Old 03-19-2014, 07:24 PM   #1
alexcorral OP
alexcorral's Avatar
Oddometer: 1,304
Bar risers for 2014 GSAW
I stopped by my dealer today and saw my GSA on the showroom floor. I got on and immediately knew I will need some bar risers for comfortable riding on the pegs. I saw the risers on Touratech but these only raise the bars 0.6". I am looking for at least 1" rise or as high as I an go without needing to re-route any wires or lines.
Any recommendations?
2014 BMW R1200 GS Adventure
2014 KTM 350EXC-F
2013 Harley Davidson 1200 Custom 110th Anniversary
alexcorral is offline   Reply With Quote
Old 03-19-2014, 07:50 PM   #2
ADV Fool
ADV Fool's Avatar
Oddometer: 451
ROX Risers
I just put ROX Risers on my 2014 GSA WC. I went with the 1 1/2 inch riser just for the same reason, no need to move any lines. I gott'm from Adventure Designs. Check out their website.
'Grand Fool' for the 'Group of Fools'
Old Fat Fart
2014 BMW R1200 GSA LC
2010 HD Ultra "Limited"
ADV Fool is offline   Reply With Quote
Old 03-19-2014, 08:51 PM   #3
picard
engage!
picard's Avatar
Oddometer: 1,309
ADVMotorrad sells the 40mm rox risers.
SW-Motech also sells 40mm risers.
Both claim no line extensions needed. I will be able to tell you whether that's true in about 2 weeks.
"Rumors of my assimilation are greatly exaggerated." (Capt. Picard)
picard is offline   Reply With Quote
Old 03-19-2014, 09:25 PM   #4
Ojai GS guy
Been there-Done that
Ojai GS guy's Avatar
Oddometer: 106
I installed 40mm Black Dog Cycle Works bar risers on my GSW. The fit great, look even better, no need to adjust cables. My shoulders and back no longer hurt after a long ride.
Sent from my iPad using Tapatalk HD
Ojai GS guy is offline   Reply With Quote
Old 03-19-2014, 09:39 PM   #5
Kevin Dixon
Motorrad Abenteurer
Kevin Dixon's Avatar
Oddometer: 818
I second the black dog. They perfectly match the finish of the bike. Raise 40mm and require no cable adjustments.
Kevin Dixon is offline   Reply With Quote
Old 03-20-2014, 06:23 AM   #6
alexcorral OP
alexcorral's Avatar
Oddometer: 1,304
Thanks for the recommendation. I take away that I can manage 40mm without extending or re-routing any cables. I'll look at SWMotech, Blackdog and Rox Risers
2014 KTM 350EXC-F
Old 03-20-2014, 07:58 AM   #7
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 814
I put Rox risers on my GSAW and only had to move the lines to the outside of the fork. Works like a charm.
Got places to do and things to be.
'14 1200 GSA
seatec is offline   Reply With Quote
Old 03-20-2014, 10:18 AM   #8
mefly2
mefly2's Avatar
Oddometer: 1,228
Did you actually try the TT risers with the bar angle changed as well?
It might do the job ... as I, too, thought that I needed more raise.
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 03-20-2014, 07:42 PM   #9
alexcorral OP
alexcorral's Avatar
Oddometer: 1,304
I did not. The first thing I did was rotate the bars and that made it a bit better (even for riding on the seat) but I am going to need to raise them further. I am 6' 2" and have to lean forward too much when riding on the pegs.
Here's what I've found with help from folks:
Touratech 15mm $73.50
SW-Motech 40mm $124.99 (specified for 2013 R1200GS, not sure if they will work on the 2014 R1200GSA)
Rox Risers 50mm $135 (pivoting)
Black Dog 40mm $145
2014 KTM 350EXC-F
Old 03-21-2014, 07:03 AM   #10
OldMotoGuySoCal
Returning Rider
Oddometer: 203
Touratech
I just got the new Touratech catalog and they now have 15mm, 25mm and 40mm risers for the GSW/GSAW
OldMotoGuySoCal is offline   Reply With Quote
Old 03-21-2014, 07:12 AM   #11
weld86
Weld86 Motoparts
Oddometer: 201
Wonderlich has a set. 35mm up x 27mm back. Has anyonr tried these?
http://www.wunderlichamerica.com/mot.../41970111.html
weld86 is offline   Reply With Quote
Old 03-21-2014, 07:22 AM   #12
alexcorral OP
alexcorral's Avatar
Oddometer: 1,304
TT 40mm risers would be the perfect ones... I can't find them on line to order
2014 KTM 350EXC-F
Old 03-21-2014, 07:26 AM   #13
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 814
I chose the Rox risers because I didn't want the bars to come loser to me as I elevated them 2". With Rox you have axis that you can use to custom position your bars.
'14 1200 GSA
Old 03-21-2014, 07:47 AM   #14
Kevin Dixon
Motorrad Abenteurer
Oddometer: 818
I would have but they always show as backordered with 8 weeks delivery time so I gave up on them.
Old 03-21-2014, 09:23 AM   #15
Zuppy51
Oddometer: 42
I got tired of waiting on the pull back from Wunderlich and ordered these.
Handlebar Risers, 25mm
Part Number: 41970011
Price: $85.00
They work perfectly....
Zuppy51 is offline   Reply With Quote
Times are GMT -7.   It's 04:37 AM.
