences been with Ohlins' customer service overseas. For example, shock blows out in Patagonia somewhere.. How dependable is Ohlins in terms of supporting their product?
Does anyone have any experiences with Hyperpro shocks?
Times are GMT -7.   It's 06:35 AM.
