Old 03-21-2014, 10:17 AM   #16
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,270
CZ-
I got one of those giant iron-ore magnets we could use to try and pull the loose metal towards the oil drain hole, then try to reach it with a shop magnet. I'll bring it by tonight.
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Old 03-21-2014, 10:29 AM   #17
cycleman2
Oddometer: 532
If you have a magnetic drain plug it will also pick up the small metal pieces.
1971 R50/5 Cafe Project
2013 DL650 Adv
cycleman2 is offline   Reply With Quote
Old 03-21-2014, 10:48 AM   #18
c-zulu OP
Resident Dirt Burner
c-zulu's Avatar
Oddometer: 1,312
Originally Posted by jwalters View Post
CZ-
RGR that..
Current Rides:
HONDA CRF450X---BUELL XB12X
KTM 950 SER---KTM 950 ADV S---KTM 690 ER
MOTO GUZZI STELVIO NTX---VICTORY KINGPIN TOUR
c-zulu is offline   Reply With Quote
Old 03-22-2014, 07:28 AM   #19
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,270
Well C-Zulu and I made quick work of removing the fuel pump engine bracket to see if that would give us a better angle on the debris. It didn't.
Looking at the bolt though, the piece of metal missing is smaller than the width of a grain of rice, and it appears to have been torn off (hopefully into smaller pieces yet) so I don't think it's too bad of an issue. 500 mile oil change and hope for the best!
Old 03-24-2014, 01:12 AM   #20
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,118
Will probably work but it's a 4000 dollar guess..
Verstuurd vanaf mijn LG-D802 met Tapatalk
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 03-24-2014, 11:02 AM   #21
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 883
Once in my 950, started the engine and the clackity-clackity-clackity would not go away. Only above 5000rpms would sound like a normal engine.
Imediately thought that it hadn't any oil, cheked oil level, all ok, but simply it would not stop making that terrible noise.
Laid on left side and removed the oil filter screen cover. (didn't take a pic), but there was a spring hitting the oil screen.
Later found it was the oil pressure valve spring that had come off the housing, hence the low oil pressure and clacky distribution.
But now one question remained to be answered: If the spring was off, where was the washer and locking circlip that held it??????
spent several hours fishing the engine cases with a magnet without any luck... was already budgeting for a complete tear down, when suddenly:
Next to the hex bolt, there they were, washer and circlip! How they got there and remained there with the running engine is a complete mistery!
bottom line, look for that bit in the weirdest places of the sump.
690R
Gustavo.Ramos is online now   Reply With Quote
Old 03-24-2014, 12:02 PM   #22
c-zulu OP
c-zulu's Avatar
Oddometer: 1,312
Did that,plan on doing that again. My offending foreign debris isn't anything comparable in size to your find, which is good and bad I suppose..
Current Rides:
Times are GMT -7.   It's 04:27 PM.
